Not connected, Your IP: 216.73.216.63
bobbarker
Forward single program - port? Through Eddie with network lock on
I'd like to forward Sonarr and Radarr through Eddie with network lock on so that I can access them using duckdns outside my local network. Everything works great until I turn on Eddie, then everything fails. Any ideas on how I can forward duckdns (Sonarr and Radarr) only through Eddie?
https://airvpn.org/ports/
Create forwarded ports here.  And you may not need duckdns if you use the DDNS Air provides.
I have a port picked out that forwards through airvpn, but how do I make Caddy use that port? i can't seem to find anything about it online. Maybe I'm missing something simple here? This is how I made Plex available outside my home network but plex had a spot to put the forwarded port into... Caddy doesn't.
When you create a port forward with AirVPN, input the internal port that Caddy uses in the section "local port"
Ok yup, I see that now. I did that - I forwarded both "443" and "2015" through airvpn. Restarted the computer. Still nothing. If I take down AIRVPN it works perfectly, but not with the vpn running. The TCP check on port 443 is showing up as good, but it's failing on port 2015. No idea why.
You cannot forward port 443. Not sure how you did the TCP check, but you normally should
configure only ports that are associated with your account (and then the backend system can know your
internal IP and ports) in your 3d party software.
