Not connected, Your IP: 216.73.216.13
kyrusdemnati
air vpn qnap 4.3.3 how do i get it to work as a client (openvpn) - previous firmware worked
tick "use default gateway on remote network"
works for "me"
greets
did you follow any guide? any links
i will try and also does your disconnect often?
at the moment mines connects but then often disconnects..
