here's my idea:
if you are an admin of say a torrent site do not get involved in other activiities that will bring attention to your community.
stop with the bloat code on your websites, adware, scamware etc.
put a link up for your community to be able to 'donate' what they can when they can
might be better to mirror the site to the tor network for the magnets not have that available via clear
so in a way you are running two sites same thing but the tor network has the magnets
maybe put another site up separate from that onion address for the 'forum' community where you probably will need java running for all the admin junk, this way your 'java' site is tor only and separate from your magnet site
hire an attorney if and when you can, if needed so you got some help if something goes wrong as it tends to
if you have enough from donations give some of that back some how, whatever your ethics are, do some kind of good with it
if your site grows beyond your ability, bring someone else in that can handle it and can keep your community safe
drink tons of coffee, like way more than needed
# airvpn irc hidden service stealth mode ssl
# mkdir hidircz
# cd d0wnz
# touch cool.motd
# vim cool.motd
hit 'i' copy paste
text below or your own
custom motd
hit 'esc' key then type ':wq'
____ _ ____ _  _ ___  _  _
|__| | |__/ |  | |__] |\ |
https://airvpn.org
add this to your torrc file
mod for your own config if needed...
VirtualAddrNetwork 10.192.0.0/10
TransPort 9040
DNSPort 53
AutomapHostsOnResolve 1
##hidden service
HiddenServiceDir /var/lib/tor/
HiddenServicePort 6697 127.0.0.1:6697
HiddenServiceAuthorizeClient stealth IRCvisitor
HidServAuth newtorsitenamehere.onion stealthpasshere
you'll start tor and then stop tor to get your hidden service
hostname and authorization cookie, this 'cookie' is in the hostname
/var/lib/tor
looks like this:
newtorsitenamehere.onion yourauthcookieherebruh # client: IRCvisitor
now remember in the torrc file below the port you created the 'IRCvisitor'
without this information from /var/lib/tor added to the torrc file in the example
above you cannot access the irc server or if it were http you can not access it
even from the box hosting the irc/http server
the advantage to stealth mode is this: it is NOT listed in the tor directory
and if anything goes wrong with your irc server or you just want to create another openssl req -x509 -sha256 -newkey rsa:2048 -keyout ~/d0wnz/ircpriv.pem -out ~/d0wnz/ircert.pem -days 1024 -nodes -subj '/CN=irc.z4ojdtiaqvdfi4ys.onion'
'domain' no problem, you are not tied to anything, and anyone accessing your site/chat
has to have contacted you to get the authorization cookie
from hidircz directory...
# openssl req -x509 -sha256 -newkey rsa:2048 -keyout /root/hidrircz/ircpriv.pem -out /root/hidircz/ircert.pem -days 1024 -nodes -subj '/CN=irc.newtorsitenamehere.onion'
# cat /root/hidircz/ircpriv.pem > hidz.pem
# cat /root/hidircz/ircert.pem >> hidz.pem
here's the python script....
#! /usr/bin/env python
# https://github.com/jrosdahl/miniircd
# Joel Rosdahl <joel@rosdahl.net>
# pacman -S python-pyopenssl if needed
import logging
import os
import re
import select
import socket
import string
import sys
import tempfile
import time
from datetime import datetime
from logging.handlers import RotatingFileHandler
from optparse import OptionParser
VERSION = "1.2.1"
PY3 = sys.version_info[0] >= 3
if PY3:
    def buffer_to_socket(msg):
        return msg.encode()
    def socket_to_buffer(buf):
        return buf.decode()
else:
        return msg
        return buf
def create_directory(path):
    if not os.path.isdir(path):
        os.makedirs(path)
class Channel(object):
    def __init__(self, server, name):
        self.server = server
        self.name = name
        self.members = set()
        self._topic = ""
        self._key = None
        if self.server.state_dir:
            self._state_path = "%s/%s" % (
                self.server.state_dir,
                name.replace("_", "__").replace("/", "_"))
            self._read_state()
        else:
            self._state_path = None
    def add_member(self, client):
        self.members.add(client)
    def get_topic(self):
        return self._topic
    def set_topic(self, value):
        self._topic = value
        self._write_state()
    topic = property(get_topic, set_topic)
    def get_key(self):
        return self._key
    def set_key(self, value):
        self._key = value
        self._write_state()
    key = property(get_key, set_key)
    def remove_client(self, client):
        self.members.discard(client)
        if not self.members:
            self.server.remove_channel(self)
    def _read_state(self):
        if not (self._state_path and os.path.exists(self._state_path)):
            return
        data = {}
        with open(self._state_path, "rb") as state_file:
            exec(state_file.read(), {}, data)
        self._topic = data.get("topic", "")
        self._key = data.get("key")
    def _write_state(self):
        if not self._state_path:
            return
        (fd, path) = tempfile.mkstemp(dir=os.path.dirname(self._state_path))
        fp = os.fdopen(fd, "w")
        fp.write("topic = %r\n" % self.topic)
        fp.write("key = %r\n" % self.key)
        fp.close()
        os.rename(path, self._state_path)
class Client(object):
