einhander
What sndbuf/rcvbuf recommended for my connection ?
hi members ,  i am looking to speed up my connection with Custom Directives if it's possible.  I have noticed a good speedup with changing TCP/UDP send and receive buffer size to 256kb but i may be able to increase my speed a bit more with Directives.
I use UDP 2018 Primary Protocol
My connection is the below
100mbits Download
40mbits Upload
appreciate any help
100mbits Download
40mbits Upload
appreciate any help
You can go up to 512KB in the Eddie settings if you're wanting to try a larger buffer.  Or maybe I misunderstood what you were asking for.
hi ,  i used to use 512kb in Eddie for the TCP/UDP send and receive buffer size but when i decreased it to 256kb i got more speed.  I was wondering if i can use Custom Directives like sndbuf and rcvbuf to get even more speed.  Or those are both the same thing ?
Custom Directives sndbuf and rcvbuf
same thing ?
same thing ?
yes, those are the same thing.
