I have a 20 mbit/s adsl connection. I use openvpn client. I selected Switzerland only configuration.
At first connection no problem: good speed, all worked well. Then problems started.
I noticed in the openvpn client log a soft reset every hour, then my connection stop working:
Sat Sep 23 07:11:16 2017 TLS: soft reset sec=0 bytes=2572624377/-1 pkts=3400690/0
Sat Sep 23 07:11:28 2017 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Sat Sep 23 07:11:28 2017 VERIFY KU OK
Sat Sep 23 07:11:28 2017 Validating certificate extended key usage
Sat Sep 23 07:11:28 2017 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Sat Sep 23 07:11:28 2017 VERIFY EKU OK
Sat Sep 23 07:11:28 2017 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Sat Sep 23 07:11:34 2017 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sat Sep 23 07:11:34 2017 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Sep 23 07:11:34 2017 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sat Sep 23 07:11:34 2017 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Sep 23 07:11:34 2017 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Sat Sep 23 07:12:53 2017 TLS: new session incoming connection from [AF_INET]46.19.137.114:443
Sat Sep 23 07:12:53 2017 MANAGEMENT: >STATE:1506143573,WAIT,,,,,,
Sat Sep 23 07:13:53 2017 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Sep 23 07:13:53 2017 TLS Error: TLS handshake failed
Sat Sep 23 07:14:11 2017 TLS: new session incoming connection from [AF_INET]46.19.137.114:443
Sat Sep 23 07:14:11 2017 MANAGEMENT: >STATE:1506143651,WAIT,,,,,,
Sat Sep 23 07:14:51 2017 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Sat Sep 23 07:14:51 2017 VERIFY KU OK
Sat Sep 23 07:14:51 2017 Validating certificate extended key usage
Sat Sep 23 07:14:51 2017 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Sat Sep 23 07:14:51 2017 VERIFY EKU OK
Sat Sep 23 07:14:51 2017 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Sat Sep 23 07:15:11 2017 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Sep 23 07:15:11 2017 TLS Error: TLS handshake failed
Sat Sep 23 07:15:27 2017 TLS: new session incoming connection from [AF_INET]46.19.137.114:443
Sat Sep 23 07:15:27 2017 MANAGEMENT: >STATE:1506143727,WAIT,,,,,,
Sat Sep 23 07:16:27 2017 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Sep 23 07:16:27 2017 TLS Error: TLS handshake failed
Sat Sep 23 07:16:48 2017 TLS: new session incoming connection from [AF_INET]46.19.137.114:443
Sat Sep 23 07:16:48 2017 MANAGEMENT: >STATE:1506143808,WAIT,,,,,,
Sat Sep 23 07:17:24 2017 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Sat Sep 23 07:17:24 2017 VERIFY KU OK
Sat Sep 23 07:17:24 2017 Validating certificate extended key usage
Sat Sep 23 07:17:24 2017 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Sat Sep 23 07:17:24 2017 VERIFY EKU OK
Sat Sep 23 07:17:24 2017 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Sat Sep 23 07:17:48 2017 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Sep 23 07:17:48 2017 TLS Error: TLS handshake failed
Sat Sep 23 07:18:03 2017 TLS: new session incoming connection from [AF_INET]46.19.137.114:443
Sat Sep 23 07:18:03 2017 MANAGEMENT: >STATE:1506143883,WAIT,,,,,,
Sat Sep 23 07:19:03 2017 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Sep 23 07:19:03 2017 TLS Error: TLS handshake failed
Sat Sep 23 07:20:32 2017 [server] Inactivity timeout (--ping-restart), restarting
Sat Sep 23 07:20:32 2017 SIGUSR1[soft,ping-restart] received, process restarting
Sat Sep 23 07:20:32 2017 MANAGEMENT: >STATE:1506144032,RECONNECTING,ping-restart,,,,,
Sat Sep 23 07:20:32 2017 Restart pause, 5 second(s)
Sat Sep 23 07:20:37 2017 TCP/UDP: Preserving recently used remote address: [AF_INET]46.19.137.114:443
Sat Sep 23 07:20:37 2017 Socket Buffers: R=[65536->262144] S=[65536->262144]
Sat Sep 23 07:20:37 2017 UDP link local: (not bound)
Sat Sep 23 07:20:37 2017 UDP link remote: [AF_INET]46.19.137.114:443
Sat Sep 23 07:20:37 2017 MANAGEMENT: >STATE:1506144037,WAIT,,,,,,
Sat Sep 23 07:21:37 2017 [uNDEF] Inactivity timeout (--ping-restart), restarting
Sat Sep 23 07:21:37 2017 SIGUSR1[soft,ping-restart] received, process restarting
Sat Sep 23 07:21:37 2017 MANAGEMENT: >STATE:1506144097,RECONNECTING,ping-restart,,,,,
Sat Sep 23 07:21:37 2017 Restart pause, 5 second(s)
Sat Sep 23 07:21:42 2017 MANAGEMENT: >STATE:1506144102,RESOLVE,,,,,,
Sat Sep 23 07:21:42 2017 RESOLVE: Cannot resolve host address: ch.vpn.airdns.org:443 (Host sconosciuto. )
Sat Sep 23 07:21:42 2017 Could not determine IPv4/IPv6 protocol
Sat Sep 23 07:21:42 2017 SIGUSR1[soft,init_instance] received, process restarting
Sat Sep 23 07:21:42 2017 MANAGEMENT: >STATE:1506144102,RECONNECTING,init_instance,,,,,
Sat Sep 23 07:21:42 2017 Restart pause, 5 second(s)
Sat Sep 23 07:21:47 2017 MANAGEMENT: >STATE:1506144107,RESOLVE,,,,,,
Sat Sep 23 07:21:47 2017 RESOLVE: Cannot resolve host address: ch.vpn.airdns.org:443 (Host sconosciuto. )
Sat Sep 23 07:21:47 2017 Could not determine IPv4/IPv6 protocol
Sat Sep 23 07:21:47 2017 SIGUSR1[soft,init_instance] received, process restarting
Sat Sep 23 07:21:47 2017 MANAGEMENT: >STATE:1506144107,RECONNECTING,init_instance,,,,,
Sat Sep 23 07:21:47 2017 Restart pause, 5 second(s)
And so on ...
I manually restarted the connection and now I'm getting slow speeds ...
Any help?
I'm no more using OpenVPN GUI and I'm using command line openvpn.exe. I use a batch file to open connection and automatically restart it when stop working, at least I will have a working connection.
I'll double check connection speed ...
I did my script for improve autoreconnect but still I get random speed in Switzerland. After a lot of reconnect I passed from 1 to 15 mbit/s (download) and from 0.08 to 0.5 mbit/s (upload).
Then I added this to VPN configuration (OpenVPN client with Windows 8)
tun-mtu 1500
fragment 0
mssfix 0
And I got a little speed improvement.
