fHzpCOkf 0 Posted ... Hi, Application Version: 2.0.1 Could someone please try to change the port or protocol settings within the Android Eddie Client as I seem to change the settings then when trying to connect and it just connects using Port 443 and UDP. This seems to be a bug for me and I would like to confirm it with someone else. Thanks. Quote Share this post Link to post
Staff 10478 Posted ... Hi, Application Version: 2.0.1 Could someone please try to change the port or protocol settings within the Android Eddie Client as I seem to change the settings then when trying to connect and it just connects using Port 443 and UDP. This seems to be a bug for me and I would like to confirm it with someone else. Thanks. Hello! Unless you connect through imported ovpn files, please make sure you set "Quick connection mode" to "Use custom settings" in the "Settings" view in order to tell Eddie to use exclusively the protocol, port and TLS mode you selected, even when you pick "Quick connect" or a specific server from the list. Kind regards Quote Share this post Link to post
