Not connected, Your IP: 216.73.216.82
AHUB
ANSWERED When i connect to Belgium, ipleak.net show UK
When I connect to the Belgian server, Ipleak tells me that I'm connected from the UK.
How can i fix this?
~Ahub
When I connect with the Belgian server, airvpn tells me that I'm connected from the UKW
I assume that you are in the UK? Is it your IP address or your DNS which is showing the UK? How are you connecting to the VPN?
I am not in the UK.
Then don't worry, it might be a geolocation database error, not "fixable" directly. You are indeed connected to Belgium.
Sent via Tapatalk. Means, I don't have a computer available now.
I come for the same; almost send a email ...
It's a bug so or a sort of relay/spoof ?
