Not connected, Your IP: 216.73.216.9
ozone777
[SOLVED] Connectivity issues
I'm having difficulty connecting to the servers. Any help would be greatly appreciated. Thanks in advance.
5/20/2012 - 11:47 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:47 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:47 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:47 AM UDPv4 link local: [undef]
5/20/2012 - 11:47 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:48 AM TLS: Initial packet from 95.211.169.3:443, sid=f700e037 4b34be5b
5/20/2012 - 11:48 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:48 AM TLS Error: TLS handshake failed
5/20/2012 - 11:48 AM TCP/UDP: Closing socket
5/20/2012 - 11:48 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:48 AM Restart pause, 2 second(s)
5/20/2012 - 11:49 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:49 AM LZO compression initialized
5/20/2012 - 11:49 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:49 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:49 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:49 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:49 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:49 AM UDPv4 link local: [undef]
5/20/2012 - 11:49 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:49 AM TLS: Initial packet from 95.211.169.3:443, sid=694bcc61 d7d53286
5/20/2012 - 11:49 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
5/20/2012 - 11:49 AM VERIFY OK: nsCertType=SERVER
5/20/2012 - 11:49 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
5/20/2012 - 11:50 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:50 AM TLS Error: TLS handshake failed
5/20/2012 - 11:50 AM TCP/UDP: Closing socket
5/20/2012 - 11:50 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:50 AM Restart pause, 2 second(s)
5/20/2012 - 11:50 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:50 AM LZO compression initialized
5/20/2012 - 11:50 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:50 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:50 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:50 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:50 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:50 AM UDPv4 link local: [undef]
5/20/2012 - 11:50 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:50 AM TLS Error: Unroutable control packet received from 95.211.169.3:443 (si=3 op=P_ACK_V1)
5/20/2012 - 11:50 AM TLS: Initial packet from 95.211.169.3:443, sid=b40baef5 707f19cb
5/20/2012 - 11:51 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:51 AM TLS Error: TLS handshake failed
5/20/2012 - 11:51 AM TCP/UDP: Closing socket
5/20/2012 - 11:51 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:51 AM Restart pause, 2 second(s)
5/20/2012 - 11:51 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:51 AM LZO compression initialized
5/20/2012 - 11:51 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:51 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:51 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:51 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:51 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:51 AM UDPv4 link local: [undef]
5/20/2012 - 11:51 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:51 AM TLS: Initial packet from 95.211.169.3:443, sid=6cf894e6 22fbf04a
5/20/2012 - 11:52 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:52 AM TLS Error: TLS handshake failed
5/20/2012 - 11:52 AM TCP/UDP: Closing socket
5/20/2012 - 11:52 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:52 AM Restart pause, 2 second(s)
5/20/2012 - 11:52 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:52 AM LZO compression initialized
5/20/2012 - 11:52 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:52 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:52 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:52 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:52 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:52 AM UDPv4 link local: [undef]
5/20/2012 - 11:52 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:52 AM TLS: Initial packet from 95.211.169.3:443, sid=ef576b10 433de228
5/20/2012 - 11:53 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:53 AM TLS Error: TLS handshake failed
5/20/2012 - 11:53 AM TCP/UDP: Closing socket
5/20/2012 - 11:53 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:53 AM Restart pause, 2 second(s)
5/20/2012 - 11:53 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:53 AM LZO compression initialized
5/20/2012 - 11:53 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:53 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:53 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:53 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:53 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:53 AM UDPv4 link local: [undef]
5/20/2012 - 11:53 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:53 AM TLS: Initial packet from 95.211.169.3:443, sid=446bf280 242664f4
5/20/2012 - 11:53 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
5/20/2012 - 11:53 AM VERIFY OK: nsCertType=SERVER
5/20/2012 - 11:53 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
5/20/2012 - 11:54 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:54 AM TLS Error: TLS handshake failed
5/20/2012 - 11:54 AM TCP/UDP: Closing socket
5/20/2012 - 11:54 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:54 AM Restart pause, 2 second(s)
5/20/2012 - 11:54 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:54 AM LZO compression initialized
5/20/2012 - 11:54 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:54 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:54 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:54 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:54 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:54 AM UDPv4 link local: [undef]
5/20/2012 - 11:54 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:54 AM TLS: Initial packet from 95.211.169.3:443, sid=3e39a2e2 2ab480d5
