Korr
AirVPN on Android [UPDATED GUIDE] (ICS/JB)
The following is is updated version of the guide found here. This version is using the latest version of OpenVPN (0.5.22) for android and has been tested on ICS 4.0.1 and the latest version of JB.
1.) Install Openvpn on your android device (it's free) LINK
2.) Log into the airvpn website on your computer.
3.)Download your desired config for airvpn via the 'Access without client' (For this guide I'm downloading all to my phone can I can have a selection) LINK FOR THE LAZY
Posted Image
Posted Image
4.) Extract the folder that you download from the airvpn site
Posted Image
5.) Connect your phone to your computer and copy the 'air' folder to your sdcard (you can change the name of the folder if you wish makes no difference)
6.) Open OpenVPN app on your phone
7.) Tap 'All your precious VPNs'
Posted Image
8.) Tap the 'import from file' icon
Posted Image
9.) Tap the folder which you copied from your computer mine is called 'air'
Posted Image
10.) Tap the server you wish to use then press 'Select'
Posted Image
11.) The following screen should look similar so tap 'Save'
Posted Image
12.) Tap the configuration to connect.
Posted Image
13.) Chrome showing its connected!
Posted Image
Enjoy!
