spookygoy
Web site keeps identifying me as 46.x.y.z
It doesn't matter what server I connected to, it always sees my external IP as this address.
I think this is wreacking havock with my attempt to use a prepaid VISA debit card to make payments via paypal as well, because this IP resolves to Germany which is outside of the USA.
I have successfully in the past used prepaid VISA cards to make payments anonymously on this site so I am not sure what is up here or why it sees my IP as that and not the external IP assigned to the server I am connected to
WebRTC is turned off in Firefox
even tried switching DNS server to google 8.8.8.8
Can anyone explain how/why it is detecting this IP and what I can do to try and get around it?
of course I'm connected.  I live in the USA I shouldn't have a german IP regardless (I'm connected to USA servers also).
Not sure how a log would help here
other sites correctly identify my IP as the one associated with the AirVPN server I am connected to
. 2017.08.25 12:59:29 - Updating systems & servers data ...
. 2017.08.25 12:59:31 - Systems & servers data update completed
. 2017.08.25 13:09:33 - Updating systems & servers data ...
. 2017.08.25 13:09:34 - Systems & servers data update completed
. 2017.08.25 13:19:36 - Updating systems & servers data ...
. 2017.08.25 13:19:38 - Systems & servers data update completed
. 2017.08.25 13:29:40 - Updating systems & servers data ...
. 2017.08.25 13:29:41 - Systems & servers data update completed
. 2017.08.25 13:39:43 - Updating systems & servers data ...
. 2017.08.25 13:39:44 - Systems & servers data update completed
. 2017.08.25 13:49:46 - Updating systems & servers data ...
. 2017.08.25 13:49:47 - Systems & servers data update completed
. 2017.08.25 13:51:48 - OpenVPN > TLS: soft reset sec=0 bytes=737877/-1 pkts=2078/0
. 2017.08.25 13:51:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 13:51:48 - OpenVPN > Validating certificate key usage
. 2017.08.25 13:51:48 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 13:51:48 - OpenVPN > VERIFY KU OK
. 2017.08.25 13:51:48 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 13:51:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 13:51:48 - OpenVPN > VERIFY EKU OK
. 2017.08.25 13:51:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 13:51:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 13:51:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 13:51:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 13:51:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 13:51:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 13:59:49 - Updating systems & servers data ...
. 2017.08.25 13:59:50 - Systems & servers data update completed
. 2017.08.25 14:09:52 - Updating systems & servers data ...
. 2017.08.25 14:09:55 - Systems & servers data update completed
. 2017.08.25 14:19:57 - Updating systems & servers data ...
. 2017.08.25 14:19:58 - Systems & servers data update completed
. 2017.08.25 14:30:00 - Updating systems & servers data ...
. 2017.08.25 14:30:01 - Systems & servers data update completed
. 2017.08.25 14:40:03 - Updating systems & servers data ...
. 2017.08.25 14:40:04 - Systems & servers data update completed
. 2017.08.25 14:50:06 - Updating systems & servers data ...
. 2017.08.25 14:50:07 - Systems & servers data update completed
. 2017.08.25 14:51:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 14:51:48 - OpenVPN > Validating certificate key usage
. 2017.08.25 14:51:48 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 14:51:48 - OpenVPN > VERIFY KU OK
. 2017.08.25 14:51:48 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 14:51:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 14:51:48 - OpenVPN > VERIFY EKU OK
. 2017.08.25 14:51:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 14:51:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 14:51:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 14:51:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 14:51:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 14:51:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 15:00:09 - Updating systems & servers data ...
. 2017.08.25 15:00:10 - Systems & servers data update completed
. 2017.08.25 15:10:12 - Updating systems & servers data ...
. 2017.08.25 15:10:13 - Systems & servers data update completed
. 2017.08.25 15:20:15 - Updating systems & servers data ...
. 2017.08.25 15:20:16 - Systems & servers data update completed
. 2017.08.25 15:30:19 - Updating systems & servers data ...
. 2017.08.25 15:30:20 - Systems & servers data update completed
. 2017.08.25 15:40:22 - Updating systems & servers data ...
. 2017.08.25 15:40:23 - Systems & servers data update completed
. 2017.08.25 15:50:25 - Updating systems & servers data ...
. 2017.08.25 15:50:26 - Systems & servers data update completed
. 2017.08.25 15:51:48 - OpenVPN > TLS: soft reset sec=0 bytes=120605639/-1 pkts=128569/0
. 2017.08.25 15:51:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 15:51:48 - OpenVPN > Validating certificate key usage
. 2017.08.25 15:51:48 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 15:51:48 - OpenVPN > VERIFY KU OK
. 2017.08.25 15:51:48 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 15:51:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 15:51:48 - OpenVPN > VERIFY EKU OK
. 2017.08.25 15:51:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 15:51:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 15:51:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 15:51:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 15:51:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 15:51:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 16:00:28 - Updating systems & servers data ...
. 2017.08.25 16:00:29 - Systems & servers data update completed
. 2017.08.25 16:10:31 - Updating systems & servers data ...
. 2017.08.25 16:10:32 - Systems & servers data update completed
. 2017.08.25 16:20:34 - Updating systems & servers data ...
. 2017.08.25 16:20:35 - Systems & servers data update completed
. 2017.08.25 16:30:38 - Updating systems & servers data ...
. 2017.08.25 16:30:39 - Systems & servers data update completed
. 2017.08.25 16:40:41 - Updating systems & servers data ...
. 2017.08.25 16:40:42 - Systems & servers data update completed
. 2017.08.25 16:50:44 - Updating systems & servers data ...
. 2017.08.25 16:50:45 - Systems & servers data update completed
. 2017.08.25 16:51:48 - OpenVPN > TLS: soft reset sec=0 bytes=8848947/-1 pkts=10746/0
. 2017.08.25 16:51:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 16:51:49 - OpenVPN > Validating certificate key usage
. 2017.08.25 16:51:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 16:51:49 - OpenVPN > VERIFY KU OK
. 2017.08.25 16:51:49 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 16:51:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 16:51:49 - OpenVPN > VERIFY EKU OK
. 2017.08.25 16:51:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 16:51:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 16:51:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 16:51:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 16:51:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 16:51:49 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 17:00:48 - Updating systems & servers data ...
. 2017.08.25 17:00:49 - Systems & servers data update completed
. 2017.08.25 17:10:51 - Updating systems & servers data ...
. 2017.08.25 17:10:52 - Systems & servers data update completed
. 2017.08.25 17:20:54 - Updating systems & servers data ...
. 2017.08.25 17:20:55 - Systems & servers data update completed
. 2017.08.25 17:30:58 - Updating systems & servers data ...
. 2017.08.25 17:30:59 - Systems & servers data update completed
. 2017.08.25 17:41:01 - Updating systems & servers data ...
. 2017.08.25 17:41:02 - Systems & servers data update completed
. 2017.08.25 17:51:04 - Updating systems & servers data ...