5/20/2012 - 11:55 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:55 AM TLS Error: TLS handshake failed
5/20/2012 - 11:55 AM TCP/UDP: Closing socket
5/20/2012 - 11:55 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:55 AM Restart pause, 2 second(s)
5/20/2012 - 11:55 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:55 AM LZO compression initialized
5/20/2012 - 11:55 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:55 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:55 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:55 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:55 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:55 AM UDPv4 link local: [undef]
5/20/2012 - 11:55 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:55 AM TLS: Initial packet from 95.211.169.3:443, sid=2cb96d35 f0660609
5/20/2012 - 11:56 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:56 AM TLS Error: TLS handshake failed
5/20/2012 - 11:56 AM TCP/UDP: Closing socket
5/20/2012 - 11:56 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:56 AM Restart pause, 2 second(s)
5/20/2012 - 11:56 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:56 AM LZO compression initialized
5/20/2012 - 11:56 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:56 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:56 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:56 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:56 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:56 AM UDPv4 link local: [undef]
5/20/2012 - 11:56 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:56 AM TLS: Initial packet from 95.211.169.3:443, sid=92fbcd6f 0c0a10c4
5/20/2012 - 11:57 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:57 AM TLS Error: TLS handshake failed
5/20/2012 - 11:57 AM TCP/UDP: Closing socket
5/20/2012 - 11:57 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:57 AM Restart pause, 2 second(s)
5/20/2012 - 11:57 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:57 AM LZO compression initialized
5/20/2012 - 11:57 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:57 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:57 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:57 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:57 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:57 AM UDPv4 link local: [undef]
5/20/2012 - 11:57 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:57 AM TLS Error: Unroutable control packet received from 95.211.169.3:443 (si=3 op=P_ACK_V1)
5/20/2012 - 11:57 AM TLS: Initial packet from 95.211.169.3:443, sid=206727b4 6eea1c5b
5/20/2012 - 11:58 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:58 AM TLS Error: TLS handshake failed
5/20/2012 - 11:58 AM TCP/UDP: Closing socket
5/20/2012 - 11:58 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:58 AM Restart pause, 2 second(s)
5/20/2012 - 11:58 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:58 AM LZO compression initialized
5/20/2012 - 11:58 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:58 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:58 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:58 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:58 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:58 AM UDPv4 link local: [undef]
5/20/2012 - 11:58 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:58 AM TLS: Initial packet from 95.211.169.3:443, sid=4247ae8d 3cf1a023
5/20/2012 - 11:59 AM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
5/20/2012 - 11:59 AM VERIFY OK: nsCertType=SERVER
5/20/2012 - 11:59 AM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
5/20/2012 - 11:59 AM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 11:59 AM TLS Error: TLS handshake failed
5/20/2012 - 11:59 AM TCP/UDP: Closing socket
5/20/2012 - 11:59 AM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 11:59 AM Restart pause, 2 second(s)
5/20/2012 - 11:59 AM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 11:59 AM LZO compression initialized
5/20/2012 - 11:59 AM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 11:59 AM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 11:59 AM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 11:59 AM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 11:59 AM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 11:59 AM UDPv4 link local: [undef]
5/20/2012 - 11:59 AM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 11:59 AM TLS: Initial packet from 95.211.169.3:443, sid=117797ee 1a85d6b9
5/20/2012 - 12:00 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/20/2012 - 12:00 PM TLS Error: TLS handshake failed
5/20/2012 - 12:00 PM TCP/UDP: Closing socket
5/20/2012 - 12:00 PM SIGUSR1[soft,tls-error] received, process restarting
5/20/2012 - 12:00 PM Restart pause, 2 second(s)
5/20/2012 - 12:00 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/20/2012 - 12:00 PM LZO compression initialized
5/20/2012 - 12:00 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/20/2012 - 12:00 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/20/2012 - 12:00 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/20/2012 - 12:00 PM Local Options hash (VER=V4): '22188c5b'
5/20/2012 - 12:00 PM Expected Remote Options hash (VER=V4): 'a8f55717'
5/20/2012 - 12:00 PM UDPv4 link local: [undef]
5/20/2012 - 12:00 PM UDPv4 link remote: 95.211.169.3:443
5/20/2012 - 12:00 PM TLS: Initial packet from 95.211.169.3:443, sid=ad634f7c 426b2497
5/20/2012 - 12:01 PM Disconnecting...
5/20/2012 - 12:01 PM Disconnected.
Hopefully an admin will jump in, but in the meantime, from what you supplied this:
looks like a problem .. you may want to look at the configuration for the server you are trying to connect to.
Hope that helps .. Cheers
The most common cause of this problem is a firewall blocking OpenVPN. Can you please check? Also, please try a connection to a TCP port, just in case some UDP ports are blocked/capped by your ISP, on different servers.
We're looking forward to hearing from you.
