Update
i managed to fix the leak by installing the open vpn tap adapter from the website.  i geuss the one thats installed from the Eddie software package is no good????
It is much better to disable WebRTC in your browser: On Firefox go to about:config and set media.peerconnection.enabled to false. On Chrome you have to rely on extensions.
