Not connected, Your IP: 34.204.202.44
183aTr78f9o
Arch Linux/Elementary OS/Ubuntu Budgie: Eddie freezes at some point
First, I'd like to say that I've reached AirVPN support about this issue about a month ago. They provided a couple of suggestions (like updating mono for instance) but none of them worked.
Here's what happens: at some point, Eddie window freezes. The VPN connection keeps working fine but Eddie window is completely frozen. It occurs randomly, sometimes after 2 hours, sometimes after longer sessions... I've managed to achieve a 28-hour session without any freeze but most of the time it starts freezing after a few hours only. The only thing I can do when Eddie is frozen is to resize the window, which leads to weird graphical glitches:
I did maybe 6 or 7 clean installs with different Linux distributions: Elementary OS Loki 0.4.1, Ubuntu Budgie 17.10, then Arch Linux. All x64 architecture. MD5/sha256 of my ISOs match the originals, so there's nothing wrong with them.
I'm running latest stable version (2.3.16). Eddie is the only program on my system I'm having issues with. I've been using it on Windows 10 x64 for a year and a half and never had any freeze whatsoever.
I'm getting these freezes regardless of the Eddie variant. I tried to install it via the .deb package, the PPA, I tried to use the portable variant, the portable mono variant (on Elementary OS/Ubuntu Budgie 17.10), I installed Eddie via AUR repository on Arch Linux... one month passed and I'm still getting freezes.
Unfortunately, there's no relevant info in the logs. Eddie stops writting data in the logs once the freeze occurs.
The most annoying part is that I cannot find how to properly kill Eddie without rebooting. I've started using Linux about a month and a half ago, please excuse my lack of knowledge. Clicking on the cross does absolutely nothing since the window is totally frozen. I tried with "xkill" and "sudo kill openvpn" commands in terminal but it's not a proper workaround because when I launch Eddie again, I'm getting "another instance of Eddie is already running" error. There's nothing related to "Eddie" or "AirVPN" or even "OpenVPN" in the System Monitor either, apart from a process called "gksu" but ending or killing it doesn't make any difference.
As I said, The only workaround I found is to restart my machine, which is clearly a PITA considering these freezes happen very often. Eddie is just as stable as an early beta at this point. I'd be grateful if someome could help on this and save me tons of reboots (and time).
I've asked AirVPN support like 5 times if there was a way to kill Eddie without rebooting but they never answered me. They also told me a few days after opening the ticket that they would "try to reproduce the issue on some Elementary OS (note: first Linux distribution I tried) testing machine they will prepare" and that they would "keep me posted". I contacted them several times to know whether they faced the problem on their side, never had an answer either.
They ended up telling me that Eddie v3 GUI would be "completely rewritten" when I told them that I gave up and would wait for Eddie v3.
Pretty bad customer support if you ask me, I'm disappointed. Not quite what you're entitled to expect as a paying customer. Not only the issue isn't fixed but they don't even bother answering my messages. And 0 follow-up regarding their attempt to reproduce the issue on their side. Note that I remained very polite and did my best to fix the issue.
Well, either I'm cursed and cannot get Eddie to work properly on three different Linux distribution or there's something wrong with Eddie... I don't exclude the option that there's something wrong with my system but I highly doubt it's the culprit. As I said, I did several clean installs with different distributions and I'm using a limited amount of software. I'm not getting a single issue with any of them. No issue on Windows 10 x64 either.
Am I the only one having this problem?
Cheers
You should start Eddie via terminal and "sudo airvpn". If Eddie freezes again you will (hopefully) be able to see something in the terminal that could help us/ the support. Depending on your desktop environment there should als be a taskmanager where you can kill a process via a graphical user interface.
There are several ways to kill a running process via command line. You could type in "top". That lists all running processes with additional information. You need the PID of airvpn, for example 1040. You can quit with "q". The command "kill 1040" should close it. If that doesn't work you could try "kill -9 1040".
It helps to read the manual, which is "man kill". I hope that works for you.
Thank you very much for suggesting the "top" command, I finally managed to kill Eddie manually without getting "another instance of Eddie is running".
My desktop environment is Budgie. The graphical System Monitor only lists "gksu" process and killing wouldn't work (I would get "another instance of Eddie is already running" error). However, top lists more processes and that did the trick.
Here's the full list:
Running "sudo kill 12811" ended the VPN connection (Eddie was showing "Reconnecting...") and "sudo kill 1138" killed Eddie. I had to kill "gksu-run-helper" process and not "gksu".  Nice, I won't have to reboot my machine when next freezes occurs.
I'll definitely try to launch Eddie via command line and see if I can get any useful data next time it freezes.
Note that my mono package is up-to-date:
Thank you again for your help, appreciate it.
Eddie crashed when I was away from my computer. It didn't freeze, when I came back, it was just no longer there. I launched it via terminal by running:
sudo airvpn
Here's the Terminal output:
. 2017.11.21 15:38:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pyxis, emailAddress=info@airvpn.org
. 2017.11.21 15:38:29 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.11.21 15:38:29 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.11.21 15:38:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.11.21 15:40:12 - Updating systems & servers data ...
. 2017.11.21 15:40:13 - Systems & servers data update completed
Stacktrace:
/proc/self/maps:
40c2b000-40e23000 rwxp 00000000 00:00 0
40fce000-40fde000 rwxp 00000000 00:00 0
556c0e3b0000-556c0e779000 r-xp 00000000 08:05 1744110                    /usr/bin/mono-sgen
556c0e979000-556c0e97e000 r--p 003c9000 08:05 1744110                    /usr/bin/mono-sgen
556c0e97e000-556c0e980000 rw-p 003ce000 08:05 1744110                    /usr/bin/mono-sgen
556c0e980000-556c0e9b4000 rw-p 00000000 00:00 0
556c1003a000-556c1d075000 rw-p 00000000 00:00 0                          [heap]
7fab4ef7c000-7fab4ef80000 rw-p 00000000 00:00 0
7fab4efc4000-7fab4efc8000 rw-p 00000000 00:00 0
7fab4f00c000-7fab4f014000 rw-p 00000000 00:00 0
7fab4f0c0000-7fab4f0c4000 rw-p 00000000 00:00 0
7fab4f274000-7fab4f278000 rw-p 00000000 00:00 0
7fab4f27c000-7fab4f284000 rw-p 00000000 00:00 0
7fab4f2b8000-7fab4f2bc000 rw-p 00000000 00:00 0
7fab4f2d0000-7fab4f2d4000 rw-p 00000000 00:00 0
7fab4f414000-7fab4f418000 rw-p 00000000 00:00 0
7fab4f500000-7fab4f600000 rw-p 00000000 00:00 0
7fab4f6d4000-7fab4f6d8000 rw-p 00000000 00:00 0
7fab4f724000-7fab4f72c000 rw-p 00000000 00:00 0
7fab4f774000-7fab4f778000 rw-p 00000000 00:00 0
7fab4f7dc000-7fab4f7e0000 rw-p 00000000 00:00 0
7fab4f7e8000-7fab4f7ec000 rw-p 00000000 00:00 0
7fab4f890000-7fab4f894000 rw-p 00000000 00:00 0
7fab4f998000-7fab4f99c000 rw-p 00000000 00:00 0
7fab4f9d0000-7fab4f9d8000 rw-p 00000000 00:00 0
7fab4f9dc000-7fab4f9e0000 rw-p 00000000 00:00 0
7fab4f9e8000-7fab4f9ec000 rw-p 00000000 00:00 0
7fab4fae4000-7fab4fae8000 rw-p 00000000 00:00 0
7fab4fb4c000-7fab4fb50000 rw-p 00000000 00:00 0
7fab4fbf8000-7fab4fbfc000 rw-p 00000000 00:00 0
7fab4fe6c000-7fab4fe70000 rw-p 00000000 00:00 0
