hellosunshine 0 Posted ... Ever since I disconnected 30 minutes ago my login attempts are no longer successful with an error message "AUTH: Received AUTH_FAILED control message". Nothing on my side has changed and I've waited several minutes for a time-out to make sure there is no lingering dirty disconnection. I've also tried connecting as UDP and TCP on ports 80/443 to Vega and Omicron with no avail. What's going on? Tue Jul 03 01:19:33 2012 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 Tue Jul 03 01:19:33 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Tue Jul 03 01:19:33 2012 LZO compression initialized Tue Jul 03 01:19:33 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Tue Jul 03 01:19:33 2012 Socket Buffers: R=[8192->8192] S=[8192->8192] Tue Jul 03 01:19:33 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Tue Jul 03 01:19:33 2012 Local Options hash (VER=V4): '22188c5b' Tue Jul 03 01:19:33 2012 Expected Remote Options hash (VER=V4): 'a8f55717' Tue Jul 03 01:19:33 2012 UDPv4 link local: [undef] Tue Jul 03 01:19:33 2012 UDPv4 link remote: 69.163.36.66:443 Tue Jul 03 01:19:33 2012 TLS: Initial packet from 69.163.36.66:443, sid=d87f5253 92d449d0 Tue Jul 03 01:19:33 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Tue Jul 03 01:19:33 2012 VERIFY OK: nsCertType=SERVER Tue Jul 03 01:19:33 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Tue Jul 03 01:19:34 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Tue Jul 03 01:19:34 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Tue Jul 03 01:19:34 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Tue Jul 03 01:19:34 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Tue Jul 03 01:19:34 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Tue Jul 03 01:19:34 2012 [server] Peer Connection Initiated with 69.163.36.66:443 Tue Jul 03 01:19:36 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Jul 03 01:19:41 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Tue Jul 03 01:19:42 2012 AUTH: Received AUTH_FAILED control message Tue Jul 03 01:19:42 2012 SIGTERM received, sending exit notification to peer Tue Jul 03 01:19:42 2012 AUTH: Received AUTH_FAILED control message Tue Jul 03 01:19:42 2012 TCP/UDP: Closing socket Tue Jul 03 01:19:42 2012 SIGTERM[soft,auth-failure] received, process exiting Quote Share this post Link to post
Staff 10331 Posted ... Hello! Your account is authorized to access all the VPN servers. However, at the time of your attempted connection we had a minor issue with Vega (the server you tried to connect to) which did not affect old connections but prevented new connections to be established. It was solved in 10 minutes, please feel free to let us know if it's all right now for you. Kind regards Quote Share this post Link to post
