qwertylad 0 Posted ... Hi. I can connect to your servers and when I use checkmyip.com it shows I am using them, but when i go on to the AirVPN website the Red 'Not Connected' icon is shown and i cant do a speed check either as it says im not connected. I have changed my FireWall/Anti Virus to accept Air VPN, But it still shows 'Not Connected' Please help! Quote Share this post Link to post
Staff 10415 Posted ... Hi.I can connect to your servers and when I use checkmyip.com it shows I am using them, but when i go on to the AirVPN website the Red 'Not Connected' icon is shown and i cant do a speed check either as it says im not connected.I have changed my FireWall/Anti Virus to accept Air VPN, But it still shows 'Not Connected'Please help!Hello!Can you please send us the connection logs?Kind regards Quote Share this post Link to post
qwertylad 0 Posted ... 11/08/2012 - 11:42 AirVPN client version: 1.7 11/08/2012 - 11:42 Reading options from C:\Users\David\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 11/08/2012 - 11:42 OpenVPN bundle version: OpenVPN 2.2.2 11/08/2012 - 11:42 OpenVPN current version: OpenVPN 2.2.2 11/08/2012 - 11:42 Ready. 11/08/2012 - 11:42 Login... 11/08/2012 - 11:42 Login success. 11/08/2012 - 11:43 Contacting service... 11/08/2012 - 11:43 Connecting... 11/08/2012 - 11:43 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 11/08/2012 - 11:43 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 11/08/2012 - 11:43 LZO compression initialized 11/08/2012 - 11:43 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 11/08/2012 - 11:43 Socket Buffers: R=[516096->516096] S=[172032->172032] 11/08/2012 - 11:43 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 11/08/2012 - 11:43 Local Options hash (VER=V4): '22188c5b' 11/08/2012 - 11:43 Expected Remote Options hash (VER=V4): 'a8f55717' 11/08/2012 - 11:43 UDPv4 link local: [undef] 11/08/2012 - 11:43 UDPv4 link remote: 89.149.226.185:443 11/08/2012 - 11:43 TLS: Initial packet from 89.149.226.185:443, sid=a90abc00 5e50b67c 11/08/2012 - 11:43 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 11/08/2012 - 11:43 VERIFY OK: nsCertType=SERVER 11/08/2012 - 11:43 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 11/08/2012 - 11:43 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 11/08/2012 - 11:43 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 11/08/2012 - 11:43 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 11/08/2012 - 11:43 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 11/08/2012 - 11:43 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 11/08/2012 - 11:43 [server] Peer Connection Initiated with 89.149.226.185:443 11/08/2012 - 11:43 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) 11/08/2012 - 11:43 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.27.158 10.4.27.157' 11/08/2012 - 11:43 OPTIONS IMPORT: timers and/or timeouts modified 11/08/2012 - 11:43 OPTIONS IMPORT: LZO parms modified 11/08/2012 - 11:43 OPTIONS IMPORT: --ifconfig/up options modified 11/08/2012 - 11:43 OPTIONS IMPORT: route options modified 11/08/2012 - 11:43 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified 11/08/2012 - 11:43 ROUTE default_gateway=192.168.1.1 11/08/2012 - 11:43 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{24809FCF-958E-491C-AF97-2CAEF7F9DFC6}.tap 11/08/2012 - 11:43 TAP-Win32 Driver Version 9.9 11/08/2012 - 11:43 TAP-Win32 MTU=1500 11/08/2012 - 11:43 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.27.158/255.255.255.252 on interface {24809FCF-958E-491C-AF97-2CAEF7F9DFC6} [DHCP-serv: 10.4.27.157, lease-time: 31536000] 11/08/2012 - 11:43 Successful ARP Flush on interface [14] {24809FCF-958E-491C-AF97-2CAEF7F9DFC6} 11/08/2012 - 11:43 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up 11/08/2012 - 11:43 C:\WINDOWS\system32\route.exe ADD 89.149.226.185 MASK 255.255.255.255 192.168.1.1 11/08/2012 - 11:43 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 11/08/2012 - 11:43 Route addition via IPAPI succeeded [adaptive] 11/08/2012 - 11:43 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.27.157 11/08/2012 - 11:43 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 11/08/2012 - 11:43 Route addition via IPAPI succeeded [adaptive] 11/08/2012 - 11:43 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.27.157 11/08/2012 - 11:43 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 11/08/2012 - 11:43 Route addition via IPAPI succeeded [adaptive] 11/08/2012 - 11:43 C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.27.157 11/08/2012 - 11:43 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 11/08/2012 - 11:43 Route addition via IPAPI succeeded [adaptive] 11/08/2012 - 11:43 Initialization Sequence Completed 11/08/2012 - 11:43 Starting Management Interface... 