    __linesep_regexp = re.compile(r"\r?\n")
    # The RFC limit for nicknames is 9 characters, but what the heck.
    __valid_nickname_regexp = re.compile(
        r"^[][\`_^{|}A-Za-z][][\`_^{|}A-Za-z0-9-]{0,50}$")
    __valid_channelname_regexp = re.compile(
        r"^[+!][^\x00\x07\x0a\x0d ,:]{0,50}$")
    def __init__(self, server, socket):
        self.socket = socket
        self.channels = {}  # irc_lower(Channel name) --> Channel
        self.nickname = None
        self.user = None
        self.realname = None
        (self.host, self.port) = socket.getpeername()
        self.__timestamp = time.time()
        self.__readbuffer = ""
        self.__writebuffer = ""
        self.__sent_ping = False
        if self.server.password:
            self.__handle_command = self.__pass_handler
        else:
            self.__handle_command = self.__registration_handler
    def get_prefix(self):
        return "%s!%s@%s" % (self.nickname, self.user, self.host)
    prefix = property(get_prefix)
    def check_aliveness(self):
        now = time.time()
        if self.__timestamp + 180 < now:
            self.disconnect("ping timeout")
            return
        if not self.__sent_ping and self.__timestamp + 90 < now:
            if self.__handle_command == self.__command_handler:
                # Registered.
                self.message("PING :%s" % self.server.name)
                self.__sent_ping = True
            else:
                # Not registered.
    def write_queue_size(self):
        return len(self.__writebuffer)
    def __parse_read_buffer(self):
        lines = self.__linesep_regexp.split(self.__readbuffer)
        self.__readbuffer = lines[-1]
        lines = lines[:-1]
        for line in lines:
            if not line:
                # Empty line. Ignore.
                continue
            x = line.split(" ", 1)
            command = x[0].upper()
            if len(x) == 1:
                arguments = []
            else:
                if len(x[1]) > 0 and x[1][0] == ":":
                    arguments = [x[1][1:]]
                else:
                    y = x[1].split(" :", 1)
                    arguments = y[0].split()
                    if len(y) == 2:
                        arguments.append(y[1])
            self.__handle_command(command, arguments)
    def __pass_handler(self, command, arguments):
        server = self.server
        if command == "PASS":
            if len(arguments) == 0:
                self.reply_461("PASS")
            else:
                if arguments[0].lower() == server.password:
                else:
                    self.reply("464 :Password incorrect")
        elif command == "QUIT":
            self.disconnect("Client quit")
            return
    def __registration_handler(self, command, arguments):
        if command == "NICK":
            if len(arguments) < 1:
                self.reply("431 :No nickname given")
                return
            nick = arguments[0]
            if server.get_client(nick):
                self.reply("433 * %s :Nickname is already in use" % nick)
            elif not self.__valid_nickname_regexp.match(nick):
                self.reply("432 * %s :Erroneous nickname" % nick)
            else:
                self.nickname = nick
                server.client_changed_nickname(self, None)
        elif command == "USER":
            if len(arguments) < 4:
                self.reply_461("USER")
                return
            self.user = arguments[0]
            self.realname = arguments[3]
            return
        if self.nickname and self.user:
            self.reply("001 %s :Hi, welcome to IRC" % self.nickname)
            self.reply("002 %s :Your host is %s, running version miniircd-%s"
                       % (self.nickname, server.name, VERSION))
            self.reply("003 %s :This server was created sometime"
                       % self.nickname)
            self.reply("004 %s %s miniircd-%s o o"
            self.send_lusers()
            self.send_motd()
            self.__handle_command = self.__command_handler
    def __send_names(self, arguments, for_join=False):
        valid_channel_re = self.__valid_channelname_regexp
        if len(arguments) > 0:
            channelnames = arguments[0].split(",")
        else:
            channelnames = sorted(self.channels.keys())
        if len(arguments) > 1:
            keys = arguments[1].split(",")
        else:
            keys = []
        keys.extend((len(channelnames) - len(keys)) * [None])
        for (i, channelname) in enumerate(channelnames):
            if for_join and irc_lower(channelname) in self.channels:
                continue
            if not valid_channel_re.match(channelname):
                self.reply_403(channelname)
                continue
            channel = server.get_channel(channelname)
            if channel.key is not None and channel.key != keys[i]:
                self.reply(
                    "475 %s %s :Cannot join channel (+k) - bad key"
                    % (self.nickname, channelname))
                continue
            if for_join:
                channel.add_member(self)
                self.channels[irc_lower(channelname)] = channel
                self.message_channel(channel, "JOIN", channelname, True)
                self.channel_log(channel, "joined", meta=True)
                if channel.topic:
                    self.reply("332 %s %s :%s"
                               % (self.nickname, channel.name, channel.topic))
                else:
                    self.reply("331 %s %s :No topic is set"
                               % (self.nickname, channel.name))
            names_prefix = "353 %s = %s :" % (self.nickname, channelname)
            names = ""