7fab4fef4000-7fab4fef8000 rw-p 00000000 00:00 0
7fab4ffc8000-7fab4ffcc000 rw-p 00000000 00:00 0
7fab50020000-7fab50024000 rw-p 00000000 00:00 0
7fab500b4000-7fab500bc000 rw-p 00000000 00:00 0
7fab5015c000-7fab50164000 rw-p 00000000 00:00 0
7fab50264000-7fab50268000 rw-p 00000000 00:00 0
7fab50308000-7fab5030c000 rw-p 00000000 00:00 0
7fab50414000-7fab50418000 rw-p 00000000 00:00 0
7fab5043c000-7fab50440000 rw-p 00000000 00:00 0
7fab5048c000-7fab50490000 rw-p 00000000 00:00 0
7fab504b4000-7fab504b8000 rw-p 00000000 00:00 0
7fab50504000-7fab50508000 rw-p 00000000 00:00 0
7fab505a4000-7fab505a8000 rw-p 00000000 00:00 0
7fab50690000-7fab50694000 rw-p 00000000 00:00 0
7fab5069c000-7fab506a0000 rw-p 00000000 00:00 0
7fab50764000-7fab50768000 rw-p 00000000 00:00 0
7fab507f8000-7fab507fc000 rw-p 00000000 00:00 0
7fab50804000-7fab5080c000 rw-p 00000000 00:00 0
7fab50888000-7fab5088c000 rw-p 00000000 00:00 0
7fab50894000-7fab50898000 rw-p 00000000 00:00 0
7fab50930000-7fab50934000 rw-p 00000000 00:00 0
7fab50938000-7fab5093c000 rw-p 00000000 00:00 0
7fab509d4000-7fab509d8000 rw-p 00000000 00:00 0
7fab50a1c000-7fab50a20000 rw-p 00000000 00:00 0
7fab50a5c000-7fab50a60000 rw-p 00000000 00:00 0
7fab50b4c000-7fab50b50000 rw-p 00000000 00:00 0
7fab50d0c000-7fab50d10000 rw-p 00000000 00:00 0
7fab50d98000-7fab50d9c000 rw-p 00000000 00:00 0
7fab51080000-7fab51084000 rw-p 00000000 00:00 0
7fab51308000-7fab5130c000 rw-p 00000000 00:00 0
7fab51450000-7fab51454000 rw-p 00000000 00:00 0
7fab51640000-7fab51644000 rw-p 00000000 00:00 0
7fab51648000-7fab5164c000 rw-p 00000000 00:00 0
7fab51740000-7fab51744000 rw-p 00000000 00:00 0
7fab51810000-7fab51814000 rw-p 00000000 00:00 0
7fab51958000-7fab5195c000 rw-p 00000000 00:00 0
7fab51974000-7fab51978000 rw-p 00000000 00:00 0
7fab519d4000-7fab519d8000 rw-p 00000000 00:00 0
7fab51a98000-7fab51a9c000 rw-p 00000000 00:00 0
7fab51af4000-7fab51af8000 rw-p 00000000 00:00 0
7fab51d38000-7fab51d3c000 rw-p 00000000 00:00 0
7fab51eb0000-7fab51eb4000 rw-p 00000000 00:00 0
7fab51ff4000-7fab52000000 rw-p 00000000 00:00 0
7fab520a0000-7fab520a4000 rw-p 00000000 00:00 0
7fab520bc000-7fab520c0000 rw-p 00000000 00:00 0
7fab52134000-7fab52138000 rw-p 00000000 00:00 0
7fab52364000-7fab52368000 rw-p 00000000 00:00 0
7fab5239c000-7fab523a0000 rw-p 00000000 00:00 0
7fab52660000-7fab52664000 rw-p 00000000 00:00 0
7fab5271c000-7fab52720000 rw-p 00000000 00:00 0
7fab52770000-7fab52774000 rw-p 00000000 00:00 0
7fab527c8000-7fab527cc000 rw-p 00000000 00:00 0
7fab52908000-7fab5290c000 rw-p 00000000 00:00 0
7fab52958000-7fab5295c000 rw-p 00000000 00:00 0
7fab52960000-7fab52964000 rw-p 00000000 00:00 0
7fab52a10000-7fab52a14000 rw-p 00000000 00:00 0
7fab52bf0000-7fab52c70000 rw-p 00000000 00:00 0
7fab52c74000-7fab52cf4000 rw-p 00000000 00:00 0
7fab52cf8000-7fab52d78000 rw-p 00000000 00:00 0
7fab52d7c000-7fab52d88000 rw-p 00000000 00:00 0
7fab52d90000-7fab52d94000 rw-p 00000000 00:00 0
7fab52dc8000-7fab52e48000 rw-p 00000000 00:00 0
7fab52e4c000-7fab52ecc000 rw-p 00000000 00:00 0
7fab52ed0000-7fab52ed4000 rw-p 00000000 00:00 0
7fab52edc000-7fab52ee0000 rw-p 00000000 00:00 0
7fab52f08000-7fab52f0c000 rw-p 00000000 00:00 0
7fab52f34000-7fab52fb4000 rw-p 00000000 00:00 0
7fab52fb8000-7fab52fbc000 rw-p 00000000 00:00 0
7fab52ff8000-7fab52ffc000 rw-p 00000000 00:00 0
7fab53000000-7fab53080000 rw-p 00000000 00:00 0
7fab53084000-7fab53104000 rw-p 00000000 00:00 0
7fab53108000-7fab53188000 rw-p 00000000 00:00 0
7fab5318c000-7fab53190000 rw-p 00000000 00:00 0
7fab531d0000-7fab53250000 rw-p 00000000 00:00 0
7fab53254000-7fab532d4000 rw-p 00000000 00:00 0
7fab532d8000-7fab53358000 rw-p 00000000 00:00 0
7fab5335c000-7fab533dc000 rw-p 00000000 00:00 0
7fab533e0000-7fab53460000 rw-p 00000000 00:00 0
7fab53464000-7fab534e4000 rw-p 00000000 00:00 0
7fab534e8000-7fab53568000 rw-p 00000000 00:00 0
7fab5356c000-7fab535ec000 rw-p 00000000 00:00 0
7fab535f0000-7fab53670000 rw-p 00000000 00:00 0
7fab53674000-7fab536f4000 rw-p 00000000 00:00 0
7fab536f8000-7fab53778000 rw-p 00000000 00:00 0
7fab5377c000-7fab537fc000 rw-p 00000000 00:00 0
7fab53800000-7fab53880000 rw-p 00000000 00:00 0
7fab53884000-7fab53904000 rw-p 00000000 00:00 0
7fab53908000-7fab53988000 rw-p 00000000 00:00 0
7fab5398c000-7fab53990000 rw-p 00000000 00:00 0
7fab53994000-7fab53998000 rw-p 00000000 00:00 0
7fab539c4000-7fab539c8000 rw-p 00000000 00:00 0
7fab53a08000-7fab53a78000 rw-p 00000000 00:00 0
7fab53a7c000-7fab53ab4000 rw-p 00000000 00:00 0
7fab53b10000-7fab53b90000 rw-p 00000000 00:00 0
7fab53b94000-7fab53c14000 rw-p 00000000 00:00 0
7fab53c18000-7fab53c98000 rw-p 00000000 00:00 0
7fab53c9c000-7fab53ca0000 rw-p 00000000 00:00 0
7fab53ca4000-7fab53ca8000 rw-p 00000000 00:00 0
7fab53cac000-7fab53cb0000 rw-p 00000000 00:00 0
7fab53ce8000-7fab53cec000 rw-p 00000000 00:00 0
7fab53cf4000-7fab53cf8000 rw-p 00000000 00:00 0
7fab53d70000-7fab53d74000 rw-p 00000000 00:00 0
7fab53d98000-7fab53d9c000 rw-p 00000000 00:00 0
7fab53df4000-7fab53df8000 rw-p 00000000 00:00 0
7fab53e38000-7fab53e3c000 rw-p 00000000 00:00 0
7fab53eb4000-7fab53eb8000 rw-p 00000000 00:00 0
7fab53ec4000-7fab53ec8000 rw-p 00000000 00:00 0
7fab53f30000-7fab53f34000 rw-p 00000000 00:00 0
7fab53f4c000-7fab53f50000 rw-p 00000000 00:00 0
7fab53f80000-7fab53f84000 rw-p 00000000 00:00 0
7fab53f94000-7fab53f98000 rw-p 00000000 00:00 0
7fab54000000-7fab54021000 rw-p 00000000 00:00 0
7fab54021000-7fab58000000 ---p 00000000 00:00 0
7fab58000000-7fab58148000 rw-p 00000000 00:00 0
7fab58148000-7fab5c000000 ---p 00000000 00:00 0
7fab5c000000-7fab5c021000 rw-p 00000000 00:00 0
7fab5c021000-7fab60000000 ---p 00000000 00:00 0
7fab60000000-7fab60021000 rw-p 00000000 00:00 0
7fab60021000-7fab64000000 ---p 00000000 00:00 0
7fab64000000-7fab64039000 rw-p 00000000 00:00 0
7fab64039000-7fab68000000 ---p 00000000 00:00 0
7fab68000000-7fab68021000 rw-p 00000000 00:00 0
7fab68021000-7fab6c000000 ---p 00000000 00:00 0
7fab6c000000-7fab6c021000 rw-p 00000000 00:00 0
7fab6c021000-7fab70000000 ---p 00000000 00:00 0
7fab70000000-7fab70021000 rw-p 00000000 00:00 0
7fab70021000-7fab74000000 ---p 00000000 00:00 0
7fab74000000-7fab74021000 rw-p 00000000 00:00 0
7fab74021000-7fab78000000 ---p 00000000 00:00 0
7fab78000000-7fab7802e000 rw-p 00000000 00:00 0
7fab7802e000-7fab7c000000 ---p 00000000 00:00 0
7fab7c000000-7fab7c021000 rw-p 00000000 00:00 0
7fab7c021000-7fab80000000 ---p 00000000 00:00 0
7fab80000000-7fab80021000 rw-p 00000000 00:00 0
7fab80021000-7fab84000000 ---p 00000000 00:00 0
7fab84000000-7fab84027000 rw-p 00000000 00:00 0
7fab84027000-7fab88000000 ---p 00000000 00:00 0
7fab88000000-7fab880d1000 rw-p 00000000 00:00 0
7fab880d1000-7fab8c000000 ---p 00000000 00:00 0
7fab8c000000-7fab8c034000 rw-p 00000000 00:00 0
7fab8c034000-7fab90000000 ---p 00000000 00:00 0
7fab90000000-7fab90021000 rw-p 00000000 00:00 0
7fab90021000-7fab94000000 ---p 00000000 00:00 0
7fab94000000-7fab94157000 rw-p 00000000 00:00 0
7fab94157000-7fab98000000 ---p 00000000 00:00 0
7fab98030000-7fab98034000 rw-p 00000000 00:00 0
7fab98074000-7fab98078000 rw-p 00000000 00:00 0
7fab980ac000-7fab980b0000 rw-p 00000000 00:00 0
7fab98128000-7fab9812c000 rw-p 00000000 00:00 0
7fab98150000-7fab98154000 rw-p 00000000 00:00 0
7fab981ac000-7fab981b0000 rw-p 00000000 00:00 0
7fab981b4000-7fab981b8000 rw-p 00000000 00:00 0
7fab981f8000-7fab981fc000 rw-p 00000000 00:00 0
7fab98234000-7fab98238000 rw-p 00000000 00:00 0
7fab98298000-7fab9829c000 rw-p 00000000 00:00 0
7fab982f4000-7fab982f8000 rw-p 00000000 00:00 0
7fab98330000-7fab98334000 rw-p 00000000 00:00 0
7fab98338000-7fab9833c000 rw-p 00000000 00:00 0
7fab98364000-7fab98368000 rw-p 00000000 00:00 0
7fab9836c000-7fab98370000 rw-p 00000000 00:00 0
7fab983b8000-7fab983bc000 rw-p 00000000 00:00 0
7fab98408000-7fab9840c000 rw-p 00000000 00:00 0
7fab98464000-7fab98468000 rw-p 00000000 00:00 0
7fab9846c000-7fab98470000 rw-p 00000000 00:00 0
