cristiline
Can't connect with Network Lock
Hi, everyone. I purchased a new laptop recently (Windows 10), but haven't been able to get Eddie (v2.16.3) to connect while Network Lock is activated. It does connect if Network Lock is turned off. I tried turning off my Firewall, and that didn't help. I'm pretty amateur when it comes to connection settings, so please be patient.
I activate Network Lock, then "Connect to a recommended server." After connecting, it goes through the steps: Flushing DNS > Checking Route IPv6 > Disconnecting > Restart in 3 seconds. I have let it go through several recommended servers, and they all fail.
Here is my log from the most recent connection (with Firewall on, but I've allowed the Eddie-UI app through):
I 2019.05.26 13:35:29 - Session starting.
I 2019.05.26 13:35:29 - Checking authorization ...
! 2019.05.26 13:35:30 - Connecting to Sadalbari (Canada, Toronto, Ontario)
. 2019.05.26 13:35:30 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2019.05.26 13:35:30 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2019.05.26 13:35:30 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2019.05.26 13:35:30 - Connection to OpenVPN Management Interface
. 2019.05.26 13:35:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2019.05.26 13:35:30 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.05.26 13:35:30 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.05.26 13:35:30 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2019.05.26 13:35:30 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2019.05.26 13:35:30 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.181:443
. 2019.05.26 13:35:30 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2019.05.26 13:35:30 - OpenVPN > UDP link local: (not bound)
. 2019.05.26 13:35:30 - OpenVPN > UDP link remote: [AF_INET]184.75.221.181:443
. 2019.05.26 13:35:30 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.181:443, sid=25fa639e 65bd42b5
. 2019.05.26 13:35:30 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2019.05.26 13:35:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2019.05.26 13:35:30 - OpenVPN > VERIFY KU OK
. 2019.05.26 13:35:30 - OpenVPN > Validating certificate extended key usage
. 2019.05.26 13:35:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2019.05.26 13:35:30 - OpenVPN > VERIFY EKU OK
. 2019.05.26 13:35:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2019.05.26 13:35:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2019.05.26 13:35:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.181:443
. 2019.05.26 13:35:31 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2019.05.26 13:35:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.186.1,dhcp-option DNS6 fde6:7a:7d20:18ba::1,tun-ipv6,route-gateway 10.28.186.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:18ba::1061/64 fde6:7a:7d20:18ba::1,ifconfig 10.28.186.99 255.255.255.0,peer-id 5,cipher AES-256-GCM'
. 2019.05.26 13:35:31 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2019.05.26 13:35:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2019.05.26 13:35:31 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2019.05.26 13:35:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2019.05.26 13:35:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2019.05.26 13:35:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2019.05.26 13:35:31 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2019.05.26 13:35:31 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2019.05.26 13:35:31 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2019.05.26 13:35:31 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2019.05.26 13:35:31 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.05.26 13:35:31 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2019.05.26 13:35:31 - OpenVPN > interactive service msg_channel=0
. 2019.05.26 13:35:31 - OpenVPN > ROUTE_GATEWAY 10.0.0.1/255.255.255.0 I=15 HWADDR=50:76:af:10:8d:3a
. 2019.05.26 13:35:31 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2019.05.26 13:35:31 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2019.05.26 13:35:31 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2019.05.26 13:35:31 - OpenVPN > open_tun
. 2019.05.26 13:35:31 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{50838EC1-5CE3-48FB-A038-80B6D17D1920}.tap
. 2019.05.26 13:35:31 - OpenVPN > TAP-Windows Driver Version 9.21
. 2019.05.26 13:35:31 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.28.186.0/10.28.186.99/255.255.255.0 [SUCCEEDED]
. 2019.05.26 13:35:31 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.28.186.99/255.255.255.0 on interface {50838EC1-5CE3-48FB-A038-80B6D17D1920} [DHCP-serv: 10.28.186.254, lease-time: 31536000]
. 2019.05.26 13:35:31 - OpenVPN > Successful ARP Flush on interface [41] {50838EC1-5CE3-48FB-A038-80B6D17D1920}
. 2019.05.26 13:35:32 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2019.05.26 13:35:32 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=41 fde6:7a:7d20:18ba::1061 store=active
. 2019.05.26 13:35:33 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:18ba::1 validate=no
. 2019.05.26 13:35:33 - OpenVPN > add_route_ipv6(fde6:7a:7d20:18ba::/64 -> fde6:7a:7d20:18ba::1061 metric 0) dev Ethernet 2
. 2019.05.26 13:35:33 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:18ba::/64 interface=41 fe80::8 store=active
. 2019.05.26 13:35:33 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2019.05.26 13:35:38 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2019.05.26 13:35:38 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.221.181 MASK 255.255.255.255 10.0.0.1
. 2019.05.26 13:35:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2019.05.26 13:35:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2019.05.26 13:35:38 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.28.186.1
. 2019.05.26 13:35:38 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.28.186.1
. 2019.05.26 13:35:38 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:18ba::1 metric -1) dev Ethernet 2
. 2019.05.26 13:35:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=41 fe80::8 store=active
. 2019.05.26 13:35:38 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2019.05.26 13:35:38 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:18ba::1 metric -1) dev Ethernet 2
. 2019.05.26 13:35:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=41 fe80::8 store=active
. 2019.05.26 13:35:38 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:18ba::1 metric -1) dev Ethernet 2
. 2019.05.26 13:35:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=41 fe80::8 store=active
. 2019.05.26 13:35:38 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:18ba::1 metric -1) dev Ethernet 2
. 2019.05.26 13:35:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=41 fe80::8 store=active
. 2019.05.26 13:35:38 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2019.05.26 13:35:38 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2019.05.26 13:35:38 - DNS leak protection with packet filtering enabled.
