nattor
Restart Issue Connecting to Servers
Hey guys , new VPN and Air user here , unable to connect to any server without getting the "Restarting ... 3 seconds" message. Running Windows 10 , log :
I 2017.05.07 10:54:29 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 10.0.15063.0, Mono/.Net Framework: v4.0.30319
. 2017.05.07 10:54:29 - Reading options from C:\Users\Danro\AppData\Local\AirVPN\AirVPN.xml
. 2017.05.07 10:54:30 - Data path: C:\Users\Danro\AppData\Local\AirVPN
. 2017.05.07 10:54:30 - Application path: C:\Program Files\AirVPN
. 2017.05.07 10:54:30 - Executable path: C:\Program Files\AirVPN\AirVPN.exe
. 2017.05.07 10:54:30 - Command line arguments (1): path="home"
. 2017.05.07 10:54:30 - Operating System: Microsoft Windows NT 10.0.15063.0
I 2017.05.07 10:54:33 - OpenVPN Driver - TAP-Win32 Adapter V9 (Tunngle), version 9.21.2
I 2017.05.07 10:54:33 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2017.05.07 10:54:33 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2017.05.07 10:54:33 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
I 2017.05.07 10:54:33 - curl - Version: 7.34.0 (C:\Program Files\AirVPN\curl.exe)
I 2017.05.07 10:54:33 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem
. 2017.05.07 10:54:37 - Updating systems & servers data ...
I 2017.05.07 10:54:37 - Session starting.
. 2017.05.07 10:54:37 - Network adapter DHCP switched to static (Realtek PCIe GBE Family Controller)
. 2017.05.07 10:54:37 - Cannot retrieve systems & servers data. (curl: (56) Recv failure: Connection was reset)
. 2017.05.07 10:54:40 - IPv6 disabled with packet filtering.
I 2017.05.07 10:54:40 - Checking authorization ...
! 2017.05.07 10:54:41 - Connecting to Alkurhah (Canada, Toronto, Ontario)
. 2017.05.07 10:54:41 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.05.07 10:54:41 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.05.07 10:54:41 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.05.07 10:54:41 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.05.07 10:54:41 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 10:54:41 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 10:54:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.202:443
. 2017.05.07 10:54:41 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.05.07 10:54:41 - OpenVPN > UDP link local: (not bound)
. 2017.05.07 10:54:41 - OpenVPN > UDP link remote: [AF_INET]184.75.221.202:443
. 2017.05.07 10:54:41 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.202:443, sid=e3ad9d54 111d860c
. 2017.05.07 10:54:41 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.05.07 10:54:41 - OpenVPN > Validating certificate key usage
. 2017.05.07 10:54:41 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.05.07 10:54:41 - OpenVPN > VERIFY KU OK
. 2017.05.07 10:54:41 - OpenVPN > Validating certificate extended key usage
. 2017.05.07 10:54:41 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.05.07 10:54:41 - OpenVPN > VERIFY EKU OK
. 2017.05.07 10:54:41 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.05.07 10:54:42 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.05.07 10:54:42 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.202:443
. 2017.05.07 10:54:43 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.05.07 10:54:43 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.72.233 255.255.0.0'
. 2017.05.07 10:54:43 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.05.07 10:54:43 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.05.07 10:54:43 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.05.07 10:54:43 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.05.07 10:54:43 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.05.07 10:54:43 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.05.07 10:54:43 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.05.07 10:54:43 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 10:54:43 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.05.07 10:54:43 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 10:54:43 - OpenVPN > interactive service msg_channel=0
. 2017.05.07 10:54:43 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 I=6 HWADDR=4c:cc:6a:6b:30:df
. 2017.05.07 10:54:43 - OpenVPN > open_tun
. 2017.05.07 10:54:43 - OpenVPN > There are no TAP-Windows adapters on this system.  You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter.
. 2017.05.07 10:54:43 - OpenVPN > Exiting due to fatal error
! 2017.05.07 10:54:43 - Disconnecting
. 2017.05.07 10:54:43 - Connection terminated.
I 2017.05.07 10:54:46 - Checking authorization ...
! 2017.05.07 10:54:46 - Connecting to Agena (Canada, Toronto, Ontario)
. 2017.05.07 10:54:46 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.05.07 10:54:46 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.05.07 10:54:46 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.05.07 10:54:46 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.05.07 10:54:46 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 10:54:46 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 10:54:46 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.210:443
. 2017.05.07 10:54:46 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.05.07 10:54:46 - OpenVPN > UDP link local: (not bound)
. 2017.05.07 10:54:46 - OpenVPN > UDP link remote: [AF_INET]184.75.223.210:443
. 2017.05.07 10:54:46 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.210:443, sid=cc5a3e11 5bd9edf1
. 2017.05.07 10:54:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.05.07 10:54:47 - OpenVPN > Validating certificate key usage
. 2017.05.07 10:54:47 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.05.07 10:54:47 - OpenVPN > VERIFY KU OK
. 2017.05.07 10:54:47 - OpenVPN > Validating certificate extended key usage
. 2017.05.07 10:54:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.05.07 10:54:47 - OpenVPN > VERIFY EKU OK
. 2017.05.07 10:54:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.05.07 10:54:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.05.07 10:54:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.210:443
. 2017.05.07 10:54:48 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.05.07 10:54:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.9.190 255.255.0.0'
. 2017.05.07 10:54:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.05.07 10:54:48 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.05.07 10:54:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.05.07 10:54:48 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.05.07 10:54:48 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.05.07 10:54:48 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.05.07 10:54:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.05.07 10:54:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 10:54:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.05.07 10:54:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.07 10:54:48 - OpenVPN > interactive service msg_channel=0
. 2017.05.07 10:54:48 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 I=6 HWADDR=4c:cc:6a:6b:30:df
. 2017.05.07 10:54:48 - OpenVPN > open_tun
. 2017.05.07 10:54:48 - OpenVPN > There are no TAP-Windows adapters on this system.  You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter.
. 2017.05.07 10:54:48 - OpenVPN > Exiting due to fatal error
! 2017.05.07 10:54:48 - Disconnecting
. 2017.05.07 10:54:48 - Connection terminated.
I 2017.05.07 10:54:51 - Cancel requested.
. 2017.05.07 10:54:51 - IPv6 restored with packet filtering.
. 2017.05.07 10:54:51 - DHCP of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
. 2017.05.07 10:54:51 - Flushing DNS
! 2017.05.07 10:54:54 - Session terminated.
These are odd. Would you kindly uninstall all TAP drivers, reboot and then launch Eddie again?