7fab98498000-7fab9849c000 rw-p 00000000 00:00 0
7fab984b0000-7fab984b4000 rw-p 00000000 00:00 0
7fab984c8000-7fab984cc000 rw-p 00000000 00:00 0
7fab984d4000-7fab984d8000 rw-p 00000000 00:00 0
7fab98524000-7fab98528000 rw-p 00000000 00:00 0
7fab98558000-7fab9855c000 rw-p 00000000 00:00 0
7fab98560000-7fab98564000 rw-p 00000000 00:00 0
7fab985b4000-7fab985bc000 rw-p 00000000 00:00 0
7fab985c0000-7fab985c4000 rw-p 00000000 00:00 0
7fab98634000-7fab98638000 rw-p 00000000 00:00 0
7fab98688000-7fab9868c000 rw-p 00000000 00:00 0
7fab98690000-7fab9869c000 rw-p 00000000 00:00 0
7fab986b4000-7fab986b8000 rw-p 00000000 00:00 0
7fab986e4000-7fab986e8000 rw-p 00000000 00:00 0
7fab986f0000-7fab986f4000 rw-p 00000000 00:00 0
7fab98748000-7fab9874c000 rw-p 00000000 00:00 0
7fab9879c000-7fab987a4000 rw-p 00000000 00:00 0
7fab987b4000-7fab987b8000 rw-p 00000000 00:00 0
7fab987bc000-7fab987c0000 rw-p 00000000 00:00 0
7fab987f8000-7fab987fc000 rw-p 00000000 00:00 0
7fab98868000-7fab9886c000 rw-p 00000000 00:00 0
7fab988a4000-7fab988a8000 rw-p 00000000 00:00 0
7fab988dc000-7fab988e0000 rw-p 00000000 00:00 0
7fab98958000-7fab9895c000 rw-p 00000000 00:00 0
7fab989b4000-7fab989b8000 rw-p 00000000 00:00 0
7fab989c0000-7fab989c4000 rw-p 00000000 00:00 0
7fab98a34000-7fab98a38000 rw-p 00000000 00:00 0
7fab98a98000-7fab98a9c000 rw-p 00000000 00:00 0
7fab98aa0000-7fab98aa4000 rw-p 00000000 00:00 0
7fab98ab4000-7fab98ab8000 rw-p 00000000 00:00 0
7fab98ac8000-7fab98acc000 rw-p 00000000 00:00 0
7fab98afc000-7fab98b00000 rw-p 00000000 00:00 0
7fab98b24000-7fab98b28000 rw-p 00000000 00:00 0
7fab98b58000-7fab98b5c000 rw-p 00000000 00:00 0
7fab98bb8000-7fab98bbc000 rw-p 00000000 00:00 0
7fab98bdc000-7fab98be0000 rw-p 00000000 00:00 0
7fab98c0c000-7fab98c10000 rw-p 00000000 00:00 0
7fab98c18000-7fab98c1c000 rw-p 00000000 00:00 0
7fab98c48000-7fab98c4c000 rw-p 00000000 00:00 0
7fab98c9c000-7fab98ca0000 rw-p 00000000 00:00 0
7fab98cec000-7fab98cf0000 rw-p 00000000 00:00 0
7fab98d40000-7fab98d44000 rw-p 00000000 00:00 0
7fab98d70000-7fab98d74000 rw-p 00000000 00:00 0
7fab98d7c000-7fab98d80000 rw-p 00000000 00:00 0
7fab98d94000-7fab98d98000 rw-p 00000000 00:00 0
7fab98dd8000-7fab98ddc000 rw-p 00000000 00:00 0
7fab98e5c000-7fab98e60000 rw-p 00000000 00:00 0
7fab98eb0000-7fab98eb4000 rw-p 00000000 00:00 0
7fab98ec0000-7fab98ec4000 rw-p 00000000 00:00 0
7fab98ed4000-7fab98ed8000 rw-p 00000000 00:00 0
7fab98ee8000-7fab98eec000 rw-p 00000000 00:00 0
7fab98efc000-7fab98f00000 rw-p 00000000 00:00 0
7fab98f3c000-7fab98f40000 rw-p 00000000 00:00 0
7fab98f58000-7fab98f5c000 rw-p 00000000 00:00 0
7fab98f70000-7fab98f74000 rw-p 00000000 00:00 0
7fab98f9c000-7fab98fa0000 rw-p 00000000 00:00 0
7fab98fbc000-7fab98fc0000 rw-p 00000000 00:00 0
7fab98ff0000-7fab98ff4000 rw-p 00000000 00:00 0
7fab98ffe000-7fab98fff000 ---p 00000000 00:00 0
7fab98fff000-7fab99007000 ---p 00000000 00:00 0
7fab99007000-7fab991ff000 rw-p 00000000 00:00 0
7fab991ff000-7fab99200000 ---p 00000000 00:00 0
7fab99200000-7fab99400000 rw-p 00000000 00:00 0
7fab99428000-7fab9942c000 rw-p 00000000 00:00 0
7fab9947c000-7fab99480000 rw-p 00000000 00:00 0
7fab99484000-7fab99488000 rw-p 00000000 00:00 0
7fab99498000-7fab9949c000 rw-p 00000000 00:00 0
7fab994d4000-7fab994d8000 rw-p 00000000 00:00 0
7fab99530000-7fab99534000 rw-p 00000000 00:00 0
7fab99538000-7fab9953c000 rw-p 00000000 00:00 0
7fab9957c000-7fab99580000 rw-p 00000000 00:00 0
7fab995d4000-7fab995d8000 rw-p 00000000 00:00 0
7fab995e0000-7fab995e8000 rw-p 00000000 00:00 0
7fab995f8000-7fab995fc000 rw-p 00000000 00:00 0
7fab99634000-7fab99638000 rw-p 00000000 00:00 0
7fab996b0000-7fab996b4000 rw-p 00000000 00:00 0
7fab996b8000-7fab996bc000 rw-p 00000000 00:00 0
7fab996f4000-7fab996f8000 rw-p 00000000 00:00 0
7fab996fc000-7fab99700000 rw-p 00000000 00:00 0
7fab99730000-7fab99734000 rw-p 00000000 00:00 0
7fab99740000-7fab99744000 rw-p 00000000 00:00 0
7fab9978c000-7fab99790000 rw-p 00000000 00:00 0
7fab997bc000-7fab997c0000 rw-p 00000000 00:00 0
7fab997c8000-7fab997d0000 rw-p 00000000 00:00 0
7fab997d8000-7fab997e0000 rw-p 00000000 00:00 0
7fab997f0000-7fab997f4000 rw-p 00000000 00:00 0
7fab997f6000-7fab997f7000 ---p 00000000 00:00 0
7fab997f7000-7fab997ff000 ---p 00000000 00:00 0
7fab997ff000-7fab999f7000 rw-p 00000000 00:00 0
7fab999f7000-7fab999f8000 ---p 00000000 00:00 0
7fab999f8000-7fab99bf8000 rw-p 00000000 00:00 0
7fab99bf8000-7fab99bf9000 ---p 00000000 00:00 0
7fab99bf9000-7fab99df9000 rw-p 00000000 00:00 0
7fab99df9000-7fab99dfa000 ---p 00000000 00:00 0
7fab99dfa000-7fab99ffa000 rw-p 00000000 00:00 0
7fab99ffa000-7fab99ffb000 ---p 00000000 00:00 0
7fab99ffb000-7fab9a1fb000 rw-p 00000000 00:00 0
7fab9a1fb000-7fab9a1fc000 ---p 00000000 00:00 0
7fab9a1fc000-7fab9a3fc000 rw-p 00000000 00:00 0
7fab9a3fc000-7fab9a3fd000 ---p 00000000 00:00 0
7fab9a3fd000-7fab9a405000 ---p 00000000 00:00 0
7fab9a405000-7fab9a5fd000 rw-p 00000000 00:00 0
7fab9a5fd000-7fab9a5fe000 ---p 00000000 00:00 0
7fab9a5fe000-7fab9a606000 ---p 00000000 00:00 0
7fab9a606000-7fab9a7fe000 rw-p 00000000 00:00 0
7fab9a7fe000-7fab9a7ff000 ---p 00000000 00:00 0
7fab9a7ff000-7fab9a807000 ---p 00000000 00:00 0
7fab9a807000-7fab9a9ff000 rw-p 00000000 00:00 0
7fab9a9ff000-7fab9aa00000 ---p 00000000 00:00 0
7fab9aa00000-7fab9aa08000 ---p 00000000 00:00 0
7fab9aa08000-7fab9ad00000 rw-p 00000000 00:00 0
7fab9ad5c000-7fab9ad60000 rw-p 00000000 00:00 0
7fab9adb8000-7fab9adbc000 rw-p 00000000 00:00 0
7fab9ade4000-7fab9adf0000 rw-p 00000000 00:00 0
7fab9adf8000-7fab9adfc000 rw-p 00000000 00:00 0
7fab9ae00000-7fab9b600000 rw-s 00000000 00:05 86868005                   /SYSV00000000 (deleted)
7fab9b600000-7fab9b700000 rw-p 00000000 00:00 0
7fab9b75c000-7fab9b774000 rw-p 00000000 00:00 0
7fab9b77c000-7fab9b780000 rw-p 00000000 00:00 0
7fab9b788000-7fab9b790000 rw-p 00000000 00:00 0
7fab9b7b0000-7fab9b7b4000 rw-p 00000000 00:00 0
7fab9b7b7000-7fab9b7b8000 ---p 00000000 00:00 0
7fab9b7b8000-7fab9b9bc000 rw-p 00000000 00:00 0
7fab9b9d4000-7fab9b9e0000 rw-p 00000000 00:00 0
7fab9ba20000-7fab9ba24000 rw-p 00000000 00:00 0
7fab9ba6c000-7fab9ba70000 rw-p 00000000 00:00 0
7fab9ba84000-7fab9ba90000 rw-p 00000000 00:00 0
7fab9ba98000-7fab9baa0000 rw-p 00000000 00:00 0
7fab9baa8000-7fab9babc000 rw-p 00000000 00:00 0
7fab9babf000-7fab9baff000 r-xp 00000000 08:05 1744074                    /usr/lib/libMonoPosixHelper.so
7fab9baff000-7fab9bcff000 ---p 00040000 08:05 1744074                    /usr/lib/libMonoPosixHelper.so
7fab9bcff000-7fab9bd00000 r--p 00040000 08:05 1744074                    /usr/lib/libMonoPosixHelper.so
7fab9bd00000-7fab9bd01000 rw-p 00041000 08:05 1744074                    /usr/lib/libMonoPosixHelper.so
7fab9bd26000-7fab9bd7a000 r--p 00000000 08:05 2498629                    /usr/share/fonts/TTF/DejaVuSansMono.ttf
7fab9bd7a000-7fab9bd7b000 ---p 00000000 00:00 0
7fab9bd7b000-7fab9bd83000 ---p 00000000 00:00 0
7fab9bd83000-7fab9bf7b000 rw-p 00000000 00:00 0
7fab9bf7b000-7fab9bf7c000 ---p 00000000 00:00 0
7fab9bf7c000-7fab9c1a0000 rw-p 00000000 00:00 0
7fab9c1d0000-7fab9c1d4000 rw-p 00000000 00:00 0
7fab9c1ff000-7fab9c200000 ---p 00000000 00:00 0
7fab9c200000-7fab9c208000 ---p 00000000 00:00 0
7fab9c208000-7fab9c400000 rw-p 00000000 00:00 0
7fab9c460000-7fab9c468000 rw-p 00000000 00:00 0
7fab9c4a0000-7fab9c4a4000 rw-p 00000000 00:00 0
7fab9c4ec000-7fab9c4f0000 rw-p 00000000 00:00 0
7fab9c4f4000-7fab9c4fc000 rw-p 00000000 00:00 0
7fab9c538000-7fab9c540000 rw-p 00000000 00:00 0
7fab9c548000-7fab9c54c000 rw-p 00000000 00:00 0
7fab9c55c000-7fab9c588000 rw-p 00000000 00:00 0
7fab9c5bb000-7fab9c5bc000 ---p 00000000 00:00 0
7fab9c5bc000-7fab9c7bc000 rw-p 00000000 00:00 0
7fab9c7d4000-7fab9c7dc000 rw-p 00000000 00:00 0
7fab9c7ec000-7fab9c7fc000 rw-p 00000000 00:00 0
7fab9c82c000-7fab9c834000 rw-p 00000000 00:00 0
7fab9c844000-7fab9c848000 rw-p 00000000 00:00 0
7fab9c860000-7fab9c868000 rw-p 00000000 00:00 0