. 2017.08.25 17:51:05 - Systems & servers data update completed
I 2017.08.25 17:51:48 - Renewing TLS key
. 2017.08.25 17:51:48 - OpenVPN > TLS: tls_process: killed expiring key
. 2017.08.25 17:51:49 - OpenVPN > TLS: soft reset sec=0 bytes=757874/-1 pkts=2111/0
. 2017.08.25 17:51:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 17:51:49 - OpenVPN > Validating certificate key usage
. 2017.08.25 17:51:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 17:51:49 - OpenVPN > VERIFY KU OK
. 2017.08.25 17:51:49 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 17:51:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 17:51:49 - OpenVPN > VERIFY EKU OK
. 2017.08.25 17:51:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 17:51:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 17:51:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 17:51:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 17:51:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 17:51:49 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 18:01:07 - Updating systems & servers data ...
. 2017.08.25 18:01:08 - Systems & servers data update completed
. 2017.08.25 18:11:11 - Updating systems & servers data ...
. 2017.08.25 18:11:12 - Systems & servers data update completed
. 2017.08.25 18:21:14 - Updating systems & servers data ...
. 2017.08.25 18:21:15 - Systems & servers data update completed
. 2017.08.25 18:31:17 - Updating systems & servers data ...
. 2017.08.25 18:31:18 - Systems & servers data update completed
. 2017.08.25 18:41:21 - Updating systems & servers data ...
. 2017.08.25 18:41:22 - Systems & servers data update completed
. 2017.08.25 18:51:24 - Updating systems & servers data ...
. 2017.08.25 18:51:25 - Systems & servers data update completed
. 2017.08.25 18:51:49 - OpenVPN > TLS: soft reset sec=0 bytes=767248/-1 pkts=2178/0
. 2017.08.25 18:51:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 18:51:49 - OpenVPN > Validating certificate key usage
. 2017.08.25 18:51:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 18:51:49 - OpenVPN > VERIFY KU OK
. 2017.08.25 18:51:49 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 18:51:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 18:51:49 - OpenVPN > VERIFY EKU OK
. 2017.08.25 18:51:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 18:51:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 18:51:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 18:51:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 18:51:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 18:51:49 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 19:01:27 - Updating systems & servers data ...
. 2017.08.25 19:01:28 - Systems & servers data update completed
. 2017.08.25 19:11:30 - Updating systems & servers data ...
. 2017.08.25 19:11:31 - Systems & servers data update completed
. 2017.08.25 19:21:34 - Updating systems & servers data ...
. 2017.08.25 19:21:35 - Systems & servers data update completed
. 2017.08.25 19:31:37 - Updating systems & servers data ...
. 2017.08.25 19:31:39 - Systems & servers data update completed
. 2017.08.25 19:41:42 - Updating systems & servers data ...
. 2017.08.25 19:41:43 - Systems & servers data update completed
. 2017.08.25 19:51:45 - Updating systems & servers data ...
. 2017.08.25 19:51:46 - Systems & servers data update completed
. 2017.08.25 19:51:49 - OpenVPN > TLS: soft reset sec=0 bytes=7166189/-1 pkts=9370/0
. 2017.08.25 19:51:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 19:51:49 - OpenVPN > Validating certificate key usage
. 2017.08.25 19:51:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 19:51:49 - OpenVPN > VERIFY KU OK
. 2017.08.25 19:51:49 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 19:51:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 19:51:49 - OpenVPN > VERIFY EKU OK
. 2017.08.25 19:51:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 19:51:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 19:51:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 19:51:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 19:51:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 19:51:49 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 20:01:48 - Updating systems & servers data ...
. 2017.08.25 20:01:50 - Systems & servers data update completed
. 2017.08.25 20:11:52 - Updating systems & servers data ...
. 2017.08.25 20:11:53 - Systems & servers data update completed
. 2017.08.25 20:21:56 - Updating systems & servers data ...
. 2017.08.25 20:21:57 - Systems & servers data update completed
. 2017.08.25 20:31:59 - Updating systems & servers data ...
. 2017.08.25 20:32:00 - Systems & servers data update completed
. 2017.08.25 20:42:02 - Updating systems & servers data ...
. 2017.08.25 20:42:03 - Systems & servers data update completed
. 2017.08.25 20:51:49 - OpenVPN > TLS: soft reset sec=0 bytes=612641/-1 pkts=1886/0
. 2017.08.25 20:51:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 20:51:50 - OpenVPN > Validating certificate key usage
. 2017.08.25 20:51:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 20:51:50 - OpenVPN > VERIFY KU OK
. 2017.08.25 20:51:50 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 20:51:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 20:51:50 - OpenVPN > VERIFY EKU OK
. 2017.08.25 20:51:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 20:51:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 20:51:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 20:51:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 20:51:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 20:51:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 20:52:06 - Updating systems & servers data ...
. 2017.08.25 20:52:07 - Systems & servers data update completed
. 2017.08.25 21:02:09 - Updating systems & servers data ...
. 2017.08.25 21:02:10 - Systems & servers data update completed
. 2017.08.25 21:12:12 - Updating systems & servers data ...
. 2017.08.25 21:12:13 - Systems & servers data update completed
. 2017.08.25 21:22:15 - Updating systems & servers data ...
. 2017.08.25 21:22:16 - Systems & servers data update completed
. 2017.08.25 21:32:19 - Updating systems & servers data ...
. 2017.08.25 21:32:20 - Systems & servers data update completed
. 2017.08.25 21:42:22 - Updating systems & servers data ...
. 2017.08.25 21:42:23 - Systems & servers data update completed
I 2017.08.25 21:51:49 - Renewing TLS key
. 2017.08.25 21:51:49 - OpenVPN > TLS: tls_process: killed expiring key
. 2017.08.25 21:51:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 21:51:50 - OpenVPN > Validating certificate key usage
. 2017.08.25 21:51:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 21:51:50 - OpenVPN > VERIFY KU OK
. 2017.08.25 21:51:50 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 21:51:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 21:51:50 - OpenVPN > VERIFY EKU OK
. 2017.08.25 21:51:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 21:51:51 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 21:51:51 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 21:51:51 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 21:51:51 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 21:51:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 21:52:25 - Updating systems & servers data ...
. 2017.08.25 21:52:26 - Systems & servers data update completed
. 2017.08.25 22:02:29 - Updating systems & servers data ...
. 2017.08.25 22:02:30 - Systems & servers data update completed
. 2017.08.25 22:12:32 - Updating systems & servers data ...
. 2017.08.25 22:12:33 - Systems & servers data update completed
. 2017.08.25 22:22:35 - Updating systems & servers data ...
. 2017.08.25 22:22:36 - Systems & servers data update completed
. 2017.08.25 22:32:39 - Updating systems & servers data ...
. 2017.08.25 22:32:40 - Systems & servers data update completed
. 2017.08.25 22:42:42 - Updating systems & servers data ...