Yes. It appears to be my firewall. It works everytime I disable my firewall (not recommended, I know, but it was just a simple test).
I'm using Comodo firewall. I set AirVPN as a trusted application but the issue is still there. Do you have any idea what other settings I can change in order to solve this issue?
Please make sure that openvpn.exe is in the trusted applications list as well.
It's acting up again...firewall or not. By the way, it worked flawlessly for the first five days or so after I paid for the service
5/25/2012 - 7:31 PM SIGUSR1[soft,tls-error] received, process restarting
5/25/2012 - 7:31 PM Restart pause, 2 second(s)
5/25/2012 - 7:31 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/25/2012 - 7:31 PM LZO compression initialized
5/25/2012 - 7:31 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/25/2012 - 7:31 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/25/2012 - 7:31 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/25/2012 - 7:31 PM Local Options hash (VER=V4): '22188c5b'
5/25/2012 - 7:31 PM Expected Remote Options hash (VER=V4): 'a8f55717'
5/25/2012 - 7:31 PM UDPv4 link local: [undef]
5/25/2012 - 7:31 PM UDPv4 link remote: 108.59.8.147:443
5/25/2012 - 7:31 PM TLS: Initial packet from 108.59.8.147:443, sid=e1099a6a d269b276
5/25/2012 - 7:31 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
5/25/2012 - 7:31 PM VERIFY OK: nsCertType=SERVER
5/25/2012 - 7:31 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
5/25/2012 - 7:32 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/25/2012 - 7:32 PM TLS Error: TLS handshake failed
5/25/2012 - 7:32 PM TCP/UDP: Closing socket
5/25/2012 - 7:32 PM SIGUSR1[soft,tls-error] received, process restarting
5/25/2012 - 7:32 PM Restart pause, 2 second(s)
5/25/2012 - 7:32 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/25/2012 - 7:32 PM LZO compression initialized
5/25/2012 - 7:32 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/25/2012 - 7:32 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/25/2012 - 7:32 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/25/2012 - 7:32 PM Local Options hash (VER=V4): '22188c5b'
5/25/2012 - 7:32 PM Expected Remote Options hash (VER=V4): 'a8f55717'
5/25/2012 - 7:32 PM UDPv4 link local: [undef]
5/25/2012 - 7:32 PM UDPv4 link remote: 108.59.8.147:443
5/25/2012 - 7:32 PM TLS: Initial packet from 108.59.8.147:443, sid=1c2e7a95 4715a06e
5/25/2012 - 7:32 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
5/25/2012 - 7:32 PM VERIFY OK: nsCertType=SERVER
5/25/2012 - 7:32 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
5/25/2012 - 7:32 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
5/25/2012 - 7:32 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
5/25/2012 - 7:32 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
5/25/2012 - 7:32 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
5/25/2012 - 7:32 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
5/25/2012 - 7:32 PM [server] Peer Connection Initiated with 108.59.8.147:443
5/25/2012 - 7:32 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
5/25/2012 - 7:32 PM AUTH: Received AUTH_FAILED control message
5/25/2012 - 7:32 PM Authorization failed. Maybe you are connected from another machine?
5/25/2012 - 7:32 PM Disconnecting...
5/25/2012 - 7:32 PM Disconnected.
5/25/2012 - 7:32 PM SIGTERM received, sending exit notification to peer
5/25/2012 - 7:32 PM Login...
5/25/2012 - 7:32 PM Already connected.
5/25/2012 - 7:33 PM Login...
5/25/2012 - 7:33 PM Already connected.
5/25/2012 - 7:37 PM Login...
5/25/2012 - 7:37 PM Login success.
5/25/2012 - 7:37 PM Contacting service...
5/25/2012 - 7:37 PM Connecting...