7fab9c8e4000-7fab9c8e8000 rw-p 00000000 00:00 0
7fab9c900000-7fab9c904000 rw-p 00000000 00:00 0
7fab9c908000-7fab9c90c000 rw-p 00000000 00:00 0
7fab9c910000-7fab9c914000 rw-p 00000000 00:00 0
7fab9c94c000-7fab9c950000 rw-p 00000000 00:00 0
7fab9c954000-7fab9c958000 rw-p 00000000 00:00 0
7fab9c978000-7fab9c97c000 rw-p 00000000 00:00 0
7fab9c998000-7fab9c9b8000 r-xp 00000000 08:05 1744075                    /usr/lib/libMonoSupportW.so
7fab9c9b8000-7fab9cbb7000 ---p 00020000 08:05 1744075                    /usr/lib/libMonoSupportW.so
7fab9cbb7000-7fab9cbb8000 r--p 0001f000 08:05 1744075                    /usr/lib/libMonoSupportW.so
7fab9cbb8000-7fab9cbb9000 rw-p 00020000 08:05 1744075                    /usr/lib/libMonoSupportW.so
7fab9cbb9000-7fab9cbbe000 r-xp 00000000 08:05 1726936                    /usr/lib/libogg.so.0.8.3
7fab9cbbe000-7fab9cdbe000 ---p 00005000 08:05 1726936                    /usr/lib/libogg.so.0.8.3
7fab9cdbe000-7fab9cdbf000 r--p 00005000 08:05 1726936                    /usr/lib/libogg.so.0.8.3
7fab9cdbf000-7fab9cdc0000 rw-p 00006000 08:05 1726936                    /usr/lib/libogg.so.0.8.3
7fab9cdc0000-7fab9cdeb000 r-xp 00000000 08:05 1726955                    /usr/lib/libvorbis.so.0.4.8
7fab9cdeb000-7fab9cfeb000 ---p 0002b000 08:05 1726955                    /usr/lib/libvorbis.so.0.4.8
7fab9cfeb000-7fab9cfec000 r--p 0002b000 08:05 1726955                    /usr/lib/libvorbis.so.0.4.8
7fab9cfec000-7fab9cfed000 rw-p 0002c000 08:05 1726955                    /usr/lib/libvorbis.so.0.4.8
7fab9cfed000-7fab9cff5000 r-xp 00000000 08:05 1732051                    /usr/lib/libltdl.so.7.3.1
7fab9cff5000-7fab9d1f5000 ---p 00008000 08:05 1732051                    /usr/lib/libltdl.so.7.3.1
7fab9d1f5000-7fab9d1f6000 r--p 00008000 08:05 1732051                    /usr/lib/libltdl.so.7.3.1
7fab9d1f6000-7fab9d1f7000 rw-p 00009000 08:05 1732051                    /usr/lib/libltdl.so.7.3.1
7fab9d1f7000-7fab9d20c000 r-xp 00000000 08:05 1733662                    /usr/lib/libtdb.so.1.3.15
7fab9d20c000-7fab9d40b000 ---p 00015000 08:05 1733662                    /usr/lib/libtdb.so.1.3.15
7fab9d40b000-7fab9d40c000 r--p 00014000 08:05 1733662                    /usr/lib/libtdb.so.1.3.15
7fab9d40c000-7fab9d40d000 rw-p 00015000 08:05 1733662                    /usr/lib/libtdb.so.1.3.15
7fab9d40d000-7fab9d415000 r-xp 00000000 08:05 1726959                    /usr/lib/libvorbisfile.so.3.3.7
7fab9d415000-7fab9d614000 ---p 00008000 08:05 1726959                    /usr/lib/libvorbisfile.so.3.3.7
7fab9d614000-7fab9d615000 r--p 00007000 08:05 1726959                    /usr/lib/libvorbisfile.so.3.3.7
7fab9d615000-7fab9d616000 rw-p 00008000 08:05 1726959                    /usr/lib/libvorbisfile.so.3.3.7
7fab9d616000-7fab9d627000 r-xp 00000000 08:05 1733675                    /usr/lib/libcanberra.so.0.2.5
7fab9d627000-7fab9d826000 ---p 00011000 08:05 1733675                    /usr/lib/libcanberra.so.0.2.5
7fab9d826000-7fab9d827000 r--p 00010000 08:05 1733675                    /usr/lib/libcanberra.so.0.2.5
7fab9d827000-7fab9d828000 rw-p 00011000 08:05 1733675                    /usr/lib/libcanberra.so.0.2.5
7fab9d828000-7fab9d82c000 r-xp 00000000 08:05 1733677                    /usr/lib/libcanberra-gtk.so.0.1.9
7fab9d82c000-7fab9da2b000 ---p 00004000 08:05 1733677                    /usr/lib/libcanberra-gtk.so.0.1.9
7fab9da2b000-7fab9da2c000 r--p 00003000 08:05 1733677                    /usr/lib/libcanberra-gtk.so.0.1.9
7fab9da2c000-7fab9da2d000 rw-p 00004000 08:05 1733677                    /usr/lib/libcanberra-gtk.so.0.1.9
7fab9da2d000-7fab9da32000 r-xp 00000000 08:05 2370430                    /usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so
7fab9da32000-7fab9dc31000 ---p 00005000 08:05 2370430                    /usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so
7fab9dc31000-7fab9dc32000 r--p 00004000 08:05 2370430                    /usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so
7fab9dc32000-7fab9dc33000 rw-p 00005000 08:05 2370430                    /usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so
7fab9dc33000-7fab9dc35000 r-xp 00000000 08:05 2502541                    /usr/lib/gtk-2.0/2.10.0/engines/libadwaita.so
7fab9dc35000-7fab9de34000 ---p 00002000 08:05 2502541                    /usr/lib/gtk-2.0/2.10.0/engines/libadwaita.so
7fab9de34000-7fab9de35000 r--p 00001000 08:05 2502541                    /usr/lib/gtk-2.0/2.10.0/engines/libadwaita.so
7fab9de35000-7fab9de36000 rw-p 00002000 08:05 2502541                    /usr/lib/gtk-2.0/2.10.0/engines/libadwaita.so
7fab9de36000-7fab9de40000 r-xp 00000000 08:05 2509725                    /usr/lib/gtk-2.0/2.10.0/engines/libpixmap.so
7fab9de40000-7fab9e03f000 ---p 0000a000 08:05 2509725                    /usr/lib/gtk-2.0/2.10.0/engines/libpixmap.so
7fab9e03f000-7fab9e040000 r--p 00009000 08:05 2509725                    /usr/lib/gtk-2.0/2.10.0/engines/libpixmap.so
7fab9e040000-7fab9e041000 rw-p 0000a000 08:05 2509725                    /usr/lib/gtk-2.0/2.10.0/engines/libpixmap.so
7fab9e041000-7fab9e048000 r-xp 00000000 08:05 1732944                    /usr/lib/libdatrie.so.1.3.3
7fab9e048000-7fab9e247000 ---p 00007000 08:05 1732944                    /usr/lib/libdatrie.so.1.3.3
7fab9e247000-7fab9e248000 r--p 00006000 08:05 1732944                    /usr/lib/libdatrie.so.1.3.3
7fab9e248000-7fab9e249000 rw-p 00007000 08:05 1732944                    /usr/lib/libdatrie.so.1.3.3
7fab9e249000-7fab9e24f000 r-xp 00000000 08:05 1716403                    /usr/lib/libuuid.so.1.3.0
7fab9e24f000-7fab9e44e000 ---p 00006000 08:05 1716403                    /usr/lib/libuuid.so.1.3.0
7fab9e44e000-7fab9e44f000 r--p 00005000 08:05 1716403                    /usr/lib/libuuid.so.1.3.0
7fab9e44f000-7fab9e450000 rw-p 00006000 08:05 1716403                    /usr/lib/libuuid.so.1.3.0
7fab9e450000-7fab9e497000 r-xp 00000000 08:05 1716405                    /usr/lib/libblkid.so.1.1.0
7fab9e497000-7fab9e696000 ---p 00047000 08:05 1716405                    /usr/lib/libblkid.so.1.1.0
7fab9e696000-7fab9e69b000 r--p 00046000 08:05 1716405                    /usr/lib/libblkid.so.1.1.0
7fab9e69b000-7fab9e69c000 rw-p 0004b000 08:05 1716405                    /usr/lib/libblkid.so.1.1.0
7fab9e69c000-7fab9e69d000 rw-p 00000000 00:00 0
7fab9e69d000-7fab9e6a4000 r-xp 00000000 08:05 1719419                    /usr/lib/libffi.so.6.0.4
7fab9e6a4000-7fab9e8a4000 ---p 00007000 08:05 1719419                    /usr/lib/libffi.so.6.0.4
7fab9e8a4000-7fab9e8a5000 r--p 00007000 08:05 1719419                    /usr/lib/libffi.so.6.0.4
7fab9e8a5000-7fab9e8a6000 rw-p 00008000 08:05 1719419                    /usr/lib/libffi.so.6.0.4
7fab9e8a6000-7fab9e8ae000 r-xp 00000000 08:05 1732952                    /usr/lib/libthai.so.0.3.0
7fab9e8ae000-7fab9eaae000 ---p 00008000 08:05 1732952                    /usr/lib/libthai.so.0.3.0
7fab9eaae000-7fab9eaaf000 r--p 00008000 08:05 1732952                    /usr/lib/libthai.so.0.3.0
7fab9eaaf000-7fab9eab0000 rw-p 00009000 08:05 1732952                    /usr/lib/libthai.so.0.3.0
7fab9eab0000-7fab9eac3000 r-xp 00000000 08:05 1706103                    /usr/lib/libresolv-2.26.so
7fab9eac3000-7fab9ecc3000 ---p 00013000 08:05 1706103                    /usr/lib/libresolv-2.26.so
7fab9ecc3000-7fab9ecc4000 r--p 00013000 08:05 1706103                    /usr/lib/libresolv-2.26.so
7fab9ecc4000-7fab9ecc5000 rw-p 00014000 08:05 1706103                    /usr/lib/libresolv-2.26.so
7fab9ecc5000-7fab9ecc7000 rw-p 00000000 00:00 0
7fab9ecc7000-7fab9ed19000 r-xp 00000000 08:05 1716411                    /usr/lib/libmount.so.1.1.0
7fab9ed19000-7fab9ef18000 ---p 00052000 08:05 1716411                    /usr/lib/libmount.so.1.1.0
7fab9ef18000-7fab9ef1b000 r--p 00051000 08:05 1716411                    /usr/lib/libmount.so.1.1.0