            # Max length: reply prefix ":server_name(space)" plus CRLF in
            # the end.
            names_max_len = 512 - (len(server.name) + 2 + 2)
            for name in sorted(x.nickname for x in channel.members):
                if not names:
                    names = names_prefix + name
                # Using >= to include the space between "names" and "name".
                elif len(names) + len(name) >= names_max_len:
                    self.reply(names)
                else:
                    names += " " + name
            if names:
                self.reply(names)
            self.reply("366 %s %s :End of NAMES list"
    def __command_handler(self, command, arguments):
        def away_handler():
            pass
        def ison_handler():
                self.reply_461("ISON")
                return
            nicks = arguments
            online = [n for n in nicks if server.get_client(n)]
            self.reply("303 %s :%s" % (self.nickname, " ".join(online)))
        def join_handler():
                self.reply_461("JOIN")
                return
            if arguments[0] == "0":
                for (channelname, channel) in self.channels.items():
                    self.message_channel(channel, "PART", channelname, True)
                    self.channel_log(channel, "left", meta=True)
                    server.remove_member_from_channel(self, channelname)
                self.channels = {}
                return
            self.__send_names(arguments, for_join=True)
        def list_handler():
                channels = server.channels.values()
            else:
                channels = []
                for channelname in arguments[0].split(","):
                    if server.has_channel(channelname):
                        channels.append(server.get_channel(channelname))
            sorted_channels = sorted(channels, key=lambda x: x.name)
            for channel in sorted_channels:
                self.reply("322 %s %s %d :%s"
                              len(channel.members), channel.topic))
            self.reply("323 %s :End of LIST" % self.nickname)
        def lusers_handler():
            self.send_lusers()
        def mode_handler():
                self.reply_461("MODE")
                return
            targetname = arguments[0]
            if server.has_channel(targetname):
                channel = server.get_channel(targetname)
                if len(arguments) < 2:
                    if channel.key:
                        modes = "+k"
                        if irc_lower(channel.name) in self.channels:
                            modes += " %s" % channel.key
                    else:
                        modes = "+"
                    self.reply("324 %s %s %s"
                               % (self.nickname, targetname, modes))
                    return
                flag = arguments[1]
                if flag == "+k":
                    if len(arguments) < 3:
                        return
                    key = arguments[2]
                        channel.key = key
                            channel, "MODE", "%s +k %s" % (channel.name, key),
                            True)
                        self.channel_log(
                            channel, "set channel key to %s" % key, meta=True)
                    else:
                        self.reply("442 %s :You're not on that channel"
                                   % targetname)
                elif flag == "-k":
                        channel.key = None
                            channel, "MODE", "%s -k" % channel.name,
                            True)
                        self.channel_log(
                            channel, "removed channel key", meta=True)
                    else:
                                   % targetname)
                else:
                    self.reply("472 %s %s :Unknown MODE flag"
                               % (self.nickname, flag))
            elif targetname == self.nickname:
                if len(arguments) == 1:
                    self.reply("221 %s +" % self.nickname)
                else:
                    self.reply("501 %s :Unknown MODE flag" % self.nickname)
            else:
                self.reply_403(targetname)
        def motd_handler():
            self.send_motd()
        def names_handler():
            self.__send_names(arguments)
        def nick_handler():
                return
            newnick = arguments[0]
            client = server.get_client(newnick)
            if newnick == self.nickname:
                pass
            elif client and client is not self:
                self.reply("433 %s %s :Nickname is already in use"
                           % (self.nickname, newnick))
            elif not self.__valid_nickname_regexp.match(newnick):
                self.reply("432 %s %s :Erroneous Nickname"
            else:
                for x in self.channels.values():
                    self.channel_log(
                        x, "changed nickname to %s" % newnick, meta=True)
                oldnickname = self.nickname
