Has anyone used AirVPN in Mexico with an Apple or Android device?
Will be travelling from USA and am researching VPNs.
Thank you in advance for any replies.
Hi:
I've used Airvpn from Mexico for a couple of years without a problem. To use Apple or Android, you simply install OpenVPN and connect to Air. Should be no problem. There are several servers in the American southwest, connection speeds are excellent. The problem is the Mexican internet services are kind of slow. 10mbs is all I can get in my area, no matter which provider I use - cable or DSL.