. 2017.08.25 22:42:43 - Systems & servers data update completed
I 2017.08.25 22:51:50 - Renewing TLS key
. 2017.08.25 22:51:50 - OpenVPN > TLS: tls_process: killed expiring key
. 2017.08.25 22:51:51 - OpenVPN > TLS: soft reset sec=0 bytes=609992/-1 pkts=1855/0
. 2017.08.25 22:51:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 22:51:51 - OpenVPN > Validating certificate key usage
. 2017.08.25 22:51:51 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 22:51:51 - OpenVPN > VERIFY KU OK
. 2017.08.25 22:51:51 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 22:51:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 22:51:51 - OpenVPN > VERIFY EKU OK
. 2017.08.25 22:51:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 22:51:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 22:51:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 22:51:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 22:51:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 22:51:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 22:52:45 - Updating systems & servers data ...
. 2017.08.25 22:52:46 - Systems & servers data update completed
. 2017.08.25 23:02:48 - Updating systems & servers data ...
. 2017.08.25 23:02:49 - Systems & servers data update completed
. 2017.08.25 23:12:52 - Updating systems & servers data ...
. 2017.08.25 23:12:53 - Systems & servers data update completed
. 2017.08.25 23:22:55 - Updating systems & servers data ...
. 2017.08.25 23:22:56 - Systems & servers data update completed
. 2017.08.25 23:32:58 - Updating systems & servers data ...
. 2017.08.25 23:32:59 - Systems & servers data update completed
. 2017.08.25 23:43:01 - Updating systems & servers data ...
. 2017.08.25 23:43:02 - Systems & servers data update completed
. 2017.08.25 23:51:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.25 23:51:49 - OpenVPN > Validating certificate key usage
. 2017.08.25 23:51:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.25 23:51:49 - OpenVPN > VERIFY KU OK
. 2017.08.25 23:51:49 - OpenVPN > Validating certificate extended key usage
. 2017.08.25 23:51:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.25 23:51:49 - OpenVPN > VERIFY EKU OK
. 2017.08.25 23:51:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.25 23:51:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 23:51:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 23:51:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.25 23:51:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.25 23:51:49 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.25 23:54:02 - Updating systems & servers data ...
. 2017.08.25 23:54:03 - Systems & servers data update completed
. 2017.08.26 00:04:05 - Updating systems & servers data ...
. 2017.08.26 00:04:06 - Systems & servers data update completed
. 2017.08.26 00:14:08 - Updating systems & servers data ...
. 2017.08.26 00:14:09 - Systems & servers data update completed
. 2017.08.26 00:24:10 - Updating systems & servers data ...
. 2017.08.26 00:24:11 - Systems & servers data update completed
. 2017.08.26 00:34:12 - Updating systems & servers data ...
. 2017.08.26 00:34:14 - Systems & servers data update completed
. 2017.08.26 00:44:15 - Updating systems & servers data ...
. 2017.08.26 00:44:16 - Systems & servers data update completed
. 2017.08.26 00:51:49 - OpenVPN > TLS: soft reset sec=0 bytes=530821673/-1 pkts=573967/0
. 2017.08.26 00:51:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 00:51:49 - OpenVPN > Validating certificate key usage
. 2017.08.26 00:51:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 00:51:49 - OpenVPN > VERIFY KU OK
. 2017.08.26 00:51:49 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 00:51:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 00:51:49 - OpenVPN > VERIFY EKU OK
. 2017.08.26 00:51:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 00:51:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 00:51:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 00:51:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 00:51:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 00:51:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 00:54:17 - Updating systems & servers data ...
. 2017.08.26 00:54:18 - Systems & servers data update completed
. 2017.08.26 01:04:19 - Updating systems & servers data ...
. 2017.08.26 01:04:21 - Systems & servers data update completed
. 2017.08.26 01:14:22 - Updating systems & servers data ...
. 2017.08.26 01:14:23 - Systems & servers data update completed
. 2017.08.26 01:24:25 - Updating systems & servers data ...
. 2017.08.26 01:24:26 - Systems & servers data update completed
. 2017.08.26 01:34:27 - Updating systems & servers data ...
. 2017.08.26 01:34:28 - Systems & servers data update completed
. 2017.08.26 01:44:29 - Updating systems & servers data ...
. 2017.08.26 01:44:30 - Systems & servers data update completed
. 2017.08.26 01:51:50 - OpenVPN > TLS: soft reset sec=0 bytes=678320463/-1 pkts=710214/0
. 2017.08.26 01:51:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 01:51:50 - OpenVPN > Validating certificate key usage
. 2017.08.26 01:51:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 01:51:50 - OpenVPN > VERIFY KU OK
. 2017.08.26 01:51:50 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 01:51:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 01:51:50 - OpenVPN > VERIFY EKU OK
. 2017.08.26 01:51:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 01:51:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 01:51:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 01:51:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 01:51:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 01:51:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 01:54:32 - Updating systems & servers data ...
. 2017.08.26 01:54:33 - Systems & servers data update completed
. 2017.08.26 02:04:34 - Updating systems & servers data ...
. 2017.08.26 02:04:35 - Systems & servers data update completed
. 2017.08.26 02:14:36 - Updating systems & servers data ...
. 2017.08.26 02:14:37 - Systems & servers data update completed
. 2017.08.26 02:24:38 - Updating systems & servers data ...
. 2017.08.26 02:24:39 - Systems & servers data update completed
. 2017.08.26 02:34:41 - Updating systems & servers data ...
. 2017.08.26 02:34:42 - Systems & servers data update completed
. 2017.08.26 02:44:44 - Updating systems & servers data ...
. 2017.08.26 02:44:45 - Systems & servers data update completed
. 2017.08.26 02:51:50 - OpenVPN > TLS: soft reset sec=0 bytes=451278991/-1 pkts=468817/0
. 2017.08.26 02:51:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 02:51:50 - OpenVPN > Validating certificate key usage
. 2017.08.26 02:51:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 02:51:50 - OpenVPN > VERIFY KU OK
. 2017.08.26 02:51:50 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 02:51:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 02:51:50 - OpenVPN > VERIFY EKU OK
. 2017.08.26 02:51:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 02:51:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 02:51:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 02:51:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 02:51:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 02:51:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 02:54:47 - Updating systems & servers data ...
. 2017.08.26 02:54:48 - Systems & servers data update completed
. 2017.08.26 03:04:51 - Updating systems & servers data ...
. 2017.08.26 03:04:52 - Systems & servers data update completed
. 2017.08.26 03:14:54 - Updating systems & servers data ...
. 2017.08.26 03:14:55 - Systems & servers data update completed
. 2017.08.26 03:24:57 - Updating systems & servers data ...
. 2017.08.26 03:24:59 - Systems & servers data update completed
. 2017.08.26 03:35:01 - Updating systems & servers data ...
. 2017.08.26 03:35:02 - Systems & servers data update completed
. 2017.08.26 03:45:04 - Updating systems & servers data ...
