i used airvpn before the move to a new house. In this time i got with my old isp the full speed most of the time .  But now with a much better connection and a different isp ( 400 cable ).
I get only 1-3 MB/s max on every server i tested . And i purchased AirVPN for a year i think. This is just bad.
  • I download most of the time over JDownloader 2 with a premium account.
  • Windows 10 Pro
  • LAN connection 1GB
  • Usally 35+ MB/s without Air VPN
  • SSL port wont help
I try every suggestion. Please help me with my slow speeds.
Had the same problem several months ago, it came after I updated my Windows 10. Theres is a Eddie Beta, download that and try it out. It helped me for the last update, but theres is now a newer one and I have the same problems again and AirVPN did not release a newer Eddie Beta yet.
Hope they'll do soon to fix the weird Win10 issue.
PS: It was for me weird and slow website loading, sometimes full speed sometimes not, the Beta Eddie Client fixed the Issue 100% for me so try it out.
