vpnbear99 0 Posted ... Hello! At Starbucks, and some coffee shops, AirVPN doesn't work. Is there a setting I need to adjust? Or do some coffee shops simply ban VPNs? Thanks! Quote Share this post Link to post
Mad_Max 16 Posted ... Hello If you are using a Eddie on laptop, then go to settings --- Protocols, Un-check automatic, and press on UDP Ip3 443.... If it doesnt work then try TCP Ip3 443, then SSH Then SSL Quote Share this post Link to post
vpnbear99 0 Posted ... Thank you, Mad_Max. I'll try that my next visit. Quote Share this post Link to post
LZ1 678 Posted ... 17 hours ago, Mad_Max said: Hello If you are using a Eddie on laptop, then go to settings --- Protocols, Un-check automatic, and press on UDP Ip3 443.... If it doesnt work then try TCP Ip3 443, then SSH Then SSL Hello! And to add to this, remember to re-connect to a server each time, for the changes to take effect. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
