amirkhan
Can't Connect
When i run AirVPN,after i input login info and press Login,i get message 'Unable to connect to the remote server.
My os is windows 7
The thing is,it was connecting fine before,but i had a dns leak,so after trying to fix the dns leak,it doesn't connect any more ? !!
My os is windows 7
Probably you have blocked DNS resolution when you are not connected to the VPN (preventing therefore DNS leaks, and that's fine). The Air client needs to resolve airvpn.org in order to show you the servers list, download certificates etc.
You have various options to solve the issue:
1) Use OpenVPN or OpenVPN GUI instead of the Air client
or
2) Add to your hosts file the following line:
46.105.19.36 airvpn.org
This line resolves airvpn.org to the correct IP address, rendering a DNS query unnecessary.
or
3) Secure your VPN connection with Comodo firewall in order to prevent every leak, not only DNS leaks, in case of unexpected VPN disconnection.
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=3405&Itemid=142
I did those 2,and still doesn't connect
or
or
Can you please describe what you have done to prevent DNS leaks? Also, please send us the OpenVPN logs.
