Jebjoe123
AirVPN not launching
Im currently using Tails 3.0.1 from a USB drive and have installed AirVPN. But every time i go into the applications menu and try to open it, it dosent to anything. Any way to fix this?
EDIT* Been trying to fun the program through the terminal and getting this,
I 2017.07.13 09:06:32 - Eddie client version: 2.12.4 / linux_x64, System: Linux, Name: Debian GNU/Linux 9 \n \l, Mono/.Net Framework: v4.0.30319
. 2017.07.13 09:06:32 - Reading options from /root/.airvpn/AirVPN.xml
. 2017.07.13 09:06:32 - Profile options not found, using defaults.
Unhandled Exception:
System.TypeInitializationException: The type initializer for 'System.Windows.Forms.WindowsFormsSynchronizationContext' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.Net.Sockets.SocketException: Connection refused
  at System.Net.Sockets.Socket.Connect (System.Net.EndPoint remoteEP) [0x000d1] in <bd46d4d4f7964dfa9beea098499ab597>:0
  at System.Windows.Forms.XplatUIX11.SetDisplay (System.IntPtr display_handle) [0x00204] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.XplatUIX11..ctor () [0x00077] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.XplatUIX11.GetInstance () [0x0001c] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.XplatUI..cctor () [0x0007d] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
   --- End of inner exception stack trace ---
  at System.Windows.Forms.Theme.get_MenuAccessKeysUnderlined () [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.SystemInformation.get_MenuAccessKeysUnderlined () [0x00005] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.Control..ctor () [0x000ea] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control:.ctor ()
  at System.Windows.Forms.WindowsFormsSynchronizationContext..cctor () [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_generic_class_init (intptr)
  at System.Windows.Forms.WindowsFormsSynchronizationContext.get_AutoInstall () [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.Control..ctor () [0x00014] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.ScrollableControl..ctor () [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.ContainerControl..ctor () [0x0000e] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.Form..ctor () [0x00012] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.MessageBox+MessageBoxForm..ctor (System.Windows.Forms.IWin32Window owner, System.String text, System.String caption, System.Windows.Forms.MessageBoxButtons buttons, System.Windows.Forms.MessageBoxIcon icon, System.Boolean displayHelpButton) [0x0000c] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at System.Windows.Forms.MessageBox+MessageBoxForm..ctor (System.Windows.Forms.IWin32Window owner, System.String text, System.String caption, System.Windows.Forms.MessageBoxButtons buttons, System.Windows.Forms.MessageBoxIcon icon) [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.MessageBox+MessageBoxForm:.ctor (System.Windows.Forms.IWin32Window,string,string,System.Windows.Forms.MessageBoxButtons,System.Windows.Forms.MessageBoxIcon)
  at System.Windows.Forms.MessageBox.Show (System.String text, System.String caption, System.Windows.Forms.MessageBoxButtons buttons, System.Windows.Forms.MessageBoxIcon icon) [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
  at Eddie.UI.Linux.Program.Main () [0x000c3] in <827d8be374f3486292e08d514075969c>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Windows.Forms.WindowsFormsSynchronizationContext' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.Net.Sockets.SocketException: Connection refused