5/25/2012 - 7:37 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
5/25/2012 - 7:37 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/25/2012 - 7:37 PM LZO compression initialized
5/25/2012 - 7:37 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/25/2012 - 7:37 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/25/2012 - 7:37 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/25/2012 - 7:37 PM Local Options hash (VER=V4): '22188c5b'
5/25/2012 - 7:37 PM Expected Remote Options hash (VER=V4): 'a8f55717'
5/25/2012 - 7:37 PM UDPv4 link local: [undef]
5/25/2012 - 7:37 PM UDPv4 link remote: 69.163.36.66:443
5/25/2012 - 7:37 PM TLS: Initial packet from 69.163.36.66:443, sid=a67403f9 5d0b1c7e
5/25/2012 - 7:38 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
5/25/2012 - 7:38 PM VERIFY OK: nsCertType=SERVER
5/25/2012 - 7:38 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
5/25/2012 - 7:38 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
5/25/2012 - 7:38 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
5/25/2012 - 7:38 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
5/25/2012 - 7:38 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
5/25/2012 - 7:38 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
5/25/2012 - 7:38 PM [server] Peer Connection Initiated with 69.163.36.66:443
5/25/2012 - 7:38 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
5/25/2012 - 7:38 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.14.242 10.4.14.241'
5/25/2012 - 7:38 PM OPTIONS IMPORT: timers and/or timeouts modified
5/25/2012 - 7:38 PM OPTIONS IMPORT: LZO parms modified
5/25/2012 - 7:38 PM OPTIONS IMPORT: --ifconfig/up options modified
5/25/2012 - 7:38 PM OPTIONS IMPORT: route options modified
5/25/2012 - 7:38 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
5/25/2012 - 7:38 PM ROUTE default_gateway=192.168.2.1
5/25/2012 - 7:38 PM TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{D1B1D266-17DF-45F2-A7EA-4FADA2920D7F}.tap
5/25/2012 - 7:38 PM TAP-Win32 Driver Version 9.9
5/25/2012 - 7:38 PM TAP-Win32 MTU=1500
5/25/2012 - 7:38 PM Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.14.242/255.255.255.252 on interface {D1B1D266-17DF-45F2-A7EA-4FADA2920D7F} [DHCP-serv: 10.4.14.241, lease-time: 31536000]
5/25/2012 - 7:38 PM Successful ARP Flush on interface [42] {D1B1D266-17DF-45F2-A7EA-4FADA2920D7F}
5/25/2012 - 7:38 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
5/25/2012 - 7:38 PM C:\WINDOWS\system32\route.exe ADD 69.163.36.66 MASK 255.255.255.255 192.168.2.1
5/25/2012 - 7:38 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
5/25/2012 - 7:38 PM Route addition via IPAPI succeeded [adaptive]
5/25/2012 - 7:38 PM C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.14.241
5/25/2012 - 7:38 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
5/25/2012 - 7:38 PM C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.14.241
5/25/2012 - 7:38 PM C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.14.241
5/25/2012 - 7:38 PM Initialization Sequence Completed
5/25/2012 - 7:38 PM Starting Management Interface...
5/25/2012 - 7:38 PM Checking...
5/25/2012 - 7:38 PM Retrieve statistics...
5/25/2012 - 7:38 PM Connected.
5/25/2012 - 7:39 PM Disconnecting...
5/25/2012 - 7:39 PM SIGTERM received, sending exit notification to peer
5/25/2012 - 7:39 PM TCP/UDP: Closing socket
5/25/2012 - 7:39 PM Disconnected.
5/25/2012 - 7:39 PM C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.14.241
5/25/2012 - 7:39 PM Route deletion via IPAPI succeeded [adaptive]
5/25/2012 - 7:39 PM C:\WINDOWS\system32\route.exe DELETE 69.163.36.66 MASK 255.255.255.255 192.168.2.1
5/25/2012 - 7:39 PM C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.14.241
5/25/2012 - 7:39 PM C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.14.241
5/25/2012 - 7:39 PM Closing TUN/TAP interface
5/25/2012 - 7:39 PM SIGTERM[hard,] received, process exiting
5/25/2012 - 8:30 PM Login...
5/25/2012 - 8:30 PM Login success.
5/25/2012 - 8:30 PM Contacting service...
5/25/2012 - 8:30 PM Connecting...