11/08/2012 - 11:43 Checking... 11/08/2012 - 11:43 Retrieve statistics... 11/08/2012 - 11:43 Connected. 11/08/2012 - 12:43 TLS: soft reset sec=0 bytes=8493577/0 pkts=13992/0 11/08/2012 - 12:43 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 11/08/2012 - 12:43 VERIFY OK: nsCertType=SERVER 11/08/2012 - 12:43 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 11/08/2012 - 12:43 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 11/08/2012 - 12:43 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 11/08/2012 - 12:43 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 11/08/2012 - 12:43 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 11/08/2012 - 12:43 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 11/08/2012 - 13:43 TLS: tls_process: killed expiring key 11/08/2012 - 13:43 TLS: soft reset sec=0 bytes=5246717/0 pkts=9585/0 11/08/2012 - 13:43 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 11/08/2012 - 13:43 VERIFY OK: nsCertType=SERVER 11/08/2012 - 13:43 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 11/08/2012 - 13:43 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 11/08/2012 - 13:43 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 11/08/2012 - 13:43 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 11/08/2012 - 13:43 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 11/08/2012 - 13:43 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 11/08/2012 - 14:43 TLS: tls_process: killed expiring key 11/08/2012 - 14:43 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 11/08/2012 - 14:43 VERIFY OK: nsCertType=SERVER 11/08/2012 - 14:43 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 11/08/2012 - 14:43 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 11/08/2012 - 14:43 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 11/08/2012 - 14:43 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 11/08/2012 - 14:43 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 11/08/2012 - 14:43 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA 11/08/2012 - 15:43 TLS: tls_process: killed expiring key 11/08/2012 - 15:43 TLS: soft reset sec=0 bytes=15615161/0 pkts=19110/0 11/08/2012 - 15:43 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org 11/08/2012 - 15:43 VERIFY OK: nsCertType=SERVER 11/08/2012 - 15:43 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org 11/08/2012 - 15:43 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 11/08/2012 - 15:43 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 11/08/2012 - 15:43 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key 11/08/2012 - 15:43 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication 11/08/2012 - 15:43 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Thanks for your help Quote Share this post Link to post
Staff 10415 Posted ... Hello! The logs are perfectly fine. Now, if you restart your browser and browse to our website, you should see a green central bottom box saying "Connected!" to Omicron, as it was confirmed by checkmyip.com Kind regards Quote Share this post Link to post
qwertylad 0 Posted ... Hello again. I have restarted my Browsers - Google Chrome and Internet Explorer and cleared the history and cookies, but it still shows The red 'Not Connected' logo and my own IP address. The same issue affects my other PC too. Regards qwertylad Quote Share this post Link to post
Staff 10415 Posted ... Hello again.I have restarted my Browsers - Google Chrome and Internet Explorer and cleared the history and cookies, but it still shows The red 'Not Connected' logo and my own IP address.The same issue affects my other PC too.RegardsqwertyladHello!Can you please send us your routing table before and after the connection (feel free to delete sensitive information)? Just issue the command "route print" (before and after you have performed a connection to a VPN server) from a command prompt and publish the output.Kind regards Quote Share this post Link to post