. 2017.08.26 03:45:05 - Systems & servers data update completed
. 2017.08.26 03:51:50 - OpenVPN > TLS: soft reset sec=0 bytes=15174877/-1 pkts=20691/0
. 2017.08.26 03:51:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 03:51:50 - OpenVPN > Validating certificate key usage
. 2017.08.26 03:51:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 03:51:50 - OpenVPN > VERIFY KU OK
. 2017.08.26 03:51:50 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 03:51:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 03:51:50 - OpenVPN > VERIFY EKU OK
. 2017.08.26 03:51:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 03:51:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 03:51:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 03:51:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 03:51:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 03:51:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 03:55:07 - Updating systems & servers data ...
. 2017.08.26 03:55:08 - Systems & servers data update completed
. 2017.08.26 04:05:10 - Updating systems & servers data ...
. 2017.08.26 04:05:12 - Systems & servers data update completed
. 2017.08.26 04:15:14 - Updating systems & servers data ...
. 2017.08.26 04:15:15 - Systems & servers data update completed
. 2017.08.26 04:25:17 - Updating systems & servers data ...
. 2017.08.26 04:25:18 - Systems & servers data update completed
. 2017.08.26 04:35:21 - Updating systems & servers data ...
. 2017.08.26 04:35:22 - Systems & servers data update completed
. 2017.08.26 04:45:24 - Updating systems & servers data ...
. 2017.08.26 04:45:25 - Systems & servers data update completed
. 2017.08.26 04:51:50 - OpenVPN > TLS: soft reset sec=0 bytes=28089957/-1 pkts=34108/0
. 2017.08.26 04:51:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 04:51:50 - OpenVPN > Validating certificate key usage
. 2017.08.26 04:51:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 04:51:50 - OpenVPN > VERIFY KU OK
. 2017.08.26 04:51:50 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 04:51:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 04:51:50 - OpenVPN > VERIFY EKU OK
. 2017.08.26 04:51:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 04:51:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 04:51:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 04:51:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 04:51:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 04:51:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 04:55:27 - Updating systems & servers data ...
. 2017.08.26 04:55:28 - Systems & servers data update completed
. 2017.08.26 05:05:30 - Updating systems & servers data ...
. 2017.08.26 05:05:31 - Systems & servers data update completed
. 2017.08.26 05:15:33 - Updating systems & servers data ...
. 2017.08.26 05:15:35 - Systems & servers data update completed
. 2017.08.26 05:25:37 - Updating systems & servers data ...
. 2017.08.26 05:25:38 - Systems & servers data update completed
. 2017.08.26 05:35:40 - Updating systems & servers data ...
. 2017.08.26 05:35:41 - Systems & servers data update completed
. 2017.08.26 05:45:44 - Updating systems & servers data ...
. 2017.08.26 05:45:45 - Systems & servers data update completed
. 2017.08.26 05:51:50 - OpenVPN > TLS: soft reset sec=0 bytes=72534261/-1 pkts=88808/0
. 2017.08.26 05:51:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 05:51:50 - OpenVPN > Validating certificate key usage
. 2017.08.26 05:51:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 05:51:50 - OpenVPN > VERIFY KU OK
. 2017.08.26 05:51:50 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 05:51:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 05:51:50 - OpenVPN > VERIFY EKU OK
. 2017.08.26 05:51:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 05:51:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 05:51:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 05:51:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 05:51:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 05:51:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 05:55:47 - Updating systems & servers data ...
. 2017.08.26 05:55:48 - Systems & servers data update completed
. 2017.08.26 06:05:50 - Updating systems & servers data ...
. 2017.08.26 06:05:51 - Systems & servers data update completed
. 2017.08.26 06:15:53 - Updating systems & servers data ...
. 2017.08.26 06:15:54 - Systems & servers data update completed
. 2017.08.26 06:25:56 - Updating systems & servers data ...
. 2017.08.26 06:25:59 - Systems & servers data update completed
. 2017.08.26 06:36:01 - Updating systems & servers data ...
. 2017.08.26 06:36:03 - Systems & servers data update completed
. 2017.08.26 06:46:04 - Updating systems & servers data ...
. 2017.08.26 06:46:06 - Systems & servers data update completed
. 2017.08.26 06:51:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 06:51:51 - OpenVPN > Validating certificate key usage
. 2017.08.26 06:51:51 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 06:51:51 - OpenVPN > VERIFY KU OK
. 2017.08.26 06:51:51 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 06:51:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 06:51:51 - OpenVPN > VERIFY EKU OK
. 2017.08.26 06:51:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 06:51:51 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 06:51:51 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 06:51:51 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 06:51:51 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 06:51:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 06:56:07 - Updating systems & servers data ...
. 2017.08.26 06:56:08 - Systems & servers data update completed
. 2017.08.26 07:06:10 - Updating systems & servers data ...
. 2017.08.26 07:06:11 - Systems & servers data update completed
. 2017.08.26 07:16:13 - Updating systems & servers data ...
. 2017.08.26 07:16:14 - Systems & servers data update completed
. 2017.08.26 07:26:16 - Updating systems & servers data ...
. 2017.08.26 07:26:17 - Systems & servers data update completed
. 2017.08.26 07:36:19 - Updating systems & servers data ...
. 2017.08.26 07:36:21 - Systems & servers data update completed
. 2017.08.26 07:46:23 - Updating systems & servers data ...
. 2017.08.26 07:46:24 - Systems & servers data update completed
I 2017.08.26 07:51:50 - Renewing TLS key
. 2017.08.26 07:51:50 - OpenVPN > TLS: tls_process: killed expiring key
. 2017.08.26 07:51:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 07:51:51 - OpenVPN > Validating certificate key usage
. 2017.08.26 07:51:51 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 07:51:51 - OpenVPN > VERIFY KU OK
. 2017.08.26 07:51:51 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 07:51:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 07:51:51 - OpenVPN > VERIFY EKU OK
. 2017.08.26 07:51:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 07:51:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 07:51:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 07:51:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 07:51:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 07:51:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 07:56:26 - Updating systems & servers data ...
. 2017.08.26 07:56:27 - Systems & servers data update completed
. 2017.08.26 08:06:29 - Updating systems & servers data ...
. 2017.08.26 08:06:31 - Systems & servers data update completed
. 2017.08.26 08:16:33 - Updating systems & servers data ...
. 2017.08.26 08:16:34 - Systems & servers data update completed
. 2017.08.26 08:26:36 - Updating systems & servers data ...
. 2017.08.26 08:26:37 - Systems & servers data update completed
. 2017.08.26 08:36:39 - Updating systems & servers data ...
. 2017.08.26 08:36:41 - Systems & servers data update completed
. 2017.08.26 08:46:43 - Updating systems & servers data ...
