Not connected, Your IP: 216.73.216.63
Rarxlethal
Please help
I use whoer to check if my ip is hidden and it says that the server i am connected to (Alhena) is infected with a s_gozi i am worried that my infor is being logged or omething kinda new to vpns and it also says that the ip address is blacklisted
Servers are not infected and technically cannot be infected by Windows malware since they are not running Windows.
What might be flagged are the exit IPs here and then, because many security researchers use the servers to run malware
samples in virtual machines behind a VPN. This will not compromise your security in any case, just the IP might be flagged
as malicious in few reputation databases.