qwertylad 0 Posted ... Microsoft Windows [Version 6.1.7601] Copyright © 2009 Microsoft Corporation. All rights reserved. C:\Windows\system32>route print =========================================================================== Interface List 14...00 ff 24 80 9f cf ......TAP-Win32 Adapter V9 #2 13...00 ff 4c bc f5 ac ......Anchorfree HSS Adapter 11...18 f4 6a 0b c3 da ......Broadcom 802.11n Network Adapter 10...88 ae 1d 74 04 65 ......Broadcom NetLink Gigabit Ethernet 1...........................Software Loopback Interface 1 =========================================================================== IPv4 Route Table =========================================================================== Active Routes: Network Destination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.101 25 127.0.0.0 255.0.0.0 On-link 127.0.0.1 306 127.0.0.1 255.255.255.255 On-link 127.0.0.1 306 127.255.255.255 255.255.255.255 On-link 127.0.0.1 306 192.168.1.0 255.255.255.0 On-link 192.168.1.101 281 192.168.1.101 255.255.255.255 On-link 192.168.1.101 281 192.168.1.255 255.255.255.255 On-link 192.168.1.101 281 224.0.0.0 240.0.0.0 On-link 127.0.0.1 306 224.0.0.0 240.0.0.0 On-link 192.168.1.101 281 255.255.255.255 255.255.255.255 On-link 127.0.0.1 306 255.255.255.255 255.255.255.255 On-link 192.168.1.101 281 =========================================================================== Persistent Routes: None IPv6 Route Table =========================================================================== Active Routes: If Metric Network Destination Gateway 1 306 ::1/128 On-link 1 306 ff00::/8 On-link =========================================================================== Persistent Routes: None C:\Windows\system32> This is before connection Quote Share this post Link to post
qwertylad 0 Posted ... Microsoft Windows [Version 6.1.7601] Copyright © 2009 Microsoft Corporation. All rights reserved. C:\Windows\system32>route print =========================================================================== Interface List 14...00 ff 24 80 9f cf ......TAP-Win32 Adapter V9 #2 13...00 ff 4c bc f5 ac ......Anchorfree HSS Adapter 11...18 f4 6a 0b c3 da ......Broadcom 802.11n Network Adapter 10...88 ae 1d 74 04 65 ......Broadcom NetLink Gigabit Ethernet 1...........................Software Loopback Interface 1 =========================================================================== IPv4 Route Table =========================================================================== Active Routes: Network Destination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.101 25 0.0.0.0 128.0.0.0 10.4.19.137 10.4.19.138 30 10.4.0.1 255.255.255.255 10.4.19.137 10.4.19.138 30 10.4.19.136 255.255.255.252 On-link 10.4.19.138 286 10.4.19.138 255.255.255.255 On-link 10.4.19.138 286 10.4.19.139 255.255.255.255 On-link 10.4.19.138 286 95.211.98.154 255.255.255.255 192.168.1.1 192.168.1.101 25 127.0.0.0 255.0.0.0 On-link 127.0.0.1 306 127.0.0.1 255.255.255.255 On-link 127.0.0.1 306 127.255.255.255 255.255.255.255 On-link 127.0.0.1 306 128.0.0.0 128.0.0.0 10.4.19.137 10.4.19.138 30 192.168.1.0 255.255.255.0 On-link 192.168.1.101 281 192.168.1.101 255.255.255.255 On-link 192.168.1.101 281 192.168.1.255 255.255.255.255 On-link 192.168.1.101 281 224.0.0.0 240.0.0.0 On-link 127.0.0.1 306 224.0.0.0 240.0.0.0 On-link 10.4.19.138 286 224.0.0.0 240.0.0.0 On-link 192.168.1.101 281 255.255.255.255 255.255.255.255 On-link 127.0.0.1 306 255.255.255.255 255.255.255.255 On-link 10.4.19.138 286 255.255.255.255 255.255.255.255 On-link 192.168.1.101 281 =========================================================================== Persistent Routes: None IPv6 Route Table =========================================================================== Active Routes: If Metric Network Destination Gateway 1 306 ::1/128 On-link 1 306 ff00::/8 On-link =========================================================================== Persistent Routes: None C:\Windows\system32> This is after connection Quote Share this post Link to post
Staff 10415 Posted ... Hello! The routing tables and the logs are just fine. We can see that your account is currently connected and exchanging data as well. If you browse to http://ip2location.com while you're connected to the VPN, is the exit-IP of the VPN server displayed? Kind regards Quote Share this post Link to post
qwertylad 0 Posted ... Hi. After checking on ip2location.com I see that it is Dutch VPN IP adress displayed. But looking at the bottom of this page it still shows me as 'Not Connected' and displayed my own IP Address. A very strange problem indeed. Regards Quote Share this post Link to post