. 2017.08.26 08:46:44 - Systems & servers data update completed
. 2017.08.26 08:51:52 - OpenVPN > TLS: soft reset sec=0 bytes=52793562/-1 pkts=56843/0
. 2017.08.26 08:51:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 08:51:52 - OpenVPN > Validating certificate key usage
. 2017.08.26 08:51:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 08:51:52 - OpenVPN > VERIFY KU OK
. 2017.08.26 08:51:52 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 08:51:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 08:51:52 - OpenVPN > VERIFY EKU OK
. 2017.08.26 08:51:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 08:51:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 08:51:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 08:51:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 08:51:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 08:51:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 08:56:46 - Updating systems & servers data ...
. 2017.08.26 08:56:47 - Systems & servers data update completed
. 2017.08.26 09:06:49 - Updating systems & servers data ...
. 2017.08.26 09:06:50 - Systems & servers data update completed
. 2017.08.26 09:16:52 - Updating systems & servers data ...
. 2017.08.26 09:16:53 - Systems & servers data update completed
. 2017.08.26 09:26:55 - Updating systems & servers data ...
. 2017.08.26 09:26:56 - Systems & servers data update completed
. 2017.08.26 09:36:58 - Updating systems & servers data ...
. 2017.08.26 09:36:59 - Systems & servers data update completed
. 2017.08.26 09:47:01 - Updating systems & servers data ...
. 2017.08.26 09:47:02 - Systems & servers data update completed
. 2017.08.26 09:51:52 - OpenVPN > TLS: soft reset sec=0 bytes=67398871/-1 pkts=72434/0
. 2017.08.26 09:51:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 09:51:52 - OpenVPN > Validating certificate key usage
. 2017.08.26 09:51:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 09:51:52 - OpenVPN > VERIFY KU OK
. 2017.08.26 09:51:52 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 09:51:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 09:51:52 - OpenVPN > VERIFY EKU OK
. 2017.08.26 09:51:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 09:51:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 09:51:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 09:51:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 09:51:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 09:51:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 09:57:05 - Updating systems & servers data ...
. 2017.08.26 09:57:06 - Systems & servers data update completed
. 2017.08.26 10:07:08 - Updating systems & servers data ...
. 2017.08.26 10:07:09 - Systems & servers data update completed
. 2017.08.26 10:17:11 - Updating systems & servers data ...
. 2017.08.26 10:17:12 - Systems & servers data update completed
. 2017.08.26 10:27:14 - Updating systems & servers data ...
. 2017.08.26 10:27:15 - Systems & servers data update completed
. 2017.08.26 10:37:17 - Updating systems & servers data ...
. 2017.08.26 10:37:18 - Systems & servers data update completed
. 2017.08.26 10:47:20 - Updating systems & servers data ...
. 2017.08.26 10:47:21 - Systems & servers data update completed
. 2017.08.26 10:51:52 - OpenVPN > TLS: soft reset sec=0 bytes=722967/-1 pkts=2063/0
. 2017.08.26 10:51:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 10:51:52 - OpenVPN > Validating certificate key usage
. 2017.08.26 10:51:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 10:51:52 - OpenVPN > VERIFY KU OK
. 2017.08.26 10:51:52 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 10:51:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 10:51:52 - OpenVPN > VERIFY EKU OK
. 2017.08.26 10:51:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 10:51:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 10:51:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 10:51:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 10:51:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 10:51:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 10:57:23 - Updating systems & servers data ...
. 2017.08.26 10:57:24 - Systems & servers data update completed
. 2017.08.26 11:07:26 - Updating systems & servers data ...
. 2017.08.26 11:07:27 - Systems & servers data update completed
. 2017.08.26 11:17:30 - Updating systems & servers data ...
. 2017.08.26 11:17:31 - Systems & servers data update completed
. 2017.08.26 11:27:32 - Updating systems & servers data ...
. 2017.08.26 11:27:34 - Systems & servers data update completed
. 2017.08.26 11:37:36 - Updating systems & servers data ...
. 2017.08.26 11:37:37 - Systems & servers data update completed
. 2017.08.26 11:47:38 - Updating systems & servers data ...
. 2017.08.26 11:47:39 - Systems & servers data update completed
. 2017.08.26 11:51:52 - OpenVPN > TLS: soft reset sec=0 bytes=238386504/-1 pkts=273249/0
. 2017.08.26 11:51:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 11:51:52 - OpenVPN > Validating certificate key usage
. 2017.08.26 11:51:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 11:51:52 - OpenVPN > VERIFY KU OK
. 2017.08.26 11:51:52 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 11:51:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 11:51:52 - OpenVPN > VERIFY EKU OK
. 2017.08.26 11:51:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 11:51:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 11:51:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 11:51:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 11:51:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 11:51:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 11:57:41 - Updating systems & servers data ...
. 2017.08.26 11:57:42 - Systems & servers data update completed
. 2017.08.26 12:07:43 - Updating systems & servers data ...
. 2017.08.26 12:07:44 - Systems & servers data update completed
. 2017.08.26 12:17:45 - Updating systems & servers data ...
. 2017.08.26 12:17:46 - Systems & servers data update completed
. 2017.08.26 12:27:47 - Updating systems & servers data ...
. 2017.08.26 12:27:48 - Systems & servers data update completed
. 2017.08.26 12:37:49 - Updating systems & servers data ...
. 2017.08.26 12:37:50 - Systems & servers data update completed
. 2017.08.26 12:47:52 - Updating systems & servers data ...
. 2017.08.26 12:47:53 - Systems & servers data update completed
. 2017.08.26 12:51:52 - OpenVPN > TLS: soft reset sec=0 bytes=477540978/-1 pkts=503710/0
. 2017.08.26 12:51:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 12:51:52 - OpenVPN > Validating certificate key usage
. 2017.08.26 12:51:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 12:51:52 - OpenVPN > VERIFY KU OK
. 2017.08.26 12:51:52 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 12:51:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 12:51:52 - OpenVPN > VERIFY EKU OK
. 2017.08.26 12:51:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 12:51:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 12:51:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 12:51:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 12:51:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 12:51:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 12:57:54 - Updating systems & servers data ...
. 2017.08.26 12:57:55 - Systems & servers data update completed
. 2017.08.26 13:07:56 - Updating systems & servers data ...
. 2017.08.26 13:07:57 - Systems & servers data update completed
. 2017.08.26 13:17:58 - Updating systems & servers data ...
. 2017.08.26 13:17:59 - Systems & servers data update completed
. 2017.08.26 13:28:00 - Updating systems & servers data ...
. 2017.08.26 13:28:01 - Systems & servers data update completed
. 2017.08.26 13:38:03 - Updating systems & servers data ...
. 2017.08.26 13:38:04 - Systems & servers data update completed
. 2017.08.26 13:48:05 - Updating systems & servers data ...
