KingAngel
Can not connect
6/5/2012 - 4:10 PM AirVPN client version: 1.7
6/5/2012 - 4:10 PM Reading options from C:\Users\Admin\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
6/5/2012 - 4:10 PM OpenVPN bundle version: OpenVPN 2.2.2
6/5/2012 - 4:10 PM OpenVPN current version: OpenVPN 2.2.2
6/5/2012 - 4:10 PM Ready.
6/5/2012 - 4:10 PM Login...
6/5/2012 - 4:10 PM Login success.
6/5/2012 - 4:10 PM Contacting service...
6/5/2012 - 4:10 PM Connecting...
6/5/2012 - 4:10 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
6/5/2012 - 4:10 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
6/5/2012 - 4:10 PM LZO compression initialized
6/5/2012 - 4:10 PM Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
6/5/2012 - 4:10 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
6/5/2012 - 4:10 PM Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
6/5/2012 - 4:10 PM Local Options hash (VER=V4): '958c5492'
6/5/2012 - 4:10 PM Expected Remote Options hash (VER=V4): '79ef4284'
6/5/2012 - 4:10 PM Attempting to establish TCP connection with 127.0.0.1:9050
6/5/2012 - 4:10 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
6/5/2012 - 4:11 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
6/5/2012 - 4:12 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
6/5/2012 - 4:13 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
6/5/2012 - 4:14 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
6/5/2012 - 4:15 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
6/5/2012 - 4:15 PM Disconnecting...
6/5/2012 - 4:15 PM Disconnected.
6/5/2012 - 4:15 PM Login...
6/5/2012 - 4:15 PM Login success.
6/5/2012 - 4:15 PM Contacting service...
6/5/2012 - 4:15 PM Connecting...
6/5/2012 - 4:15 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
6/5/2012 - 4:15 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
6/5/2012 - 4:15 PM LZO compression initialized
6/5/2012 - 4:15 PM Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
6/5/2012 - 4:15 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
6/5/2012 - 4:15 PM Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
6/5/2012 - 4:15 PM Local Options hash (VER=V4): '958c5492'
6/5/2012 - 4:15 PM Expected Remote Options hash (VER=V4): '79ef4284'
6/5/2012 - 4:15 PM Attempting to establish TCP connection with 127.0.0.1:9050
Anyone know how to resolve this issue?
6/5/2012 - 4:10 PM
Your local proxy is refusing connections on port 9050.
Please make sure that it is running and accepting connections on port 9050. Also, check whether the proxy type matches the proxy type you selected (OpenVPN supports both http and SOCKS proxies).
You might try a connection without your proxy as well.