. 2019.05.26 13:35:38 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.28.186.1)
. 2019.05.26 13:35:38 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:18ba::1)
. 2019.05.26 13:35:38 - Routes, added a new route, 184.75.221.179 for gateway 10.28.186.1
. 2019.05.26 13:35:38 - Routes, added a new route, 2606:6080:1001:14:c766:f45a:ac4d:72a0 for gateway fde6:7a:7d20:18ba::1
. 2019.05.26 13:35:38 - Flushing DNS
I 2019.05.26 13:35:42 - Checking route IPv4
I 2019.05.26 13:35:42 - Checking route IPv6
. 2019.05.26 13:36:02 - curl: (28) Connection timed out after 20000 milliseconds
. 2019.05.26 13:36:02 - Checking route (2° try)
. 2019.05.26 13:36:23 - curl: (28) Connection timed out after 20000 milliseconds
. 2019.05.26 13:36:23 - Checking route (3° try)
. 2019.05.26 13:36:45 - curl: (28) Connection timed out after 20000 milliseconds
E 2019.05.26 13:36:45 - Checking route IPv6 failed.
. 2019.05.26 13:36:45 - OpenVPN > Initialization Sequence Completed
! 2019.05.26 13:36:45 - Disconnecting
. 2019.05.26 13:36:45 - Routes, removed a route previously added, 184.75.221.179 for gateway 10.28.186.1
. 2019.05.26 13:36:45 - Routes, removed a route previously added, 2606:6080:1001:14:c766:f45a:ac4d:72a0 for gateway fde6:7a:7d20:18ba::1
. 2019.05.26 13:36:45 - Sending management termination signal
. 2019.05.26 13:36:45 - Management - Send 'signal SIGTERM'
. 2019.05.26 13:36:45 - OpenVPN > MANAGEMENT: CMD '44679cf303b56fae9cbcecb893bfa9985bbcec7150417c8aec8bd265bc65754c'
. 2019.05.26 13:36:54 - Sending management termination signal
. 2019.05.26 13:36:54 - Management - Send 'signal SIGTERM'
. 2019.05.26 13:36:54 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2019.05.26 13:36:54 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2019.05.26 13:36:59 - OpenVPN > C:\Windows\system32\route.exe DELETE 184.75.221.181 MASK 255.255.255.255 10.0.0.1
. 2019.05.26 13:36:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2019.05.26 13:36:59 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.28.186.1
. 2019.05.26 13:36:59 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.28.186.1
. 2019.05.26 13:36:59 - OpenVPN > delete_route_ipv6(::/3)
. 2019.05.26 13:36:59 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=41 fe80::8 store=active
. 2019.05.26 13:36:59 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2019.05.26 13:36:59 - OpenVPN > delete_route_ipv6(2000::/4)
. 2019.05.26 13:36:59 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=41 fe80::8 store=active
. 2019.05.26 13:36:59 - OpenVPN > delete_route_ipv6(3000::/4)
. 2019.05.26 13:36:59 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=41 fe80::8 store=active
. 2019.05.26 13:36:59 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2019.05.26 13:36:59 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=41 fe80::8 store=active
. 2019.05.26 13:36:59 - OpenVPN > Closing TUN/TAP interface
. 2019.05.26 13:36:59 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:18ba::/64)
. 2019.05.26 13:36:59 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:18ba::/64 interface=41 fe80::8 store=active
. 2019.05.26 13:36:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:18ba::1061 store=active
. 2019.05.26 13:36:59 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2019.05.26 13:36:59 - OpenVPN > TAP: DHCP address released
. 2019.05.26 13:36:59 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2019.05.26 13:36:59 - Connection terminated.
. 2019.05.26 13:36:59 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2019.05.26 13:36:59 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2019.05.26 13:36:59 - DNS leak protection with packet filtering disabled.
. 2019.05.26 13:37:00 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2019.05.26 13:37:00 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2019.05.26 13:37:03 - Cancel requested.
! 2019.05.26 13:37:03 - Session terminated.
Thanks for any advice you can offer!
