Not connected, Your IP: 216.73.216.54
getnuserz
Client cert and key in Config Generator
Hi, I have a question about Config Generator. It works very nice and is very convenient.
However, when I generate a config, the config file includes fields for <ca>..</ca>, <cert>..</cert>, <key>..</key>.
How does the config generator know the client cert and key values? Where is it taking those values from, are those values being saved somewhere? Isn't that a potential security vulnerability?
Thanks for the support.
The cert and key are individual per each user,  they are saved server side.
Each user has an own ID, and that user has an expiration date of the premium membership.
When your premium subscription is valid, you are eligible to use the config generator. Those
values are individual per each user.