. 2017.08.26 13:48:06 - Systems & servers data update completed
. 2017.08.26 13:51:52 - OpenVPN > TLS: soft reset sec=0 bytes=331758102/-1 pkts=358180/0
. 2017.08.26 13:51:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 13:51:52 - OpenVPN > Validating certificate key usage
. 2017.08.26 13:51:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 13:51:52 - OpenVPN > VERIFY KU OK
. 2017.08.26 13:51:52 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 13:51:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 13:51:52 - OpenVPN > VERIFY EKU OK
. 2017.08.26 13:51:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 13:51:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 13:51:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 13:51:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 13:51:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 13:51:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 13:58:08 - Updating systems & servers data ...
. 2017.08.26 13:58:09 - Systems & servers data update completed
. 2017.08.26 14:08:11 - Updating systems & servers data ...
. 2017.08.26 14:08:12 - Systems & servers data update completed
. 2017.08.26 14:18:13 - Updating systems & servers data ...
. 2017.08.26 14:18:14 - Systems & servers data update completed
. 2017.08.26 14:28:16 - Updating systems & servers data ...
. 2017.08.26 14:28:17 - Systems & servers data update completed
. 2017.08.26 14:38:19 - Updating systems & servers data ...
. 2017.08.26 14:38:20 - Systems & servers data update completed
. 2017.08.26 14:48:22 - Updating systems & servers data ...
. 2017.08.26 14:48:23 - Systems & servers data update completed
. 2017.08.26 14:51:52 - OpenVPN > TLS: soft reset sec=0 bytes=293806865/-1 pkts=340232/0
. 2017.08.26 14:51:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 14:51:52 - OpenVPN > Validating certificate key usage
. 2017.08.26 14:51:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 14:51:52 - OpenVPN > VERIFY KU OK
. 2017.08.26 14:51:52 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 14:51:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 14:51:52 - OpenVPN > VERIFY EKU OK
. 2017.08.26 14:51:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 14:51:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 14:51:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 14:51:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 14:51:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 14:51:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 14:58:24 - Updating systems & servers data ...
. 2017.08.26 14:58:25 - Systems & servers data update completed
. 2017.08.26 15:08:27 - Updating systems & servers data ...
. 2017.08.26 15:08:28 - Systems & servers data update completed
. 2017.08.26 15:18:29 - Updating systems & servers data ...
. 2017.08.26 15:18:30 - Systems & servers data update completed
. 2017.08.26 15:28:32 - Updating systems & servers data ...
. 2017.08.26 15:28:36 - Systems & servers data update completed
. 2017.08.26 15:38:37 - Updating systems & servers data ...
. 2017.08.26 15:38:39 - Systems & servers data update completed
. 2017.08.26 15:48:41 - Updating systems & servers data ...
. 2017.08.26 15:48:43 - Systems & servers data update completed
. 2017.08.26 15:51:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 15:51:52 - OpenVPN > Validating certificate key usage
. 2017.08.26 15:51:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 15:51:52 - OpenVPN > VERIFY KU OK
. 2017.08.26 15:51:52 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 15:51:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 15:51:52 - OpenVPN > VERIFY EKU OK
. 2017.08.26 15:51:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.08.26 15:51:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 15:51:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 15:51:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.08.26 15:51:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 15:51:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 15:58:45 - Updating systems & servers data ...
. 2017.08.26 15:58:47 - Systems & servers data update completed
. 2017.08.26 16:08:49 - Updating systems & servers data ...
. 2017.08.26 16:08:50 - Systems & servers data update completed
! 2017.08.26 16:12:53 - Disconnecting
. 2017.08.26 16:12:53 - Management - Send 'signal SIGTERM'
. 2017.08.26 16:12:53 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.08.26 16:12:53 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.08.26 16:12:58 - OpenVPN > C:\Windows\system32\route.exe DELETE 149.255.33.154 MASK 255.255.255.255 192.168.1.1
. 2017.08.26 16:12:58 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.08.26 16:12:58 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.08.26 16:12:58 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.08.26 16:12:58 - Connection terminated.
. 2017.08.26 16:12:58 - OpenVPN > Closing TUN/TAP interface
. 2017.08.26 16:12:58 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.08.26 16:12:58 - DNS leak protection with packet filtering disabled.
. 2017.08.26 16:12:58 - IPv6 restored with packet filtering.
. 2017.08.26 16:12:58 - Flushing DNS
! 2017.08.26 16:13:01 - Session terminated.
I 2017.08.26 16:13:04 - Session starting.
. 2017.08.26 16:13:04 - IPv6 disabled with packet filtering.
I 2017.08.26 16:13:04 - Checking authorization ...
! 2017.08.26 16:13:06 - Connecting to Aquarius (United States, Chicago, Illinois)
. 2017.08.26 16:13:08 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.08.26 16:13:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.08.26 16:13:08 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.08.26 16:13:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.08.26 16:13:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 16:13:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 16:13:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]173.234.62.154:443
. 2017.08.26 16:13:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.08.26 16:13:08 - OpenVPN > UDP link local: (not bound)
. 2017.08.26 16:13:08 - OpenVPN > UDP link remote: [AF_INET]173.234.62.154:443
. 2017.08.26 16:13:08 - OpenVPN > TLS: Initial packet from [AF_INET]173.234.62.154:443, sid=31dc958b 0d7d1bdc
. 2017.08.26 16:13:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 16:13:09 - OpenVPN > Validating certificate key usage
. 2017.08.26 16:13:09 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 16:13:09 - OpenVPN > VERIFY KU OK
. 2017.08.26 16:13:09 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 16:13:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 16:13:09 - OpenVPN > VERIFY EKU OK
. 2017.08.26 16:13:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aquarius, emailAddress=info@airvpn.org
. 2017.08.26 16:13:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 16:13:11 - OpenVPN > [Aquarius] Peer Connection Initiated with [AF_INET]173.234.62.154:443
. 2017.08.26 16:13:12 - OpenVPN > SENT CONTROL [Aquarius]: 'PUSH_REQUEST' (status=1)
. 2017.08.26 16:13:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.76 255.255.0.0,peer-id 25,cipher AES-256-GCM'
. 2017.08.26 16:13:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.08.26 16:13:13 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.08.26 16:13:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.08.26 16:13:13 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.08.26 16:13:13 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.08.26 16:13:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.08.26 16:13:13 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.08.26 16:13:13 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.08.26 16:13:13 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.08.26 16:13:13 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 16:13:13 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 16:13:13 - OpenVPN > interactive service msg_channel=0
. 2017.08.26 16:13:13 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=70:4d:7b:2a:05:45
. 2017.08.26 16:13:13 - OpenVPN > open_tun
. 2017.08.26 16:13:13 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{E6C7AC27-83A8-42EE-8D92-CC53D71D0D86}.tap
. 2017.08.26 16:13:13 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.08.26 16:13:13 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.0.76/255.255.0.0 [SUCCEEDED]
. 2017.08.26 16:13:13 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.0.76/255.255.0.0 on interface {E6C7AC27-83A8-42EE-8D92-CC53D71D0D86} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.08.26 16:13:13 - OpenVPN > Successful ARP Flush on interface [14] {E6C7AC27-83A8-42EE-8D92-CC53D71D0D86}
. 2017.08.26 16:13:13 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.08.26 16:13:18 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.08.26 16:13:18 - OpenVPN > C:\Windows\system32\route.exe ADD 173.234.62.154 MASK 255.255.255.255 192.168.1.1
. 2017.08.26 16:13:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2017.08.26 16:13:18 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.08.26 16:13:18 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.08.26 16:13:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.08.26 16:13:18 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.08.26 16:13:18 - Starting Management Interface
. 2017.08.26 16:13:18 - OpenVPN > Initialization Sequence Completed
. 2017.08.26 16:13:18 - DNS leak protection with packet filtering enabled.
