routeninja 23 Posted ... https://lttelevision.com/product/mango-vpn/ I would love to have a little box like that for Air. Its possible I could simply buy that box and maybe change the config to point to Air instead. Anyone seen anything like this? 2 1 LornaGrere, Gordonmouff and KennethKnism reacted to this Quote Share this post Link to post
zhang888 1067 Posted ... Buy from GL-Inet directly, why do you need to buy from those resellers for €75 when it's $20 directly?https://store.gl-inet.com/collections/travel-routers/products/gl-mt300n-v2-mini-smart-routerIt's the same box.For that budget, the Slate is a much better product, with a better CPU for encryption:https://www.gl-inet.com/products/gl-ar750s/ And yes they all support Air out of the box since it comes with OpenWRT preinstalled. 3 1 Gordonmouff, JasonBourne, LZ1 and 1 other reacted to this Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
routeninja 23 Posted ... Do either of those create a wifi that we could connect to for wireless devices? Thats what I am looking for as well. Buy from GL-Inet directly, why do you need to buy from those resellers for €75 when it's $20 directly?https://store.gl-inet.com/collections/travel-routers/products/gl-mt300n-v2-mini-smart-routerIt's the same box.For that budget, the Slate is a much better product, with a better CPU for encryption:https://www.gl-inet.com/products/gl-ar750s/ And yes they all support Air out of the box since it comes with OpenWRT preinstalled. Quote Share this post Link to post
JasonBourne 8 Posted ... Do either of those create a wifi that we could connect to for wireless devices? Thats what I am looking for as well. Yes! GL-MT300N-V2 / Mango --- 300Mbps (2.4GHz)GL-AR750S / Slate --- 300Mbps (2.4GHz) + 433Mbps (5GHz) [Dual-band Wi-Fi] Quote Share this post Link to post
flat4 95 Posted ... I got to ask, cause I'm lazy to search, can pfsense be installed on this puppy Sent from my SM-N960U using Tapatalk 1 LornaGrere reacted to this Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
routeninja 23 Posted ... I got to ask, cause I'm lazy to search, can pfsense be installed on this puppy Sent from my SM-N960U using TapatalkNo idea. But I am curious, can this thing really do OpenVPN at 300Mbps with that CPU? 1 KennethKnism reacted to this Quote Share this post Link to post
flat4 95 Posted ... I got to ask, cause I'm lazy to search, can pfsense be installed on this puppy Sent from my SM-N960U using TapatalkProbably not since it's a SOC Sent from my SM-N960U using Tapatalk 1 SueWet reacted to this Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
flat4 95 Posted ... I got to ask, cause I'm lazy to search, can pfsense be installed on this puppy Sent from my SM-N960U using TapatalkNo idea. But I am curious, can this thing really do OpenVPN at 300Mbps with that CPU?Yeah I'd like to see what Sent from my SM-N960U using Tapatalk Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
go558a83nk 383 Posted ... I got to ask, cause I'm lazy to search, can pfsense be installed on this puppy Sent from my SM-N960U using TapatalkNo idea. But I am curious, can this thing really do OpenVPN at 300Mbps with that CPU? Where are you getting 300mbps from? Are you reading the wifi standard speed and confusing that with openvpn speed? Quote Share this post Link to post
arteryshelby 25 Posted ... On 4/4/2019 at 7:09 PM, go558a83nk said: Where are you getting 300mbps from? Are you reading the wifi standard speed and confusing that with openvpn speed? Wi-Fi for sure.. Openvpn speed would be interessting! Edit: MT300N-V2 10Mbps Openvpn.. Well .. that makes it useless But quite allright for 20 bucks. Quote Share this post Link to post
