berryracer
What is "OpenVPN GUI" ??
Hi guys, Im a newbie to AirVPN and I noticed there is a shortcut on my desktop that says "OpenVPN GUI"... what is it for?
I am running AirVPN and it's working fine but I was curious about OpenVPN GUI
OpenVPN GUI is an open source, graphical front-end application for OpenVPN on Windows. It gives you an icon in the system tray from which you can control OpenVPN. Do not try to control OpenVPN simultaneously with the Air client and the OpenVPN GUI, do it either with the first or the latter only. See also our configuration generator (menu "Member Area"->"Access without our client").