7fab9ef1b000-7fab9ef1c000 rw-p 00054000 08:05 1716411                    /usr/lib/libmount.so.1.1.0
7fab9ef1c000-7fab9ef1d000 rw-p 00000000 00:00 0
7fab9ef1d000-7fab9ef1f000 r-xp 00000000 08:05 1732942                    /usr/lib/libXdamage.so.1.1.0
7fab9ef1f000-7fab9f11e000 ---p 00002000 08:05 1732942                    /usr/lib/libXdamage.so.1.1.0
7fab9f11e000-7fab9f11f000 r--p 00001000 08:05 1732942                    /usr/lib/libXdamage.so.1.1.0
7fab9f11f000-7fab9f120000 rw-p 00002000 08:05 1732942                    /usr/lib/libXdamage.so.1.1.0
7fab9f120000-7fab9f122000 r-xp 00000000 08:05 1732935                    /usr/lib/libXcomposite.so.1.0.0
7fab9f122000-7fab9f321000 ---p 00002000 08:05 1732935                    /usr/lib/libXcomposite.so.1.0.0
7fab9f321000-7fab9f322000 r--p 00001000 08:05 1732935                    /usr/lib/libXcomposite.so.1.0.0
7fab9f322000-7fab9f323000 rw-p 00002000 08:05 1732935                    /usr/lib/libXcomposite.so.1.0.0
7fab9f323000-7fab9f32d000 r-xp 00000000 08:05 1732799                    /usr/lib/libXcursor.so.1.0.2
7fab9f32d000-7fab9f52c000 ---p 0000a000 08:05 1732799                    /usr/lib/libXcursor.so.1.0.2
7fab9f52c000-7fab9f52d000 r--p 00009000 08:05 1732799                    /usr/lib/libXcursor.so.1.0.2
7fab9f52d000-7fab9f52e000 rw-p 0000a000 08:05 1732799                    /usr/lib/libXcursor.so.1.0.2
7fab9f52e000-7fab9f538000 r-xp 00000000 08:05 1732812                    /usr/lib/libXrandr.so.2.2.0
7fab9f538000-7fab9f737000 ---p 0000a000 08:05 1732812                    /usr/lib/libXrandr.so.2.2.0
7fab9f737000-7fab9f738000 r--p 00009000 08:05 1732812                    /usr/lib/libXrandr.so.2.2.0
7fab9f738000-7fab9f739000 rw-p 0000a000 08:05 1732812                    /usr/lib/libXrandr.so.2.2.0
7fab9f739000-7fab9f748000 r-xp 00000000 08:05 1732905                    /usr/lib/libXi.so.6.1.0
7fab9f748000-7fab9f948000 ---p 0000f000 08:05 1732905                    /usr/lib/libXi.so.6.1.0
7fab9f948000-7fab9f949000 r--p 0000f000 08:05 1732905                    /usr/lib/libXi.so.6.1.0
7fab9f949000-7fab9f94a000 rw-p 00010000 08:05 1732905                    /usr/lib/libXi.so.6.1.0
7fab9f94a000-7fab9f94c000 r-xp 00000000 08:05 1732802                    /usr/lib/libXinerama.so.1.0.0
7fab9f94c000-7fab9fb4b000 ---p 00002000 08:05 1732802                    /usr/lib/libXinerama.so.1.0.0
7fab9fb4b000-7fab9fb4c000 r--p 00001000 08:05 1732802                    /usr/lib/libXinerama.so.1.0.0
7fab9fb4c000-7fab9fb4d000 rw-p 00002000 08:05 1732802                    /usr/lib/libXinerama.so.1.0.0
7fab9fb4d000-7fab9fba1000 r-xp 00000000 08:05 1719422                    /usr/lib/libgobject-2.0.so.0.5400.0
7fab9fba1000-7fab9fda0000 ---p 00054000 08:05 1719422                    /usr/lib/libgobject-2.0.so.0.5400.0
7fab9fda0000-7fab9fda2000 r--p 00053000 08:05 1719422                    /usr/lib/libgobject-2.0.so.0.5400.0
7fab9fda2000-7fab9fda3000 rw-p 00055000 08:05 1719422                    /usr/lib/libgobject-2.0.so.0.5400.0
7fab9fda3000-7fab9fdef000 r-xp 00000000 08:05 1732961                    /usr/lib/libpango-1.0.so.0.4000.13
7fab9fdef000-7fab9ffee000 ---p 0004c000 08:05 1732961                    /usr/lib/libpango-1.0.so.0.4000.13
7fab9ffee000-7fab9fff1000 r--p 0004b000 08:05 1732961                    /usr/lib/libpango-1.0.so.0.4000.13
7fab9fff1000-7fab9fff2000 rw-p 0004e000 08:05 1732961                    /usr/lib/libpango-1.0.so.0.4000.13
7fab9fff2000-7faba0005000 r-xp 00000000 08:05 1732962                    /usr/lib/libpangoft2-1.0.so.0.4000.13
7faba0005000-7faba0204000 ---p 00013000 08:05 1732962                    /usr/lib/libpangoft2-1.0.so.0.4000.13
7faba0204000-7faba0205000 r--p 00012000 08:05 1732962                    /usr/lib/libpangoft2-1.0.so.0.4000.13
7faba0205000-7faba0206000 rw-p 00013000 08:05 1732962                    /usr/lib/libpangoft2-1.0.so.0.4000.13
7faba0206000-7faba03a5000 r-xp 00000000 08:05 1719425                    /usr/lib/libgio-2.0.so.0.5400.0
7faba03a5000-7faba05a5000 ---p 0019f000 08:05 1719425                    /usr/lib/libgio-2.0.so.0.5400.0
7faba05a5000-7faba05ae000 r--p 0019f000 08:05 1719425                    /usr/lib/libgio-2.0.so.0.5400.0
7faba05ae000-7faba05af000 rw-p 001a8000 08:05 1719425                    /usr/lib/libgio-2.0.so.0.5400.0
7faba05af000-7faba05b0000 rw-p 00000000 00:00 0
7faba05b0000-7faba05d3000 r-xp 00000000 08:05 1730568                    /usr/lib/libgdk_pixbuf-2.0.so.0.3600.10
7faba05d3000-7faba07d2000 ---p 00023000 08:05 1730568                    /usr/lib/libgdk_pixbuf-2.0.so.0.3600.10
7faba07d2000-7faba07d3000 r--p 00022000 08:05 1730568                    /usr/lib/libgdk_pixbuf-2.0.so.0.3600.10
7faba07d3000-7faba07d4000 rw-p 00023000 08:05 1730568                    /usr/lib/libgdk_pixbuf-2.0.so.0.3600.10
7faba07d4000-7faba07f7000 r-xp 00000000 08:05 1732363                    /usr/lib/libatk-1.0.so.0.22610.1
7faba07f7000-7faba09f6000 ---p 00023000 08:05 1732363                    /usr/lib/libatk-1.0.so.0.22610.1
7faba09f6000-7faba09f9000 r--p 00022000 08:05 1732363                    /usr/lib/libatk-1.0.so.0.22610.1
7faba09f9000-7faba09fa000 rw-p 00025000 08:05 1732363                    /usr/lib/libatk-1.0.so.0.22610.1
7faba09fa000-7faba09ff000 r-xp 00000000 08:05 1732760                    /usr/lib/libXfixes.so.3.1.0
7faba09ff000-7faba0bfe000 ---p 00005000 08:05 1732760                    /usr/lib/libXfixes.so.3.1.0
7faba0bfe000-7faba0bff000 r--p 00004000 08:05 1732760                    /usr/lib/libXfixes.so.3.1.0
7faba0bff000-7faba0c00000 rw-p 00005000 08:05 1732760                    /usr/lib/libXfixes.so.3.1.0
7faba0c00000-7faba0c0c000 r-xp 00000000 08:05 1732964                    /usr/lib/libpangocairo-1.0.so.0.4000.13
7faba0c0c000-7faba0e0b000 ---p 0000c000 08:05 1732964                    /usr/lib/libpangocairo-1.0.so.0.4000.13
7faba0e0b000-7faba0e0c000 r--p 0000b000 08:05 1732964                    /usr/lib/libpangocairo-1.0.so.0.4000.13
7faba0e0c000-7faba0e0d000 rw-p 0000c000 08:05 1732964                    /usr/lib/libpangocairo-1.0.so.0.4000.13
7faba0e0d000-7faba0e10000 r-xp 00000000 08:05 1719424                    /usr/lib/libgmodule-2.0.so.0.5400.0
7faba0e10000-7faba100f000 ---p 00003000 08:05 1719424                    /usr/lib/libgmodule-2.0.so.0.5400.0
7faba100f000-7faba1010000 r--p 00002000 08:05 1719424                    /usr/lib/libgmodule-2.0.so.0.5400.0
7faba1010000-7faba1011000 rw-p 00003000 08:05 1719424                    /usr/lib/libgmodule-2.0.so.0.5400.0
7faba1011000-7faba10c1000 r-xp 00000000 08:05 1743835                    /usr/lib/libgdk-x11-2.0.so.0.2400.31
7faba10c1000-7faba12c0000 ---p 000b0000 08:05 1743835                    /usr/lib/libgdk-x11-2.0.so.0.2400.31
7faba12c0000-7faba12c4000 r--p 000af000 08:05 1743835                    /usr/lib/libgdk-x11-2.0.so.0.2400.31
7faba12c4000-7faba12c6000 rw-p 000b3000 08:05 1743835                    /usr/lib/libgdk-x11-2.0.so.0.2400.31
7faba12c6000-7faba16f9000 r-xp 00000000 08:05 1743836                    /usr/lib/libgtk-x11-2.0.so.0.2400.31
7faba16f9000-7faba18f8000 ---p 00433000 08:05 1743836                    /usr/lib/libgtk-x11-2.0.so.0.2400.31
7faba18f8000-7faba18ff000 r--p 00432000 08:05 1743836                    /usr/lib/libgtk-x11-2.0.so.0.2400.31
7faba18ff000-7faba1903000 rw-p 00439000 08:05 1743836                    /usr/lib/libgtk-x11-2.0.so.0.2400.31
7faba1903000-7faba1906000 rw-p 00000000 00:00 0
7faba1906000-7faba197a000 rw-p 00000000 00:00 0
7faba1990000-7faba1997000 rw-p 00000000 00:00 0
7faba199b000-7faba1a54000 r--p 00000000 08:05 2498637                    /usr/share/fonts/TTF/DejaVuSans.ttf
7faba1a54000-7faba1a98000 rw-p 00000000 00:00 0
7faba1aa0000-7faba1aa4000 rw-p 00000000 00:00 0
7faba1aac000-7faba1abc000 rw-p 00000000 00:00 0
7faba1ac4000-7faba1b58000 rw-p 00000000 00:00 0
