pane 0 Posted ... Hello, since one or two weeks i have problems with some websites (local radio site,google,streaming sites and imagehosting) when i am connected to Alderamin Vienna-Austria. Some are not working without any message, sometimes i get a "access forbidden 403 nginx" or i have to solve captchas all the time. When i change the VPN connection the problem is gone. Anyone else with this problem? Is Alderamin used for Spam or DDOS? Quote Share this post Link to post
Guest Posted ... I had the same issues with this particular server. According to browserleaks.com, Alderamin is run as a Tor exit node by someone. 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
amazake 1 Posted ... The exit node on Alderamin has been down for 2 days, but now there's one running on Caelum for a couple hours now. As soon as the exit got up, several sites which previously worked are now showing 403. Too bad there's nothing to prevent this, I guess. Also the names of these exits are just dumb. Quote Share this post Link to post
Staff 10393 Posted ... 20 hours ago, amazake said: the names of these exits are just dumb. All the Air VPN servers are named after stars and constellations. Alderamin: https://en.wikipedia.org/wiki/Alpha_Cephei Caelum: https://en.wikipedia.org/wiki/Caelum 1 amazake reacted to this Quote Share this post Link to post
amazake 1 Posted ... You got me wrong there, @Staff. I didn't mean the names you give the servers. They are great, I love that you chose stars and constellations! I meant the names of the Tor exit nodes that were given by whoever is running them behind the Austrian servers. I should have probably made that more clear. 1 Staff reacted to this Quote Share this post Link to post
pane 0 Posted ... OK,thank you all for the reply. The Problem seems gone since yesterday. Would have been nice to hear what is has caused from someone from AirVpn. Have a nice weekend Quote Share this post Link to post
Staff 10393 Posted ... Hello! The Tor exit-nodes list is highly fluid and can change from one minute to another. Kind regards Quote Share this post Link to post
