Not connected, Your IP: 216.73.216.149
kingsroadberkshire
Unable to connect
I have been unable to connect for the past couple of days. The extract from the error log is as follows:
Thu Aug 02 21:45:39 2012 LZO compression initialized
Thu Aug 02 21:45:39 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
Thu Aug 02 21:45:39 2012 Socket Buffers: R=[8192->8192] S=[8192->8192]
Thu Aug 02 21:45:39 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
Thu Aug 02 21:45:39 2012 Local Options hash (VER=V4): '22188c5b'
Thu Aug 02 21:45:39 2012 Expected Remote Options hash (VER=V4): 'a8f55717'
Thu Aug 02 21:45:39 2012 UDPv4 link local: [undef]
Thu Aug 02 21:45:39 2012 UDPv4 link remote: 146.185.25.170:443
Thu Aug 02 21:46:39 2012 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Aug 02 21:46:39 2012 TLS Error: TLS handshake failed
Thu Aug 02 21:46:39 2012 TCP/UDP: Closing socket
Thu Aug 02 21:46:39 2012 SIGUSR1[soft,tls-error] received, process restarting
Thu Aug 02 21:46:39 2012 Restart pause, 2 second(s)
Thu Aug 02 21:46:41 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Please help.
