Not connected, Your IP: 216.73.216.85
lazyevaluator
eddie on ubuntu LTS uses older openvpn and stunnel versions
Hi
it seems that on Ubuntu 16.04 LTS, Eddie2.16.3  uses OpenVPN client:2.3.10. anyway to force using the airvpn openvpn/stunnel version instead?
i know i can easily udpate teh repo to force updating openvpn to latest version, but i understood eddie uses a custom openvpn binary. how can i force using that?
If you install the deb package, Eddie will run the OpenVPN and stunnel version installed in the system. You should upgrade them, as in Ubuntu 16 the OpenVPN version that's available in Ubuntu repositories is 2.3.10.
If you run the portable version, Eddie comes packaged with OpenVPN 2.4.6 and anyway you can set (in "Preferences" > "Advanced") the path and name of the OpenVPN binary you prefer.