                self.nickname = newnick
                server.client_changed_nickname(self, oldnickname)
                self.message_related(
                    ":%s!%s@%s NICK %s"
                    % (oldnickname, self.user, self.host, self.nickname),
                    True)
        def notice_and_privmsg_handler():
                self.reply("411 %s :No recipient given (%s)"
                           % (self.nickname, command))
                return
                self.reply("412 %s :No text to send" % self.nickname)
                return
            message = arguments[1]
            client = server.get_client(targetname)
            if client:
                client.message(":%s %s %s :%s"
                               % (self.prefix, command, targetname, message))
            elif server.has_channel(targetname):
                    channel, command, "%s :%s" % (channel.name, message))
                self.channel_log(channel, message)
            else:
                self.reply("401 %s %s :No such nick/channel"
                           % (self.nickname, targetname))
        def part_handler():
                self.reply_461("PART")
                return
                partmsg = arguments[1]
            else:
                partmsg = self.nickname
                elif not irc_lower(channelname) in self.channels:
                    self.reply("442 %s %s :You're not on that channel"
                else:
                    channel = self.channels[irc_lower(channelname)]
                        channel, "PART", "%s :%s" % (channelname, partmsg),
                        True)
                    self.channel_log(channel, "left (%s)" % partmsg, meta=True)
                    del self.channels[irc_lower(channelname)]
        def ping_handler():
                self.reply("409 %s :No origin specified" % self.nickname)
                return
            self.reply("PONG %s :%s" % (server.name, arguments[0]))
        def pong_handler():
            pass
        def quit_handler():
                quitmsg = self.nickname
            else:
                quitmsg = arguments[0]
            self.disconnect(quitmsg)
        def topic_handler():
                self.reply_461("TOPIC")
                return
            channelname = arguments[0]
            channel = self.channels.get(irc_lower(channelname))
            if channel:
                    newtopic = arguments[1]
                    channel.topic = newtopic
                        channel, "TOPIC", "%s :%s" % (channelname, newtopic),
                        True)
                    self.channel_log(
                        channel, "set topic to %r" % newtopic, meta=True)
                else:
                    if channel.topic:
                                      channel.topic))
                    else:
            else:
                self.reply("442 %s :You're not on that channel" % channelname)
        def wallops_handler():
                self.reply_461("WALLOPS")
                return
            message = arguments[0]
            for client in server.clients.values():
                client.message(":%s NOTICE %s :Global notice: %s"
                               % (self.prefix, client.nickname, message))
        def who_handler():
                return
                for member in channel.members:
                    self.reply("352 %s %s %s %s %s %s H :0 %s"
                               % (self.nickname, targetname, member.user,
                                  member.host, server.name, member.nickname,
                                  member.realname))
                self.reply("315 %s %s :End of WHO list"
        def whois_handler():
                return
            username = arguments[0]
            user = server.get_client(username)
            if user:
                self.reply("311 %s %s %s %s * :%s"
                           % (self.nickname, user.nickname, user.user,
                              user.host, user.realname))
                self.reply("312 %s %s %s :%s"
                           % (self.nickname, user.nickname, server.name,
                              server.name))
                self.reply("319 %s %s :%s"
                              " ".join(user.channels)))
                self.reply("318 %s %s :End of WHOIS list"
                           % (self.nickname, user.nickname))
            else:
                self.reply("401 %s %s :No such nick"
                           % (self.nickname, username))
        handler_table = {
            "AWAY": away_handler,
            "ISON": ison_handler,
            "JOIN": join_handler,
            "LIST": list_handler,
            "LUSERS": lusers_handler,
            "MODE": mode_handler,
            "MOTD": motd_handler,
            "NAMES": names_handler,
            "NICK": nick_handler,
            "NOTICE": notice_and_privmsg_handler,
            "PART": part_handler,
            "PING": ping_handler,
            "PONG": pong_handler,
            "PRIVMSG": notice_and_privmsg_handler,
            "QUIT": quit_handler,
