theuser
Connecting AirVPN over TOR - Failed to start error
I just bought this service and have problem connecting AirVPN via Vidalia
Any idea what is going wrong?
07/08/2012 - 00:38 AirVPN client version: 1.7
07/08/2012 - 00:38 Reading options from C:\Users\user\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
07/08/2012 - 00:38 OpenVPN bundle version: OpenVPN 2.2.2
07/08/2012 - 00:38 OpenVPN current version: OpenVPN 2.2.2
07/08/2012 - 00:38 Ready.
07/08/2012 - 00:38 Login...
07/08/2012 - 00:38 Login success.
07/08/2012 - 00:38 Contacting service...
07/08/2012 - 00:38 Connecting...
07/08/2012 - 00:38 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
07/08/2012 - 00:38 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
07/08/2012 - 00:38 LZO compression initialized
07/08/2012 - 00:38 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ]
07/08/2012 - 00:38 Socket Buffers: R=[8192->8192] S=[8192->8192]
07/08/2012 - 00:38 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ]
07/08/2012 - 00:38 Local Options hash (VER=V4): '22188c5b'
07/08/2012 - 00:38 Expected Remote Options hash (VER=V4): 'a8f55717'
07/08/2012 - 00:38 Attempting to establish TCP connection with 127.0.0.1:9050
07/08/2012 - 00:38 TCP connection established with 127.0.0.1:9050
07/08/2012 - 00:38 recv_socks_reply: Socks proxy returned bad reply
07/08/2012 - 00:38 TCP/UDP: Closing socket
07/08/2012 - 00:38 SIGTERM[soft,init_instance] received, process exiting
07/08/2012 - 00:38 Failed to start.
are any of your onion sites working or is it just for me that nothing is working?
We don't have onion sites...
You have to make sure that TCP rather than UDP protocol is selected in AirVPN client - by default is UDP
