harascarlett44 0 Posted ... (edited) I followed the instructions here: and here but no matter what torrent i start my ports are greyed out and have no connection, and all my torrents which have tons of seeders, are have 0 seeds and 0 peers. i am using a macbook running on mojave. i have network lock enabled on eddie. im baffled since i had airvpn a year ago and never had this problem. can someone help me? canyouseeme says "reason: connection refused" when i try to check the port. Edited ... by harascarlett44 forgot a detail Share this post Link to post
Tech Jedi Alex 1492 Posted ... Disable NetLock, try again. 11 hours ago, harascarlett44 said: and all my torrents which have tons of seeders, are have 0 seeds and 0 peers. [...] canyouseeme says "reason: connection refused" when i try to check the port. These indicate you're not properly connected and that you're behind a firewall which is rejecting too much. 1 harascarlett44 reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
harascarlett44 0 Posted ... (edited) 4 hours ago, giganerd said: Disable NetLock, try again. These indicate you're not properly connected and that you're behind a firewall which is rejecting too much. i remember now, even when i had netlock turned off it still didn't work. all ports still greyed Edited ... by harascarlett44 Share this post Link to post
bluesjunior 46 Posted ... Unsure if this will help but the last few weeks I had been getting problems with qBittorrent where I would be downloading fine and the shift to a new site or page in my browser and everything would freeze up. My only way out was to exit both browser and qBittorrent choose a new server in AirVPN and then open my browser and qBittorrent again. Sometimes this solved it for the session and sometimes I would have to repeat. Now I only use AirVPN and QBittorrent for a couple of hours daily the rest of the time I am on an open connection. I had tried to find out what was causing this but not being a tekkie type I found no solutions. However three days ago I visited the qBittorrents site and found the following post and which I implemented the advice offered and have had no problems since (touch wood). I thibk it had something to do with UPn'P being on but like I say not sure. Hope it helps anyway. https://qbforums.shiki.hu/index.php/topic,7101.0.html 1 harascarlett44 reacted to this Share this post Link to post
Tech Jedi Alex 1492 Posted ... 7 hours ago, bluesjunior said: I thibk it had something to do with UPn'P being on More like uTP. This one is known to cause strange behavior of torrent clients in a VPN tunnel. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
harascarlett44 0 Posted ... 17 hours ago, bluesjunior said: Unsure if this will help but the last few weeks I had been getting problems with qBittorrent where I would be downloading fine and the shift to a new site or page in my browser and everything would freeze up. My only way out was to exit both browser and qBittorrent choose a new server in AirVPN and then open my browser and qBittorrent again. Sometimes this solved it for the session and sometimes I would have to repeat. Now I only use AirVPN and QBittorrent for a couple of hours daily the rest of the time I am on an open connection. I had tried to find out what was causing this but not being a tekkie type I found no solutions. However three days ago I visited the qBittorrents site and found the following post and which I implemented the advice offered and have had no problems since (touch wood). I thibk it had something to do with UPn'P being on but like I say not sure. Hope it helps anyway. https://qbforums.shiki.hu/index.php/topic,7101.0.html thanks for the tip. im not a techie either and i had airvpn for a year so i’m disappointed i couldnt get it to work, but it is kind of a technical vpn. if i renew ill try what you did. i tried everything i could think of or research for a whole day...anyways thanks again!! Share this post Link to post