            "TOPIC": topic_handler,
            "WALLOPS": wallops_handler,
            "WHO": who_handler,
            "WHOIS": whois_handler,
        try:
            handler_table[command]()
        except KeyError:
            self.reply("421 %s %s :Unknown command" % (self.nickname, command))
    def socket_readable_notification(self):
        try:
            data = self.socket.recv(2 ** 10)
            self.server.print_debug(
                "[%s:%d] -> %r" % (self.host, self.port, data))
            quitmsg = "EOT"
        except socket.error as x:
            data = ""
            quitmsg = x
        if data:
            self.__readbuffer += socket_to_buffer(data)
            self.__parse_read_buffer()
        else:
    def socket_writable_notification(self):
        try:
            sent = self.socket.send(buffer_to_socket(self.__writebuffer))
                "[%s:%d] <- %r" % (
                    self.host, self.port, self.__writebuffer[:sent]))
            self.__writebuffer = self.__writebuffer[sent:]
            self.disconnect(x)
    def disconnect(self, quitmsg):
        self.message("ERROR :%s" % quitmsg)
        self.server.print_info(
            "Disconnected connection from %s:%s (%s)." % (
                self.host, self.port, quitmsg))
        self.socket.close()
        self.server.remove_client(self, quitmsg)
    def message(self, msg):
        self.__writebuffer += msg + "\r\n"
    def reply(self, msg):
        self.message(":%s %s" % (self.server.name, msg))
    def reply_403(self, channel):
        self.reply("403 %s %s :No such channel" % (self.nickname, channel))
    def reply_461(self, command):
        nickname = self.nickname or "*"
        self.reply("461 %s %s :Not enough parameters" % (nickname, command))
    def message_channel(self, channel, command, message, include_self=False):
        line = ":%s %s %s" % (self.prefix, command, message)
        for client in channel.members:
            if client != self or include_self:
                client.message(line)
    def channel_log(self, channel, message, meta=False):
        if not self.server.channel_log_dir:
            return
        if meta:
            format = "[%s] * %s %s\n"
        else:
            format = "[%s] <%s> %s\n"
        timestamp = datetime.utcnow().strftime("%Y-%m-%d %H:%M:%S UTC")
        logname = channel.name.replace("_", "__").replace("/", "_")
        fp = open("%s/%s.log" % (self.server.channel_log_dir, logname), "a")
        fp.write(format % (timestamp, self.nickname, message))
        fp.close()
    def message_related(self, msg, include_self=False):
        clients = set()
        if include_self:
            clients.add(self)
        for channel in self.channels.values():
            clients |= channel.members
        if not include_self:
            clients.discard(self)
        for client in clients:
            client.message(msg)
    def send_lusers(self):
        self.reply("251 %s :There are %d users and 0 services on 1 server"
                   % (self.nickname, len(self.server.clients)))
    def send_motd(self):
        motdlines = server.get_motd_lines()
        if motdlines:
            self.reply("375 %s :- %s Message of the day -"
                       % (self.nickname, server.name))
            for line in motdlines:
                self.reply("372 %s :- %s" % (self.nickname, line.rstrip()))
            self.reply("376 %s :End of /MOTD command" % self.nickname)
        else:
            self.reply("422 %s :MOTD File is missing" % self.nickname)
class Server(object):
    def __init__(self, options):
        self.ports = options.ports
        self.password = options.password
        self.ssl_pem_file = options.ssl_pem_file
        self.motdfile = options.motd
        self.verbose = options.verbose
        self.debug = options.debug
        self.channel_log_dir = options.channel_log_dir
        self.chroot = options.chroot
        self.setuid = options.setuid
        self.state_dir = options.state_dir
        self.log_file = options.log_file
        self.log_max_bytes = options.log_max_size * 1024 * 1024
        self.log_count = options.log_count
        self.logger = None
        if options.password_file:
            with open(options.password_file, "r") as fp:
                self.password = fp.read().strip("\n")
        if self.ssl_pem_file:
            self.ssl = __import__("ssl")
        # Find certificate after daemonization if path is relative:
        if self.ssl_pem_file and os.path.exists(self.ssl_pem_file):
            self.ssl_pem_file = os.path.abspath(self.ssl_pem_file)
        # else: might exist in the chroot jail, so just continue
        if options.listen:
            self.address = socket.gethostbyname(options.listen)
        else:
            self.address = ""
        server_name_limit = 63  # From the RFC.
        self.name = socket.getfqdn(self.address)[:server_name_limit]
        self.channels = {}  # irc_lower(Channel name) --> Channel instance.
        self.clients = {}  # Socket --> Client instance.
        self.nicknames = {}  # irc_lower(Nickname) --> Client instance.
