telriot
utorrent / connection stops working
Hi everybody,
I'm having a problem with my VPN account.
As long as I connect to the service and browse the internet, use thunderbird or directly download files from the net everything works fine.
The problem comes out as soon as i start downloading something using utorrent: the download starts, but after 10 seconds it drops, and the rest of my internet services (browsing, email, etc) stop working too: as soon as I disconnect from the VPN everything goes back to normal.
I set up the port for utorrent as described here, using port forwarding, and i set up the Comodo firewall too, according to the instructions, in order to prevent dns leak.
COuld you help me somehow finding out what the problem could be?
Thank you very much,
t.
Hey! ( My personal Experience)
My first day on this service I had the same problem. I was using TCP ports and my internet connection ( after heavy loads ) would just stop all together, so what I did was switch from TCP to UDP Ports. I also use OpenVPN and not the AIRvpn Client, switching might help you too.
However, if you're using UDP Ports and are getting disconnected try using TCP instead and see if that helps. If not then wait for an admin response, admins are usually pretty fast to reply.
Trust me once you get this baby up and running you will never look back. Good luck.
Hi spocko,
Thank you very much for your answer!
I tried connecting manually though OpenVPN, as you said, selecting tcp first, and udp now: both times i checked whether the vpn was working, and it doesn't. My IP is still my usual one, even if the program says I'm connected to the VPN. That's even worse than before, since at least the VPN service itself worked with the airVPN client!
I hope I can get through this, since this looks like a good service to me too
Have a nice day,
t.
P.S. here is my log, I hope it helps!
Tue Jul 31 20:24:08 2012 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
Tue Jul 31 20:24:08 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Tue Jul 31 20:24:08 2012 LZO compression initialized
Tue Jul 31 20:24:08 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
Tue Jul 31 20:24:08 2012 Socket Buffers: R=[8192->8192] S=[8192->8192]
Tue Jul 31 20:24:08 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
Tue Jul 31 20:24:08 2012 Local Options hash (VER=V4): '22188c5b'
Tue Jul 31 20:24:08 2012 Expected Remote Options hash (VER=V4): 'a8f55717'
Tue Jul 31 20:24:08 2012 UDPv4 link local: [undef]
Tue Jul 31 20:24:08 2012 UDPv4 link remote: 178.248.29.132:443
Tue Jul 31 20:24:08 2012 TLS: Initial packet from 178.248.29.132:443, sid=309265c5 dbe422a4
Tue Jul 31 20:24:09 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
Tue Jul 31 20:24:09 2012 VERIFY OK: nsCertType=SERVER
Tue Jul 31 20:24:09 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
Tue Jul 31 20:24:15 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Tue Jul 31 20:24:15 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Jul 31 20:24:15 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Tue Jul 31 20:24:15 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Jul 31 20:24:15 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Tue Jul 31 20:24:15 2012 [server] Peer Connection Initiated with 178.248.29.132:443
Tue Jul 31 20:24:18 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Tue Jul 31 20:24:18 2012 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.22.218 10.4.22.217'
Tue Jul 31 20:24:18 2012 OPTIONS IMPORT: timers and/or timeouts modified
Tue Jul 31 20:24:18 2012 OPTIONS IMPORT: LZO parms modified
Tue Jul 31 20:24:18 2012 OPTIONS IMPORT: --ifconfig/up options modified
Tue Jul 31 20:24:18 2012 OPTIONS IMPORT: route options modified
Tue Jul 31 20:24:18 2012 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Tue Jul 31 20:24:18 2012 ROUTE default_gateway=192.168.2.1
Tue Jul 31 20:24:18 2012 TAP-WIN32 device [Local Area Connection 4] opened: \\.\Global\{606EF6B6-1055-4A65-83BE-E4706F49EFC0}.tap
Tue Jul 31 20:24:18 2012 TAP-Win32 Driver Version 9.9
Tue Jul 31 20:24:18 2012 TAP-Win32 MTU=1500
Tue Jul 31 20:24:18 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.22.218/255.255.255.252 on interface {606EF6B6-1055-4A65-83BE-E4706F49EFC0} [DHCP-serv: 10.4.22.217, lease-time: 31536000]
Tue Jul 31 20:24:18 2012 NOTE: FlushIpNetTable failed on interface [21] {606EF6B6-1055-4A65-83BE-E4706F49EFC0} (status=5) : Access is denied.
Tue Jul 31 20:24:23 2012 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
Tue Jul 31 20:24:23 2012 C:\WINDOWS\system32\route.exe ADD 178.248.29.132 MASK 255.255.255.255 192.168.2.1
Tue Jul 31 20:24:23 2012 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied. [status=5 if_index=18]
Tue Jul 31 20:24:23 2012 Route addition via IPAPI failed [adaptive]
Tue Jul 31 20:24:23 2012 Route addition fallback to route.exe
The requested operation requires elevation.
Tue Jul 31 20:24:23 2012 ERROR: Windows route add command failed [adaptive]: returned error code 1
Tue Jul 31 20:24:23 2012 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.22.217
Tue Jul 31 20:24:23 2012 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied. [status=5 if_index=21]
Tue Jul 31 20:24:23 2012 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.22.217
Tue Jul 31 20:24:23 2012 C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.22.217
Tue Jul 31 20:24:23 2012 Initialization Sequence Completed