5/25/2012 - 8:30 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
5/25/2012 - 8:30 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/25/2012 - 8:30 PM LZO compression initialized
5/25/2012 - 8:30 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/25/2012 - 8:30 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/25/2012 - 8:30 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/25/2012 - 8:30 PM Local Options hash (VER=V4): '22188c5b'
5/25/2012 - 8:30 PM Expected Remote Options hash (VER=V4): 'a8f55717'
5/25/2012 - 8:30 PM UDPv4 link local: [undef]
5/25/2012 - 8:30 PM UDPv4 link remote: 95.211.169.3:443
5/25/2012 - 8:30 PM TLS: Initial packet from 95.211.169.3:443, sid=07434ff9 e8f88ae7
5/25/2012 - 8:31 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
5/25/2012 - 8:31 PM VERIFY OK: nsCertType=SERVER
5/25/2012 - 8:31 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
5/25/2012 - 8:31 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/25/2012 - 8:31 PM TLS Error: TLS handshake failed
5/25/2012 - 8:31 PM TCP/UDP: Closing socket
5/25/2012 - 8:31 PM SIGUSR1[soft,tls-error] received, process restarting
5/25/2012 - 8:31 PM Restart pause, 2 second(s)
5/25/2012 - 8:31 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/25/2012 - 8:31 PM LZO compression initialized
5/25/2012 - 8:31 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/25/2012 - 8:31 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/25/2012 - 8:31 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/25/2012 - 8:31 PM Local Options hash (VER=V4): '22188c5b'
5/25/2012 - 8:31 PM Expected Remote Options hash (VER=V4): 'a8f55717'
5/25/2012 - 8:31 PM UDPv4 link local: [undef]
5/25/2012 - 8:31 PM UDPv4 link remote: 95.211.169.3:443
5/25/2012 - 8:31 PM TLS: Initial packet from 95.211.169.3:443, sid=8795e160 73854054
5/25/2012 - 8:32 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
5/25/2012 - 8:32 PM VERIFY OK: nsCertType=SERVER
5/25/2012 - 8:32 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
5/25/2012 - 8:32 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/25/2012 - 8:32 PM TLS Error: TLS handshake failed
5/25/2012 - 8:32 PM TCP/UDP: Closing socket
5/25/2012 - 8:32 PM SIGUSR1[soft,tls-error] received, process restarting
5/25/2012 - 8:32 PM Restart pause, 2 second(s)
5/25/2012 - 8:32 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/25/2012 - 8:32 PM LZO compression initialized
5/25/2012 - 8:32 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/25/2012 - 8:32 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/25/2012 - 8:32 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/25/2012 - 8:32 PM Local Options hash (VER=V4): '22188c5b'
5/25/2012 - 8:32 PM Expected Remote Options hash (VER=V4): 'a8f55717'
5/25/2012 - 8:32 PM UDPv4 link local: [undef]
5/25/2012 - 8:32 PM UDPv4 link remote: 95.211.169.3:443
5/25/2012 - 8:32 PM TLS: Initial packet from 95.211.169.3:443, sid=4a7e1345 31312021
5/25/2012 - 8:33 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
5/25/2012 - 8:33 PM VERIFY OK: nsCertType=SERVER
5/25/2012 - 8:33 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
5/25/2012 - 8:33 PM TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
5/25/2012 - 8:33 PM TLS Error: TLS handshake failed
5/25/2012 - 8:33 PM TCP/UDP: Closing socket
5/25/2012 - 8:33 PM SIGUSR1[soft,tls-error] received, process restarting
5/25/2012 - 8:33 PM Restart pause, 2 second(s)
5/25/2012 - 8:33 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
5/25/2012 - 8:33 PM LZO compression initialized
5/25/2012 - 8:33 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
5/25/2012 - 8:33 PM Socket Buffers: R=[8192->8192] S=[8192->8192]
5/25/2012 - 8:33 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
5/25/2012 - 8:33 PM Local Options hash (VER=V4): '22188c5b'
5/25/2012 - 8:33 PM Expected Remote Options hash (VER=V4): 'a8f55717'
5/25/2012 - 8:33 PM UDPv4 link local: [undef]
5/25/2012 - 8:33 PM UDPv4 link remote: 95.211.169.3:443
5/25/2012 - 8:34 PM TLS: Initial packet from 95.211.169.3:443, sid=05588c19 7f8ff887
5/25/2012 - 8:34 PM VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
5/25/2012 - 8:34 PM VERIFY OK: nsCertType=SERVER
5/25/2012 - 8:34 PM VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
5/25/2012 - 8:34 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
5/25/2012 - 8:34 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
5/25/2012 - 8:34 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
5/25/2012 - 8:34 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
5/25/2012 - 8:34 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
5/25/2012 - 8:34 PM [server] Peer Connection Initiated with 95.211.169.3:443
5/25/2012 - 8:34 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
5/25/2012 - 8:35 PM AUTH: Received AUTH_FAILED control message
5/25/2012 - 8:35 PM Authorization failed. Maybe you are connected from another machine?
Did you change anything on your firewall setup since when it worked flawlessly?
Further attempts which are worth to try:
- check Windows firewall and disable it completely if you have not already done so (you don't need it since you have Comodo);
- connect to different servers on some TCP port (try port 80 TCP for example)
The issue is still there (with or without Windows firewall) and no I haven't changed anything on my firewall since it worked flawlessly.
"- connect to different servers on some TCP port (try port 80 TCP for example)"
How do I do that? I'm not as tech savvy as I used to be.
Both the Air client and the Air configuration generator let you choose the server and the port you wish to use for the connection. With the client, select a server, then click on the "Modes" tab and click on port "80 TCP". With the configuration generator, pick a server, pick "port 80" and "protocol TCP".