        if self.channel_log_dir:
            create_directory(self.channel_log_dir)
        if self.state_dir:
            create_directory(self.state_dir)
    def make_pid_file(self, filename):
        try:
            fd = os.open(filename, os.O_RDWR | os.O_CREAT | os.O_EXCL, 0o644)
            os.write(fd, "%i\n" % os.getpid())
            os.close(fd)
        except:
            self.print_error("Could not create PID file %r" % filename)
            sys.exit(1)
    def daemonize(self):
        try:
            pid = os.fork()
            if pid > 0:
                sys.exit(0)
        except OSError:
            sys.exit(1)
        os.setsid()
        try:
            pid = os.fork()
            if pid > 0:
                self.print_info("PID: %d" % pid)
                sys.exit(0)
        except OSError:
            sys.exit(1)
        os.chdir("/")
        os.umask(0)
        dev_null = open("/dev/null", "r+")
        os.dup2(dev_null.fileno(), sys.stdout.fileno())
        os.dup2(dev_null.fileno(), sys.stderr.fileno())
        os.dup2(dev_null.fileno(), sys.stdin.fileno())
    def get_client(self, nickname):
        return self.nicknames.get(irc_lower(nickname))
    def has_channel(self, name):
        return irc_lower(name) in self.channels
    def get_channel(self, channelname):
        if irc_lower(channelname) in self.channels:
        else:
            channel = Channel(self, channelname)
        return channel
    def get_motd_lines(self):
        if self.motdfile:
            try:
                return open(self.motdfile).readlines()
            except IOError:
                return ["Could not read MOTD file %r." % self.motdfile]
        else:
            return []
    def print_info(self, msg):
        if self.verbose:
            print(msg)
            sys.stdout.flush()
        if self.logger:
            self.logger.info(msg)
    def print_debug(self, msg):
        if self.debug:
            print(msg)
            sys.stdout.flush()
        if self.logger:
            self.logger.debug(msg)
    def print_error(self, msg):
        sys.stderr.write("%s\n" % msg)
        if self.logger:
            self.logger.error(msg)
    def client_changed_nickname(self, client, oldnickname):
        if oldnickname:
            del self.nicknames[irc_lower(oldnickname)]
        self.nicknames[irc_lower(client.nickname)] = client
    def remove_member_from_channel(self, client, channelname):
            channel.remove_client(client)
    def remove_client(self, client, quitmsg):
        client.message_related(":%s QUIT :%s" % (client.prefix, quitmsg))
        for x in client.channels.values():
            client.channel_log(x, "quit (%s)" % quitmsg, meta=True)
            x.remove_client(client)
        if client.nickname \
                and irc_lower(client.nickname) in self.nicknames:
            del self.nicknames[irc_lower(client.nickname)]
        del self.clients[client.socket]
    def remove_channel(self, channel):
        del self.channels[irc_lower(channel.name)]
    def start(self):
        serversockets = []
        for port in self.ports:
            s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
            s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
            try:
                s.bind((self.address, port))
            except socket.error as e:
                self.print_error("Could not bind port %s: %s." % (port, e))
                sys.exit(1)
            s.listen(5)
            serversockets.append(s)
            del s
            self.print_info("Listening on port %d." % port)
        if self.chroot:
            os.chdir(self.chroot)
            os.chroot(self.chroot)
            self.print_info("Changed root directory to %s" % self.chroot)
        if self.setuid:
            os.setgid(self.setuid[1])
            os.setuid(self.setuid[0])
            self.print_info("Setting uid:gid to %s:%s"
                            % (self.setuid[0], self.setuid[1]))
        self.init_logging()
        try:
            self.run(serversockets)
        except:
            if self.logger:
                self.logger.exception("Fatal exception")
            raise
    def init_logging(self):
        if not self.log_file:
            return
        log_level = logging.INFO
        if self.debug:
            log_level = logging.DEBUG
        self.logger = logging.getLogger("miniircd")
        formatter = logging.Formatter(
            ("%(asctime)s - %(name)s[%(process)d] - "
             "%(levelname)s - %(message)s"))
        fh = RotatingFileHandler(
            self.log_file,
            maxBytes=self.log_max_bytes,
            backupCount=self.log_count)
        fh.setLevel(log_level)
        fh.setFormatter(formatter)
        self.logger.setLevel(log_level)
        self.logger.addHandler(fh)
    def run(self, serversockets):
        last_aliveness_check = time.time()
        while True:
            (iwtd, owtd, ewtd) = select.select(
                serversockets + [x.socket for x in self.clients.values()],
                 if x.write_queue_size() > 0],
                10)
            for x in iwtd:
                if x in self.clients:
                    self.clients[x].socket_readable_notification()
                else:
                    (conn, addr) = x.accept()