7faba1b5c000-7faba1b9c000 rw-p 00000000 00:00 0
7faba1ba4000-7faba1bb4000 rw-p 00000000 00:00 0
7faba1bbc000-7faba1bc0000 rw-p 00000000 00:00 0
7faba1bc8000-7faba1bdc000 rw-p 00000000 00:00 0
7faba1bf8000-7faba1bfc000 rw-p 00000000 00:00 0
7faba1c04000-7faba1c2c000 rw-p 00000000 00:00 0
7faba1c34000-7faba1c3c000 rw-p 00000000 00:00 0
7faba1c44000-7faba1c4c000 rw-p 00000000 00:00 0
7faba1c5c000-7faba1c60000 rw-p 00000000 00:00 0
7faba1c74000-7faba1c78000 rw-p 00000000 00:00 0
7faba1c7a000-7faba1c7b000 rw-p 00000000 00:00 0
7faba1ca8000-7faba1ce4000 rw-p 00000000 00:00 0
7faba1ce8000-7faba1d68000 rw-p 00000000 00:00 0
7faba1d6c000-7faba1d7c000 rw-p 00000000 00:00 0
7faba1d80000-7faba1d88000 rw-p 00000000 00:00 0
7faba1d90000-7faba1d94000 rw-p 00000000 00:00 0
7faba1d95000-7faba1d9b000 rw-p 00000000 00:00 0
7faba1d9c000-7faba1d9e000 rw-p 00000000 00:00 0
7faba1d9f000-7faba1da0000 rw-p 00000000 00:00 0
7faba1da1000-7faba1da9000 rw-p 00000000 00:00 0
7faba1daa000-7faba1dee000 rw-p 00000000 00:00 0
7faba1dee000-7faba1df9000 r-xp 00000000 08:05 1706110                    /usr/lib/libnss_files-2.26.so
7faba1df9000-7faba1ff8000 ---p 0000b000 08:05 1706110                    /usr/lib/libnss_files-2.26.so
7faba1ff8000-7faba1ff9000 r--p 0000a000 08:05 1706110                    /usr/lib/libnss_files-2.26.so
7faba1ff9000-7faba1ffa000 rw-p 0000b000 08:05 1706110                    /usr/lib/libnss_files-2.26.so
7faba1ffa000-7faba2101000 rw-p 00000000 00:00 0
7faba2101000-7faba210e000 rw-p 00000000 00:00 0
7faba210e000-7faba211e000 rwxp 00000000 00:00 0
7faba211e000-7faba2147000 r-xp 00000000 08:05 1847275                    /usr/lib/AirVPN/libLib.Platform.Linux.Native.so
7faba2147000-7faba2347000 ---p 00029000 08:05 1847275                    /usr/lib/AirVPN/libLib.Platform.Linux.Native.so
7faba2347000-7faba2349000 r--p 00029000 08:05 1847275                    /usr/lib/AirVPN/libLib.Platform.Linux.Native.so
7faba2349000-7faba234a000 rw-p 0002b000 08:05 1847275                    /usr/lib/AirVPN/libLib.Platform.Linux.Native.so
7faba234a000-7faba235c000 rw-p 00000000 00:00 0
7faba235c000-7faba2386000 r-xp 00000000 08:05 1732478                    /usr/lib/libgraphite2.so.3.0.1
7faba2386000-7faba2585000 ---p 0002a000 08:05 1732478                    /usr/lib/libgraphite2.so.3.0.1
7faba2585000-7faba2587000 r--p 00029000 08:05 1732478                    /usr/lib/libgraphite2.so.3.0.1
7faba2587000-7faba2588000 rw-p 0002b000 08:05 1732478                    /usr/lib/libgraphite2.so.3.0.1
7faba2588000-7faba258d000 r-xp 00000000 08:05 1727254                    /usr/lib/libXdmcp.so.6.0.0
7faba258d000-7faba278c000 ---p 00005000 08:05 1727254                    /usr/lib/libXdmcp.so.6.0.0
7faba278c000-7faba278d000 r--p 00004000 08:05 1727254                    /usr/lib/libXdmcp.so.6.0.0
7faba278d000-7faba278e000 rw-p 00005000 08:05 1727254                    /usr/lib/libXdmcp.so.6.0.0
7faba278e000-7faba2790000 r-xp 00000000 08:05 1727259                    /usr/lib/libXau.so.6.0.0
7faba2790000-7faba2990000 ---p 00002000 08:05 1727259                    /usr/lib/libXau.so.6.0.0
7faba2990000-7faba2991000 r--p 00002000 08:05 1727259                    /usr/lib/libXau.so.6.0.0
7faba2991000-7faba2992000 rw-p 00003000 08:05 1727259                    /usr/lib/libXau.so.6.0.0
7faba2992000-7faba29c1000 r-xp 00000000 08:05 1716446                    /usr/lib/libexpat.so.1.6.6
7faba29c1000-7faba2bc0000 ---p 0002f000 08:05 1716446                    /usr/lib/libexpat.so.1.6.6
7faba2bc0000-7faba2bc3000 r--p 0002e000 08:05 1716446                    /usr/lib/libexpat.so.1.6.6
7faba2bc3000-7faba2bc4000 rw-p 00031000 08:05 1716446                    /usr/lib/libexpat.so.1.6.6
7faba2bc4000-7faba2be9000 r-xp 00000000 08:05 1716283                    /usr/lib/liblzma.so.5.2.3
7faba2be9000-7faba2de8000 ---p 00025000 08:05 1716283                    /usr/lib/liblzma.so.5.2.3
7faba2de8000-7faba2de9000 r--p 00024000 08:05 1716283                    /usr/lib/liblzma.so.5.2.3
7faba2de9000-7faba2dea000 rw-p 00025000 08:05 1716283                    /usr/lib/liblzma.so.5.2.3
7faba2dea000-7faba2e86000 r-xp 00000000 08:05 1732483                    /usr/lib/libharfbuzz.so.0.10701.0
7faba2e86000-7faba3085000 ---p 0009c000 08:05 1732483                    /usr/lib/libharfbuzz.so.0.10701.0
7faba3085000-7faba3087000 r--p 0009b000 08:05 1732483                    /usr/lib/libharfbuzz.so.0.10701.0
7faba3087000-7faba3088000 rw-p 0009d000 08:05 1732483                    /usr/lib/libharfbuzz.so.0.10701.0
7faba3088000-7faba3097000 r-xp 00000000 08:05 1710652                    /usr/lib/libbz2.so.1.0.6
7faba3097000-7faba3296000 ---p 0000f000 08:05 1710652                    /usr/lib/libbz2.so.1.0.6
7faba3296000-7faba3297000 r--p 0000e000 08:05 1710652                    /usr/lib/libbz2.so.1.0.6
7faba3297000-7faba3298000 rw-p 0000f000 08:05 1710652                    /usr/lib/libbz2.so.1.0.6
7faba3298000-7faba32a9000 r-xp 00000000 08:05 1732474                    /usr/lib/libXext.so.6.4.0
7faba32a9000-7faba34a8000 ---p 00011000 08:05 1732474                    /usr/lib/libXext.so.6.4.0
7faba34a8000-7faba34a9000 r--p 00010000 08:05 1732474                    /usr/lib/libXext.so.6.4.0
7faba34a9000-7faba34aa000 rw-p 00011000 08:05 1732474                    /usr/lib/libXext.so.6.4.0
7faba34aa000-7faba34b6000 r-xp 00000000 08:05 1727330                    /usr/lib/libxcb-render.so.0.0.0
7faba34b6000-7faba36b6000 ---p 0000c000 08:05 1727330                    /usr/lib/libxcb-render.so.0.0.0
7faba36b6000-7faba36b7000 r--p 0000c000 08:05 1727330                    /usr/lib/libxcb-render.so.0.0.0
7faba36b7000-7faba36b8000 rw-p 0000d000 08:05 1727330                    /usr/lib/libxcb-render.so.0.0.0
7faba36b8000-7faba36e0000 r-xp 00000000 08:05 1727320                    /usr/lib/libxcb.so.1.1.0
7faba36e0000-7faba38df000 ---p 00028000 08:05 1727320                    /usr/lib/libxcb.so.1.1.0
7faba38df000-7faba38e0000 r--p 00027000 08:05 1727320                    /usr/lib/libxcb.so.1.1.0
7faba38e0000-7faba38e1000 rw-p 00028000 08:05 1727320                    /usr/lib/libxcb.so.1.1.0
7faba38e1000-7faba38e3000 r-xp 00000000 08:05 1727334                    /usr/lib/libxcb-shm.so.0.0.0
7faba38e3000-7faba3ae3000 ---p 00002000 08:05 1727334                    /usr/lib/libxcb-shm.so.0.0.0
7faba3ae3000-7faba3ae4000 r--p 00002000 08:05 1727334                    /usr/lib/libxcb-shm.so.0.0.0
7faba3ae4000-7faba3ae5000 rw-p 00003000 08:05 1727334                    /usr/lib/libxcb-shm.so.0.0.0
7faba3ae5000-7faba3b84000 r-xp 00000000 08:05 1732721                    /usr/lib/libpixman-1.so.0.34.0
7faba3b84000-7faba3d84000 ---p 0009f000 08:05 1732721                    /usr/lib/libpixman-1.so.0.34.0
7faba3d84000-7faba3d8c000 r--p 0009f000 08:05 1732721                    /usr/lib/libpixman-1.so.0.34.0
7faba3d8c000-7faba3d8d000 rw-p 000a7000 08:05 1732721                    /usr/lib/libpixman-1.so.0.34.0
7faba3d8d000-7faba3dfe000 r-xp 00000000 08:05 1719290                    /usr/lib/libpcre.so.1.2.9
7faba3dfe000-7faba3ffe000 ---p 00071000 08:05 1719290                    /usr/lib/libpcre.so.1.2.9
7faba3ffe000-7faba3fff000 r--p 00071000 08:05 1719290                    /usr/lib/libpcre.so.1.2.9
7faba3fff000-7faba4000000 rw-p 00072000 08:05 1719290                    /usr/lib/libpcre.so.1.2.9
7faba4000000-7faba53c6000 rw-p 00000000 00:00 0
7faba53c6000-7faba8000000 ---p 00000000 00:00 0
7faba8000000-7faba8005000 rw-p 00000000 00:00 0
7faba8005000-7faba8016000 r--p 00000000 08:05 2496577                    /usr/share/fonts/cantarell/Cantarell-Regular.otf
7faba8016000-7faba8036000 rwxp 00000000 00:00 0
7faba8036000-7faba8083000 r--p 00000000 08:05 3803076                    /usr/lib/mono/gac/Mono.Security/4.0.0.0__0738eb9f132ed756/Mono.Security.dll