. 2017.08.26 16:13:18 - Flushing DNS
I 2017.08.26 16:13:21 - Checking route
I 2017.08.26 16:13:34 - Checking DNS
! 2017.08.26 16:13:53 - Connected.
. 2017.08.26 16:13:53 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.08.26 16:13:53 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.08.26 16:18:52 - Updating systems & servers data ...
. 2017.08.26 16:18:55 - Systems & servers data update completed
. 2017.08.26 16:28:57 - Updating systems & servers data ...
. 2017.08.26 16:28:58 - Systems & servers data update completed
. 2017.08.26 16:39:00 - Updating systems & servers data ...
. 2017.08.26 16:39:01 - Systems & servers data update completed
. 2017.08.26 16:49:03 - Updating systems & servers data ...
. 2017.08.26 16:49:04 - Systems & servers data update completed
. 2017.08.26 16:59:06 - Updating systems & servers data ...
. 2017.08.26 16:59:07 - Systems & servers data update completed
. 2017.08.26 17:09:09 - Updating systems & servers data ...
. 2017.08.26 17:09:11 - Systems & servers data update completed
. 2017.08.26 17:13:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 17:13:11 - OpenVPN > Validating certificate key usage
. 2017.08.26 17:13:11 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 17:13:11 - OpenVPN > VERIFY KU OK
. 2017.08.26 17:13:11 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 17:13:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 17:13:11 - OpenVPN > VERIFY EKU OK
. 2017.08.26 17:13:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aquarius, emailAddress=info@airvpn.org
. 2017.08.26 17:13:11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 17:13:11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 17:13:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 17:19:13 - Updating systems & servers data ...
. 2017.08.26 17:19:14 - Systems & servers data update completed
. 2017.08.26 17:23:33 - Updating systems & servers data ...
. 2017.08.26 17:23:34 - Systems & servers data update completed
! 2017.08.26 17:23:39 - Disconnecting
. 2017.08.26 17:23:39 - Management - Send 'signal SIGTERM'
. 2017.08.26 17:23:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.08.26 17:23:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.08.26 17:23:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 173.234.62.154 MASK 255.255.255.255 192.168.1.1
. 2017.08.26 17:23:44 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.08.26 17:23:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.08.26 17:23:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.08.26 17:23:44 - OpenVPN > Closing TUN/TAP interface
. 2017.08.26 17:23:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.08.26 17:23:44 - Connection terminated.
. 2017.08.26 17:23:44 - DNS leak protection with packet filtering disabled.
I 2017.08.26 17:23:44 - Checking authorization ...
! 2017.08.26 17:23:44 - Connecting to Miaplacidus (United States, Newark, New Jersey)
. 2017.08.26 17:23:44 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.08.26 17:23:44 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.08.26 17:23:44 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.08.26 17:23:44 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.08.26 17:23:44 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 17:23:44 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.08.26 17:23:44 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]173.234.159.194:443
. 2017.08.26 17:23:44 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.08.26 17:23:44 - OpenVPN > UDP link local: (not bound)
. 2017.08.26 17:23:44 - OpenVPN > UDP link remote: [AF_INET]173.234.159.194:443
. 2017.08.26 17:23:45 - OpenVPN > TLS: Initial packet from [AF_INET]173.234.159.194:443, sid=02327a97 e243e050
. 2017.08.26 17:23:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 17:23:45 - OpenVPN > Validating certificate key usage
. 2017.08.26 17:23:45 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 17:23:45 - OpenVPN > VERIFY KU OK
. 2017.08.26 17:23:45 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 17:23:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 17:23:45 - OpenVPN > VERIFY EKU OK
. 2017.08.26 17:23:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Miaplacidus, emailAddress=info@airvpn.org
. 2017.08.26 17:23:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 17:23:45 - OpenVPN > [Miaplacidus] Peer Connection Initiated with [AF_INET]173.234.159.194:443
. 2017.08.26 17:23:46 - OpenVPN > SENT CONTROL [Miaplacidus]: 'PUSH_REQUEST' (status=1)
. 2017.08.26 17:23:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.235 255.255.0.0,peer-id 67,cipher AES-256-GCM'
. 2017.08.26 17:23:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.08.26 17:23:46 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.08.26 17:23:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.08.26 17:23:46 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.08.26 17:23:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.08.26 17:23:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.08.26 17:23:46 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.08.26 17:23:46 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.08.26 17:23:46 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.08.26 17:23:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 17:23:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 17:23:46 - OpenVPN > interactive service msg_channel=0
. 2017.08.26 17:23:46 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=70:4d:7b:2a:05:45
. 2017.08.26 17:23:46 - OpenVPN > open_tun
. 2017.08.26 17:23:46 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{E6C7AC27-83A8-42EE-8D92-CC53D71D0D86}.tap
. 2017.08.26 17:23:46 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.08.26 17:23:46 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.235/255.255.0.0 [SUCCEEDED]
. 2017.08.26 17:23:46 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.235/255.255.0.0 on interface {E6C7AC27-83A8-42EE-8D92-CC53D71D0D86} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.08.26 17:23:46 - OpenVPN > Successful ARP Flush on interface [14] {E6C7AC27-83A8-42EE-8D92-CC53D71D0D86}
. 2017.08.26 17:23:46 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.08.26 17:23:51 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.08.26 17:23:51 - OpenVPN > C:\Windows\system32\route.exe ADD 173.234.159.194 MASK 255.255.255.255 192.168.1.1
. 2017.08.26 17:23:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2017.08.26 17:23:51 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.08.26 17:23:51 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.08.26 17:23:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.08.26 17:23:51 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.08.26 17:23:51 - Starting Management Interface
. 2017.08.26 17:23:51 - OpenVPN > Initialization Sequence Completed
. 2017.08.26 17:23:52 - DNS leak protection with packet filtering enabled.
. 2017.08.26 17:23:52 - Flushing DNS
I 2017.08.26 17:23:55 - Checking route
I 2017.08.26 17:23:56 - Checking DNS
! 2017.08.26 17:24:08 - Connected.
. 2017.08.26 17:24:08 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.08.26 17:24:08 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.08.26 17:32:51 - Updating systems & servers data ...
. 2017.08.26 17:32:52 - Systems & servers data update completed
. 2017.08.26 17:33:51 - OpenVPN > write UDP: No buffer space available (WSAENOBUFS) (code=10055)
. 2017.08.26 17:42:54 - Updating systems & servers data ...
