Vampire369
inconsistent Speeds With AirVPN
I've been using AirVPN for a few years now and in 2017 when that Windows update came out and screwed up the speeds I've been having problems ever since.  Redone my computer from scratch, updated to latest client, etc.  By fiddling with ports, etc. I can usually get my speeds up to the max they usually can get to, but its always a battle and there seems to be no rhyme not reason to why it won't always get to my max speeds.  When not at max it usually can only get to about 1MB/s.  At my max I usually can get 8 or 9MB/s.
Last month I ordered a month of a competitor and though they don't have as many options in the client it just works at almost my max every single time no fiddling.  I don't have to do any changes, it has worked every time.
Every provider will have thus depending on how busy the sever is.. try a different server AND different port this has always fixed any issues I’ve had
Do you want help with this issue or merely pointing that Windows sux, which we know already. Maybe you're taking a shot at Air? I don't think so since you claim to be using it for 2 years so it must good, right?
If you could be more accurate and perhaps more detailed with the issues you're having we'd be happy to help.
Peace