                        try:
                            conn = self.ssl.wrap_socket(
                                conn,
                                server_side=True,
                                certfile=self.ssl_pem_file,
                                keyfile=self.ssl_pem_file)
                        except Exception as e:
                            self.print_error(
                                "SSL error for connection from %s:%s: %s" % (
                                    addr[0], addr[1], e))
                            continue
                    try:
                        self.clients[conn] = Client(self, conn)
                        self.print_info("Accepted connection from %s:%s." % (
                            addr[0], addr[1]))
                        try:
                            conn.close()
                        except:
                            pass
            for x in owtd:
                if x in self.clients:  # client may have been disconnected
                    self.clients[x].socket_writable_notification()
            now = time.time()
            if last_aliveness_check + 10 < now:
                for client in list(self.clients.values()):
                    client.check_aliveness()
                last_aliveness_check = now
_maketrans = str.maketrans if PY3 else string.maketrans
_ircstring_translation = _maketrans(
    string.ascii_lowercase.upper() + "[]\\^",
    string.ascii_lowercase + "{}|~")
def irc_lower(s):
    return s.translate(_ircstring_translation)
def main(argv):
    op = OptionParser(
        version=VERSION,
        description="miniircd is a small and limited IRC server.")
    op.add_option(
        "--channel-log-dir",
        metavar="X",
        help="store channel log in directory X")
    op.add_option(
        "-d", "--daemon",
        action="store_true",
        help="fork and become a daemon")
    op.add_option(
        "--debug",
        help="print debug messages to stdout")
    op.add_option(
        "--listen",
        metavar="X",
        help="listen on specific IP address X")
    op.add_option(
        "--log-count",
        metavar="X", default=10, type="int",
        help="keep X log files; default: %default")
    op.add_option(
        "--log-file",
        metavar="X",
        help="store log in file X")
    op.add_option(
        "--log-max-size",
        help="set maximum log file size to X MiB; default: %default MiB")
    op.add_option(
        "--motd",
        metavar="X",
        help="display file X as message of the day")
    op.add_option(
        "--pid-file",
        metavar="X",
        help="write PID to file X")
    op.add_option(
        "-p", "--password",
        metavar="X",
        help="require connection password X; default: no password")
    op.add_option(
        "--password-file",
        metavar="X",
        help=("require connection password stored in file X;"
              " default: no password"))
    op.add_option(
        "--ports",
        metavar="X",
        help="listen to ports X (a list separated by comma or whitespace);"
             " default: 6667 or 6697 if SSL is enabled")
    op.add_option(
        "-s", "--ssl-pem-file",
        metavar="FILE",
        help="enable SSL and use FILE as the .pem certificate+key")
    op.add_option(
        "--state-dir",
        metavar="X",
        help="save persistent channel state (topic, key) in directory X")
    op.add_option(
        "--verbose",
        help="be verbose (print some progress messages to stdout)")
    if os.name == "posix":
        op.add_option(
            "--chroot",
            metavar="X",
            help="change filesystem root to directory X after startup"
                 " (requires root)")
        op.add_option(
            "--setuid",
            metavar="U[:G]",
            help="change process user (and optionally group) after startup"
                 " (requires root)")
    else:
        op.chroot = False
        op.setuid = False
    (options, args) = op.parse_args(argv[1:])
    if options.debug:
        options.verbose = True
    if options.ports is None:
        if options.ssl_pem_file is None:
            options.ports = "6667"
        else:
            options.ports = "6697"
    if options.chroot:
        if os.getuid() != 0:
            op.error("Must be root to use --chroot")
    if options.setuid:
        from pwd import getpwnam
        from grp import getgrnam
            op.error("Must be root to use --setuid")
        matches = options.setuid.split(":")
        if len(matches) == 2:
            options.setuid = (getpwnam(matches[0]).pw_uid,
                              getgrnam(matches[1]).gr_gid)
        elif len(matches) == 1:
                              getpwnam(matches[0]).pw_gid)
        else:
            op.error("Specify a user, or user and group separated by a colon,"
                     " e.g. --setuid daemon, --setuid nobody:nobody")
    if (os.getuid() == 0 or os.getgid() == 0) and not options.setuid:
        op.error("Running this service as root is not recommended. Use the"
                 " --setuid option to switch to an unprivileged account after"
                 " startup. If you really intend to run as root, use"
                 " \"--setuid root\".")
