Staff 10483 Posted ... Hello!Due to maintenance work in the datacenter, Leonis is temporarily unavailable. You will see it available again as soon as the issue is resolved.If you need a NL server, please use either Castor (1 Gbit/s), Lyra (100 Mbit/s) or Orionis (100 Mbit/s).Kind regardsUPDATE: a router replacement in Leonis switch was successful. Leonis is now fully operational. Quote Share this post Link to post
Drakoblue87079 0 Posted ... I cannot connect to Castor or any other server because the configuration folder is gone. quote: Copy the files from the AirVPN zip file to the configuration directory. It is located at ~/Library/Application Support/Tunnelblick/Configurations I followed above instructions, but the Configuration folder is gone. And when I try to copy something in ~/Library/Application Support/Tunnelblick I get an error message: Files cannot be moved because Tunnelblick can't be modified. This how the Library folder looks like now: ~/Library/Application Support/Tunnelblick/Logs and Shared So where do I copy AirVPN access file now? Or how can I configure Tunnelblick so I can change to another server? And what about this Logs and Shared files. I thought you said no logs... Quote Share this post Link to post
Drakoblue87079 0 Posted ... Okay, I was able to connect. And copy files in Configuration folder. Apparently, there are more than 1 Library folder. Quote Share this post Link to post