7faba8083000-7faba80a1000 r--p 00000000 08:05 3803097                    /usr/lib/mono/gac/System.Configuration/4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
7faba80a1000-7faba80d5000 r--p 00000000 08:05 3803088                    /usr/lib/mono/gac/Mono.Posix/4.0.0.0__0738eb9f132ed756/Mono.Posix.dll
7faba80d5000-7faba8113000 r-xp 00000000 08:05 1732718                    /usr/lib/libfontconfig.so.1.10.1
7faba8113000-7faba8313000 ---p 0003e000 08:05 1732718                    /usr/lib/libfontconfig.so.1.10.1
7faba8313000-7faba8315000 r--p 0003e000 08:05 1732718                    /usr/lib/libfontconfig.so.1.10.1
7faba8315000-7faba831a000 rw-p 00040000 08:05 1732718                    /usr/lib/libfontconfig.so.1.10.1
7faba831a000-7faba834c000 r-xp 00000000 08:05 1736289                    /usr/lib/libexif.so.12.3.3
7faba834c000-7faba854b000 ---p 00032000 08:05 1736289                    /usr/lib/libexif.so.12.3.3
7faba854b000-7faba855e000 r--p 00031000 08:05 1736289                    /usr/lib/libexif.so.12.3.3
7faba855e000-7faba855f000 rw-p 00044000 08:05 1736289                    /usr/lib/libexif.so.12.3.3
7faba855f000-7faba8575000 r-xp 00000000 08:05 1716708                    /usr/lib/libz.so.1.2.11
7faba8575000-7faba8774000 ---p 00016000 08:05 1716708                    /usr/lib/libz.so.1.2.11
7faba8774000-7faba8775000 r--p 00015000 08:05 1716708                    /usr/lib/libz.so.1.2.11
7faba8775000-7faba8776000 rw-p 00016000 08:05 1716708                    /usr/lib/libz.so.1.2.11
7faba8776000-7faba87ab000 r-xp 00000000 08:05 1727099                    /usr/lib/libpng16.so.16.34.0
7faba87ab000-7faba89aa000 ---p 00035000 08:05 1727099                    /usr/lib/libpng16.so.16.34.0
7faba89aa000-7faba89ab000 r--p 00034000 08:05 1727099                    /usr/lib/libpng16.so.16.34.0
7faba89ab000-7faba89ac000 rw-p 00035000 08:05 1727099                    /usr/lib/libpng16.so.16.34.0
7faba89ac000-7faba89b4000 r-xp 00000000 08:05 1735895                    /usr/lib/libgif.so.7.0.0
7faba89b4000-7faba8bb4000 ---p 00008000 08:05 1735895                    /usr/lib/libgif.so.7.0.0
7faba8bb4000-7faba8bb5000 r--p 00008000 08:05 1735895                    /usr/lib/libgif.so.7.0.0
7faba8bb5000-7faba8bb6000 rw-p 00009000 08:05 1735895                    /usr/lib/libgif.so.7.0.0
7faba8bb6000-7faba8c35000 r-xp 00000000 08:05 1727135                    /usr/lib/libtiff.so.5.2.6
7faba8c35000-7faba8e35000 ---p 0007f000 08:05 1727135                    /usr/lib/libtiff.so.5.2.6
7faba8e35000-7faba8e39000 r--p 0007f000 08:05 1727135                    /usr/lib/libtiff.so.5.2.6
7faba8e39000-7faba8e3c000 rw-p 00083000 08:05 1727135                    /usr/lib/libtiff.so.5.2.6
7faba8e3c000-7faba8e3d000 rw-p 00000000 00:00 0
7faba8e3d000-7faba8ea4000 r-xp 00000000 08:05 1727110                    /usr/lib/libjpeg.so.8.1.2
7faba8ea4000-7faba90a4000 ---p 00067000 08:05 1727110                    /usr/lib/libjpeg.so.8.1.2
7faba90a4000-7faba90a5000 r--p 00067000 08:05 1727110                    /usr/lib/libjpeg.so.8.1.2
7faba90a5000-7faba90a6000 rw-p 00068000 08:05 1727110                    /usr/lib/libjpeg.so.8.1.2
7faba90a6000-7faba91df000 r-xp 00000000 08:05 1730476                    /usr/lib/libX11.so.6.3.0
7faba91df000-7faba93df000 ---p 00139000 08:05 1730476                    /usr/lib/libX11.so.6.3.0
7faba93df000-7faba93e0000 r--p 00139000 08:05 1730476                    /usr/lib/libX11.so.6.3.0
7faba93e0000-7faba93e5000 rw-p 0013a000 08:05 1730476                    /usr/lib/libX11.so.6.3.0
7faba93e5000-7faba93ee000 r-xp 00000000 08:05 1732407                    /usr/lib/libXrender.so.1.3.0
7faba93ee000-7faba95ee000 ---p 00009000 08:05 1732407                    /usr/lib/libXrender.so.1.3.0
7faba95ee000-7faba95ef000 r--p 00009000 08:05 1732407                    /usr/lib/libXrender.so.1.3.0
7faba95ef000-7faba95f0000 rw-p 0000a000 08:05 1732407                    /usr/lib/libXrender.so.1.3.0
7faba95f0000-7faba96ae000 r-xp 00000000 08:05 1732493                    /usr/lib/libfreetype.so.6.15.0
7faba96ae000-7faba98ae000 ---p 000be000 08:05 1732493                    /usr/lib/libfreetype.so.6.15.0
7faba98ae000-7faba98b5000 r--p 000be000 08:05 1732493                    /usr/lib/libfreetype.so.6.15.0
7faba98b5000-7faba98b6000 rw-p 000c5000 08:05 1732493                    /usr/lib/libfreetype.so.6.15.0
7faba98b6000-7faba99cf000 r-xp 00000000 08:05 1732730                    /usr/lib/libcairo.so.2.11508.0
7faba99cf000-7faba9bce000 ---p 00119000 08:05 1732730                    /usr/lib/libcairo.so.2.11508.0
7faba9bce000-7faba9bd2000 r--p 00118000 08:05 1732730                    /usr/lib/libcairo.so.2.11508.0
7faba9bd2000-7faba9bd3000 rw-p 0011c000 08:05 1732730                    /usr/lib/libcairo.so.2.11508.0
7faba9bd3000-7faba9bd4000 rw-p 00000000 00:00 0
7faba9bd4000-7faba9cef000 r-xp 00000000 08:05 1719421                    /usr/lib/libglib-2.0.so.0.5400.0
7faba9cef000-7faba9eee000 ---p 0011b000 08:05 1719421                    /usr/lib/libglib-2.0.so.0.5400.0
7faba9eee000-7faba9ef1000 r--p 0011a000 08:05 1719421                    /usr/lib/libglib-2.0.so.0.5400.0
7faba9ef1000-7faba9ef2000 rw-p 0011d000 08:05 1719421                    /usr/lib/libglib-2.0.so.0.5400.0
7faba9ef2000-7faba9ef4000 rw-p 00000000 00:00 0
7faba9ef4000-7faba9f01000 rw-p 00000000 00:00 0
7faba9f01000-7faba9f24000 r--s 00000000 08:05 2626895                    /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-le64.cache-7
7faba9f24000-7faba9f88000 r-xp 00000000 08:05 1743996                    /usr/lib/libgdiplus.so.0.0.0
7faba9f88000-7fabaa187000 ---p 00064000 08:05 1743996                    /usr/lib/libgdiplus.so.0.0.0
7fabaa187000-7fabaa189000 r--p 00063000 08:05 1743996                    /usr/lib/libgdiplus.so.0.0.0
7fabaa189000-7fabaa18a000 rw-p 00065000 08:05 1743996                    /usr/lib/libgdiplus.so.0.0.0
7fabaa18a000-7fabaa1ec000 r--p 00000000 08:05 3803106                    /usr/lib/mono/gac/System.Drawing/4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
7fabaa1ec000-7fabaa4ef000 r--p 00000000 08:05 3803082                    /usr/lib/mono/gac/System.Xml/4.0.0.0__b77a5c561934e089/System.Xml.dll
7fabaa4ef000-7fabaa77a000 r--p 00000000 08:05 3803079                    /usr/lib/mono/gac/System/4.0.0.0__b77a5c561934e089/System.dll
7fabaa77a000-7fabaacfc000 r--p 00000000 08:05 1847278                    /usr/lib/AirVPN/Lib.Forms.dll
7fabaacfc000-7fabaad70000 r--p 00000000 08:05 1847279                    /usr/lib/AirVPN/Lib.Core.dll
7fabaad70000-7fabab032000 r--p 00000000 08:05 3801536                    /usr/lib/mono/gac/System.Windows.Forms/4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
7fabab032000-7fabab033000 ---p 00000000 00:00 0
7fabab033000-7fabab03b000 ---p 00000000 00:00 0
7fabab03b000-7fabab317000 rw-p 00000000 00:00 0
7fabab317000-7fabab9e1000 r-xp 00000000 08:05 3150586                    /usr/lib/mono/4.5/mscorlib.dll.so
7fabab9e1000-7fababbe0000 ---p 006ca000 08:05 3150586                    /usr/lib/mono/4.5/mscorlib.dll.so
7fababbe0000-7fababbe1000 r--p 006c9000 08:05 3150586                    /usr/lib/mono/4.5/mscorlib.dll.so
7fababbe1000-7fababbe2000 rw-p 006ca000 08:05 3150586                    /usr/lib/mono/4.5/mscorlib.dll.so
7fababbe2000-7fabacbff000 rw-p 00000000 00:00 0
7fabacbff000-7fabacc00000 ---p 00000000 00:00 0
7fabacc00000-7fabad802000 rw-p 00000000 00:00 0
7fabad802000-7fabad819000 rw-p 00000000 00:00 0
7fabad819000-7fabad81d000 rw-p 00000000 00:00 0
7fabad81d000-7fabad82b000 r--s 00000000 08:05 2626894                    /var/cache/fontconfig/491f45a0a771fef1c10b9b647a97fb82-le64.cache-7
7fabad82b000-7fabadbd4000 r--p 00000000 08:05 3150876                    /usr/lib/mono/4.5/mscorlib.dll
7fabadbd4000-7fabadbd5000 rw-p 00000000 00:00 0
7fabadbd5000-7fabadc34000 ---p 00000000 00:00 0