. 2017.08.26 17:42:55 - Systems & servers data update completed
. 2017.08.26 17:52:57 - Updating systems & servers data ...
. 2017.08.26 17:52:58 - Systems & servers data update completed
. 2017.08.26 18:03:00 - Updating systems & servers data ...
. 2017.08.26 18:03:01 - Systems & servers data update completed
. 2017.08.26 18:13:03 - Updating systems & servers data ...
. 2017.08.26 18:13:04 - Systems & servers data update completed
. 2017.08.26 18:23:06 - Updating systems & servers data ...
. 2017.08.26 18:23:07 - Systems & servers data update completed
. 2017.08.26 18:23:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 18:23:45 - OpenVPN > Validating certificate key usage
. 2017.08.26 18:23:45 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 18:23:45 - OpenVPN > VERIFY KU OK
. 2017.08.26 18:23:45 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 18:23:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 18:23:45 - OpenVPN > VERIFY EKU OK
. 2017.08.26 18:23:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Miaplacidus, emailAddress=info@airvpn.org
. 2017.08.26 18:23:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 18:23:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 18:23:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 18:33:10 - Updating systems & servers data ...
. 2017.08.26 18:33:11 - Systems & servers data update completed
. 2017.08.26 18:43:12 - Updating systems & servers data ...
. 2017.08.26 18:43:13 - Systems & servers data update completed
. 2017.08.26 18:53:15 - Updating systems & servers data ...
. 2017.08.26 18:53:16 - Systems & servers data update completed
. 2017.08.26 19:03:17 - Updating systems & servers data ...
. 2017.08.26 19:03:18 - Systems & servers data update completed
. 2017.08.26 19:13:19 - Updating systems & servers data ...
. 2017.08.26 19:13:20 - Systems & servers data update completed
. 2017.08.26 19:23:22 - Updating systems & servers data ...
. 2017.08.26 19:23:24 - Systems & servers data update completed
. 2017.08.26 19:23:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 19:23:45 - OpenVPN > Validating certificate key usage
. 2017.08.26 19:23:45 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 19:23:45 - OpenVPN > VERIFY KU OK
. 2017.08.26 19:23:45 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 19:23:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 19:23:45 - OpenVPN > VERIFY EKU OK
. 2017.08.26 19:23:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Miaplacidus, emailAddress=info@airvpn.org
. 2017.08.26 19:23:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 19:23:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 19:23:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 19:33:25 - Updating systems & servers data ...
. 2017.08.26 19:33:26 - Systems & servers data update completed
. 2017.08.26 19:43:28 - Updating systems & servers data ...
. 2017.08.26 19:43:29 - Systems & servers data update completed
. 2017.08.26 19:53:30 - Updating systems & servers data ...
. 2017.08.26 19:53:32 - Systems & servers data update completed
. 2017.08.26 20:03:33 - Updating systems & servers data ...
. 2017.08.26 20:03:34 - Systems & servers data update completed
. 2017.08.26 20:13:35 - Updating systems & servers data ...
. 2017.08.26 20:13:36 - Systems & servers data update completed
. 2017.08.26 20:23:37 - Updating systems & servers data ...
. 2017.08.26 20:23:38 - Systems & servers data update completed
I 2017.08.26 20:23:44 - Renewing TLS key
. 2017.08.26 20:23:44 - OpenVPN > TLS: tls_process: killed expiring key
. 2017.08.26 20:23:45 - OpenVPN > TLS: soft reset sec=0 bytes=445464438/-1 pkts=476946/0
. 2017.08.26 20:23:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 20:23:45 - OpenVPN > Validating certificate key usage
. 2017.08.26 20:23:45 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 20:23:45 - OpenVPN > VERIFY KU OK
. 2017.08.26 20:23:45 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 20:23:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 20:23:45 - OpenVPN > VERIFY EKU OK
. 2017.08.26 20:23:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Miaplacidus, emailAddress=info@airvpn.org
. 2017.08.26 20:23:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 20:23:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 20:23:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 20:33:39 - Updating systems & servers data ...
. 2017.08.26 20:33:41 - Systems & servers data update completed
. 2017.08.26 20:43:42 - Updating systems & servers data ...
. 2017.08.26 20:43:43 - Systems & servers data update completed
. 2017.08.26 20:53:45 - Updating systems & servers data ...
. 2017.08.26 20:53:46 - Systems & servers data update completed
. 2017.08.26 21:03:47 - Updating systems & servers data ...
. 2017.08.26 21:03:48 - Systems & servers data update completed
. 2017.08.26 21:13:50 - Updating systems & servers data ...
. 2017.08.26 21:13:51 - Systems & servers data update completed
. 2017.08.26 21:23:45 - OpenVPN > TLS: soft reset sec=0 bytes=794487948/-1 pkts=860245/0
. 2017.08.26 21:23:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.08.26 21:23:45 - OpenVPN > Validating certificate key usage
. 2017.08.26 21:23:45 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.08.26 21:23:45 - OpenVPN > VERIFY KU OK
. 2017.08.26 21:23:45 - OpenVPN > Validating certificate extended key usage
. 2017.08.26 21:23:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.08.26 21:23:45 - OpenVPN > VERIFY EKU OK
. 2017.08.26 21:23:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Miaplacidus, emailAddress=info@airvpn.org
. 2017.08.26 21:23:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 21:23:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.08.26 21:23:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.08.26 21:23:53 - Updating systems & servers data ...
. 2017.08.26 21:23:54 - Systems & servers data update completed
. 2017.08.26 21:33:56 - Updating systems & servers data ...
. 2017.08.26 21:33:57 - Systems & servers data update completed
. 2017.08.26 21:43:58 - Updating systems & servers data ...
. 2017.08.26 21:43:59 - Systems & servers data update completed
. 2017.08.26 21:54:01 - Updating systems & servers data ...
. 2017.08.26 21:54:02 - Systems & servers data update completed
. 2017.08.26 22:04:04 - Updating systems & servers data ...
. 2017.08.26 22:04:05 - Systems & servers data update completed
The Air stats tab should show IP addresses in use, I doubt the one in question will be there. DNS shouldn't enter into this. In firefox, try clicking the "i" in the address bar after connecting to the site and see if location permissions were given.  In the firefox about:config settings, search "geo" and "location" and turn off, especially, "geo.enabled"  Search for that IP address in about:config.  Search for your add ons (aka extensions) and see if IP is there, also in profile (access in Troubleshooting.)  Use private browsing, delete cookies, no 3rd party.  If you deem safe to do so, ask the site what's going on and try a different prepaid card.  Install  O&O shutup!  https://www.oo-software.com/en/shutup10/update which will turn off most Windows tracking. CCleaner has a cookies tab that will show all the cookies on your computer. Windows saves them forever even if ff's are deleted.  Could be there.
you're accessing a service which is "geo-routed" through some of our Germany routing servers.
