darkzvpn 0 Posted ... I have the airvpn config files loaded in network manager under ubuntu. Sorry if these are basic questions or are covered elsewhere i tried searching but couldn't find what i was looking for. WIll the airvpn config file through the network manager with gnome plugin tunnel all traffic (for example dns and jabber) through the vpn or do I need to set up that differently. Also I frequently use tor up to this point i just use one at a time. Could domeone explain the benefits and drawbacks of using them together?? Would I need to get a new config file?? Thanks. PS How do I set it up to where if vpn is dropped all connections are dropped would that be a iptables rule or does the client dfo that natively under windows?? Quote Share this post Link to post
Staff 10432 Posted ... I have the airvpn config files loaded in network manager under ubuntu. Sorry if these are basic questions or are covered elsewhere i tried searching but couldn't find what i was looking for. WIll the airvpn config file through the network manager with gnome plugin tunnel all traffic (for example dns and jabber) through the vpn or do I need to set up that differently.Hello!You don't need to configure any program. Our servers will push a routing table which will tunnel everything. Just make sure that you run your applications AFTER you have connected to the VPN.Also I frequently use tor up to this point i just use one at a time. Could domeone explain the benefits and drawbacks of using them together?? Would I need to get a new config file?? Thanks.Please see here:https://airvpn.org/torand here:https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=54&limit=6&limitstart=6&Itemid=142#1745PS How do I set it up to where if vpn is dropped all connections are dropped would that be a iptables rule or does the client dfo that natively under windows??Please see here:https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=1713&Itemid=142Please do not hesitate to contact us for any further information.Kind regards Quote Share this post Link to post