7fabadc34000-7fabadde2000 r-xp 00000000 08:05 1706160                    /usr/lib/libc-2.26.so
7fabadde2000-7fabadfe2000 ---p 001ae000 08:05 1706160                    /usr/lib/libc-2.26.so
7fabadfe2000-7fabadfe6000 r--p 001ae000 08:05 1706160                    /usr/lib/libc-2.26.so
7fabadfe6000-7fabadfe8000 rw-p 001b2000 08:05 1706160                    /usr/lib/libc-2.26.so
7fabadfe8000-7fabadfec000 rw-p 00000000 00:00 0
7fabadfec000-7fabae002000 r-xp 00000000 08:05 1707717                    /usr/lib/libgcc_s.so.1
7fabae002000-7fabae201000 ---p 00016000 08:05 1707717                    /usr/lib/libgcc_s.so.1
7fabae201000-7fabae202000 r--p 00015000 08:05 1707717                    /usr/lib/libgcc_s.so.1
7fabae202000-7fabae203000 rw-p 00016000 08:05 1707717                    /usr/lib/libgcc_s.so.1
7fabae203000-7fabae21c000 r-xp 00000000 08:05 1706179                    /usr/lib/libpthread-2.26.so
7fabae21c000-7fabae41b000 ---p 00019000 08:05 1706179                    /usr/lib/libpthread-2.26.so
7fabae41b000-7fabae41c000 r--p 00018000 08:05 1706179                    /usr/lib/libpthread-2.26.so
7fabae41c000-7fabae41d000 rw-p 00019000 08:05 1706179                    /usr/lib/libpthread-2.26.so
7fabae41d000-7fabae421000 rw-p 00000000 00:00 0
7fabae421000-7fabae424000 r-xp 00000000 08:05 1706106                    /usr/lib/libdl-2.26.so
7fabae424000-7fabae623000 ---p 00003000 08:05 1706106                    /usr/lib/libdl-2.26.so
7fabae623000-7fabae624000 r--p 00002000 08:05 1706106                    /usr/lib/libdl-2.26.so
7fabae624000-7fabae625000 rw-p 00003000 08:05 1706106                    /usr/lib/libdl-2.26.so
7fabae625000-7fabae62c000 r-xp 00000000 08:05 1706102                    /usr/lib/librt-2.26.so
7fabae62c000-7fabae82b000 ---p 00007000 08:05 1706102                    /usr/lib/librt-2.26.so
7fabae82b000-7fabae82c000 r--p 00006000 08:05 1706102                    /usr/lib/librt-2.26.so
7fabae82c000-7fabae82d000 rw-p 00007000 08:05 1706102                    /usr/lib/librt-2.26.so
7fabae82d000-7fabae978000 r-xp 00000000 08:05 1706105                    /usr/lib/libm-2.26.so
7fabae978000-7fabaeb77000 ---p 0014b000 08:05 1706105                    /usr/lib/libm-2.26.so
7fabaeb77000-7fabaeb78000 r--p 0014a000 08:05 1706105                    /usr/lib/libm-2.26.so
7fabaeb78000-7fabaeb79000 rw-p 0014b000 08:05 1706105                    /usr/lib/libm-2.26.so
7fabaeb79000-7fabaeb9e000 r-xp 00000000 08:05 1706161                    /usr/lib/ld-2.26.so
7fabaeb9e000-7fabaebab000 rw-p 00000000 00:00 0
7fabaebab000-7fabaebad000 r--s 00000000 08:05 2626885                    /var/cache/fontconfig/6ba42ae0000f58711b5caaf10d690066-le64.cache-7
7fabaebad000-7fabaebb9000 r--s 00000000 08:05 2626890                    /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-le64.cache-7
7fabaebb9000-7fabaebc2000 r--s 00000000 08:05 2626889                    /var/cache/fontconfig/f349e9996a5320f6dd491cedd2b1f964-le64.cache-7
7fabaebc2000-7fabaebca000 r--p 00000000 08:05 1847277                    /usr/lib/AirVPN/Lib.Platform.Linux.dll
7fabaebca000-7fabaed65000 r--p 00000000 08:05 1743341                    /usr/lib/locale/locale-archive
7fabaed65000-7fabaed6d000 rw-p 00000000 00:00 0
7fabaed6d000-7fabaed70000 r--p 00000000 08:05 3803130                    /usr/lib/mono/gac/Accessibility/4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
7fabaed70000-7fabaed73000 r--p 00000000 08:05 1847280                    /usr/lib/AirVPN/Lib.Common.dll
7fabaed73000-7fabaed7b000 rw-p 00000000 00:00 0
7fabaed7b000-7fabaed90000 r--p 00000000 08:05 1847282                    /usr/lib/AirVPN/AirVPN.exe
7fabaed90000-7fabaed9c000 rw-p 00000000 00:00 0
7fabaed9c000-7fabaed9d000 rw-s 00000000 00:15 1934762                    /dev/shm/mono.10282
7fabaed9d000-7fabaed9e000 r--p 00024000 08:05 1706161                    /usr/lib/ld-2.26.so
7fabaed9e000-7fabaed9f000 rw-p 00025000 08:05 1706161                    /usr/lib/ld-2.26.so
7fabaed9f000-7fabaeda0000 rw-p 00000000 00:00 0
7ffdb0636000-7ffdb063e000 ---p 00000000 00:00 0
7ffdb0e14000-7ffdb0e35000 rw-p 00000000 00:00 0                          [stack]
7ffdb0e83000-7ffdb0e86000 r--p 00000000 00:00 0                          [vvar]
7ffdb0e86000-7ffdb0e88000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
Native stacktrace:
exception inside UnhandledException handler: Object reference not set to an instance of an object
[ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object
[x@x]: ~>$
To be honest, I don't have a clue what's wrong. I've never had this kind of problem on Arch. Maybe someone else can help. Zhang888 is usually very resourceful.
Did you try anothr desktop environment besides Budgie on Arch? I never experienced these problems with Xfce or KDE Plasma.
I switched to Xfce 10 days ago (on November 25th according to pamac) and Eddie hasn't frozen a single time since then! I'm still using airvpn-bin package installed from AUR.
I always used Budgie along with the three distros I mentioned (Elementary OS/ Ubuntu Budgie and Arch Linux). Never tried any other desktop environment before.
Neither Eddie nor mono have been updated in the last few days, so there are good chances that there is an issue with Budgie. At least, I can't find any other explanation.
I hope these freezes are gone for good. I fell in love with Arch Linux and I really like Xfce as well. I'll stick to that setup for a long time, that's for sure.
Thank you for your help and your time, I appreciate it.
I'm glad it worked out for you so far. I've been using Arch for several years now and never felt the need to switch to another distribution. The Xfce desktop environment has been the fastest and most stable I tested. There are lots of ways to make it really beautiful.
I had some trouble with Xorg a while ago and decided to install Plasma as a backup. It is nice as well but still has some annoying bugs (for example, the starter menu is still disappearing randomly).
This topic could be related to your problem, so if you like you could still try budgie with the next  version of Eddie:
https://airvpn.org/topic/23911-eddie-client-memory-leak-on-linux/
I found this topic when searching for a solution on the forums, indeed. The fact that Eddie requires Mono to run seems to cause quite a lot of issues for Linux users...
These freezes were driving me crazy because they occurred on three different distros with multiple clean installs. Not to mention that I didn't have any single issue/crash/freeze with other software. I was reallly out of idea and never thought about trying another desktop environment. Looks like it did the trick! I can't be 100% sure that Budgie was the culprit but one thing I'm sure about is that freezes never surfaced again since I switched to Xfce.
I wish some AirVPN users using Budgie Desktop could provide feedback, I can't believe I'm the only one who experienced these freezes.
AirVPN staff said on post #13 that a new Eddie version was coming before December 25th. I hope that's v3, which will be completely written from scratch (according to what AirVPN support told me in the ticket) and will no longer need Mono.
I've been using Arch for a few weeks and just like you, I don't intend to use anything else for now. This distribution is top notch. I still have a lot to learn (I switched to Linux on last September after 15 years+ using MS Windows) but I can definitely feel why it has such a good reputation in Linux world.
In regards to desktop environments, I tried most popular ones via VirtualBox and I figured I would stick to Xfce for now. This is just a matter of taste, obviously. I dislike Cinnamon, Pantheon, GNOME and KDE Plasma. Budgie was alright but lacked customization options in my opinion. I like MATE though, quite similar to Xfce. But Xfce still has my preference. I might try LXQt one of these days on a VM.
