Jack.Vaneden
Why I can´t reach some Websites with AirVPN
for example this one:
https://www.lite-magazin.de
I get a timeout message.
When I switch off AirVPN I get access. I have recognized this problem with a lot of websites including my own blog.
When I do a check at
https://airvpn.org/routes/
it doesn´t seems, that AirVPN is the problem in general. Is there a solution, or does someone no, what the actual problem is?
My Addblocker is not the problem. I am using Win 10.
No problem overhere;I am surfing from ch .
Btw you can use an adblocker also on win10.
(privacytools.io)
thanks for your replay. but strange that you have no problem. i can´t reach the website no matter what airvpn server i use. when i switch airvpn off, or set the ip in "oustside the tunnel", it works.
okay when i use the Gliese US, i get access to the webiste. with  cervantes GER or Almach CAN for example, it is not possible.