    ports = []
    for port in re.split(r"[,\s]+", options.ports):
        try:
            ports.append(int(port))
        except ValueError:
            op.error("bad port: %r" % port)
    options.ports = ports
    server = Server(options)
    if options.daemon:
        server.daemonize()
    if options.pid_file:
        server.make_pid_file(options.pid_file)
    try:
        server.start()
    except KeyboardInterrupt:
        server.print_error("Interrupted.")
main(sys.argv)
top of the script don't think needed just in case
ya might add 'import ssl'
on github the python file is named a bit different
to start the script save it as example: minircd.py
chmod +x the script
as root from hidircz directory with your pem file and motd file:
# python minircd.py --ssl-pem-file=/root/hidircz/hidz.pem --listen 127.0.0.1 --motd=huh.motd --setuid=root
i didn't test this out but to run the script as non root ya might need change directory to say /home/nonrootuser
move everything there, chown -R nonroot:nonroot all the files
so ssl doesn't gripe about an error i might be wrong on this fyi
to get help with the irc server:
# python minircd.py -h
i forgot to mention to start tor at least on arch:
# /usr/bin/tor -f /etc/tor/torrc
so now you have a irc tor chat server up in stealth mode
plus an additional layer of ssl
the clients say via irssi can connect as follows:
# socat TCP4-LISTEN:8000,reuseaddr,fork SOCKS4a:127.0.0.1:newtorsitenamehere.onion:6697,socksport=9050
you don't add the 'irc' in front of the 'domain' just the onion address without 'irc'
then launch irssi and to connect
/connect -ssl 127.0.0.1 8000
you can create a room join chat typical irc stuff
anything done as /whois will show localhost no ip info
for pidgin users little different but not much...
basic tab is irc protocol
yer user name
server is the tor address without 'irc'
advanced tab
port 6697
proxy tab...
proxy is http
host 127.0.0.1 port 8118
start privoxy before connecting:
# /usr/bin/privoxy --no-daemon /etc/privoxy/config
here is my privoxy config:
# Generally, this file goes in /etc/privoxy/config
# unfucked config by cm0s 010117
# to start /usr/bin/privoxy --no-dameon /etc/privoxy/config
# Tor listens as a SOCKS4a proxy here:
forward-socks5 / 127.0.0.1:9050 .
# confz
confdir /etc/privoxy
logdir /var/log/privoxy
# actionsfile standard  # Internal purpose, recommended
actionsfile default.action   # Main actions file
actionsfile user.action      # User customizations
filterfile default.filter
# timeout shit
keep-alive-timeout 600
# mohr timeout shit
default-server-timeout 600
# yet mohhhrrr...
socket-timeout 600
# Don't log interesting things, only startup messages, warnings and errors
logfile logfile
#jarfile jarfile
#debug   0    # show each GET/POST/CONNECT request
debug   4096 # Startup banner and warnings
debug   8192 # Errors - *we highly recommended enabling this*
user-manual /usr/share/doc/privoxy/user-manual
listen-address  localhost:8118
toggle  1
enable-remote-toggle 0
enable-edit-actions 0
enable-remote-http-toggle 0
buffer-limit 4096
a quick side note:
make sure logging is off in pidgin and also the otr plugin
so recap, ya just launched your very own irc chat server
can make your own motd, publish your otr key add whatever custom
stuff ya want and ya really made it private coz it's in stealth mode
stealth mode tor is NOT listed in the tor directory and even if someone
finds your onion address they can't do anything, won't even let them
scan your address without the auth cookie, and you added another layer of ssl
cheerz
splif
Edited ... by MOD-Q-BRUH
What's killing Torrent sites is the overuse of adblock software.  That's to be expected, given the type of outfits willing to advertise on a torrent site, but that's the situation.  Big article on Torrentzfreaks a while back where they interviewed some struggling site owners and the consensus was that donations don't work (some had tried it) and adblocking software posed a much bigger threat than anything governments have been doing.
a magnet is a txt file
not much overhead there
adware on a torrent site means a 3rd party
has access to your site's traffic
that by itself is the biggest liability to a torrent
site's security
you can hit github, get a magnet scraper, scrape your favorite torrent site
and put all the magents up on one single page on a site somewhere for next to
nothing
i got a couple magnets up on my site, cost me zero to add them, few minutes of time
and drinking too much coffee
