Not connected, Your IP: 216.73.216.171
prodek
problem with connection and speed (route check problem ? isp throttling speed ?)
hello everybody i got a problem with my vpn connection, i noticed that my speeds are slow (25mb/s without vpn, less than 1mb/s or sometimes 4mb/s with vpn)and when i try to play any game, csgo for example: my ping jumps + i get choke. This never happened to me. I used openvpn gui to connect to airvpn servers but now i am using eddie, i highlighted what error i get when connecting to a server, although it says that it cant connect to the server it actually connects. Can anybody explain why this error pops up and how to fix it ? i try changing servers but that doesn't work i also tried using different protocols but everytime i get the same error message but from different server. (could they be throttling my (or vpn's) speed ?)
ps: i am at university so i have no idea what kind of security they have here, 3 days ago i think they throttled everybody's internet (might be wrong), i was getting 44mb/s when downloading a game on steam and now i get max 4mb/s, is there anyway to get the same speed back ?
thanks for the help
here are the logs from eddie:
I 2017.04.24 13:13:29 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 6.3.9600.0, Mono/.Net Framework: v4.0.30319
. 2017.04.24 13:13:29 - Reading options from C:\Users\Admin\AppData\Local\AirVPN\AirVPN.xml
. 2017.04.24 13:13:29 - Data path: C:\Users\Admin\AppData\Local\AirVPN
. 2017.04.24 13:13:29 - Application path: C:\Program Files\AirVPN
. 2017.04.24 13:13:29 - Executable path: C:\Program Files\AirVPN\AirVPN.exe
. 2017.04.24 13:13:29 - Command line arguments (1): path="home"
. 2017.04.24 13:13:29 - Operating System: Microsoft Windows NT 6.3.9600.0
I 2017.04.24 13:13:29 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2017.04.24 13:13:29 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2017.04.24 13:13:29 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2017.04.24 13:13:29 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
I 2017.04.24 13:13:29 - curl - Version: 7.34.0 (C:\Program Files\AirVPN\curl.exe)
I 2017.04.24 13:13:29 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem
W 2017.04.24 13:13:29 - Windows WFP, recovery of pending rules.
! 2017.04.24 13:13:29 - Ready
. 2017.04.24 13:13:29 - Updating systems & servers data ...
. 2017.04.24 13:13:30 - Systems & servers data update completed
I 2017.04.24 13:13:31 - Session starting.
. 2017.04.24 13:13:31 - IPv6 disabled with packet filtering.
I 2017.04.24 13:13:33 - Checking authorization ...
! 2017.04.24 13:13:33 - Connecting to Naos (United Kingdom, Manchester)
. 2017.04.24 13:13:33 - SSH > Looking up host "84.39.117.58"
. 2017.04.24 13:13:33 - SSH > Connecting to 84.39.117.58 port 80
. 2017.04.24 13:13:33 - SSH > We claim version: SSH-2.0-PuTTY_Release_0.67
. 2017.04.24 13:13:33 - SSH > Server version: SSH-2.0-OpenSSH_6.7p1 Debian-5+deb8u2
. 2017.04.24 13:13:33 - SSH > Using SSH protocol version 2
. 2017.04.24 13:13:33 - SSH > Doing Diffie-Hellman group exchange
. 2017.04.24 13:13:33 - SSH > Doing Diffie-Hellman key exchange with hash SHA-256
. 2017.04.24 13:13:33 - SSH > Host key fingerprint is:
. 2017.04.24 13:13:33 - SSH > ssh-rsa 2048 19:00:13:df:6d:71:36:38:81:2a:d3:26:6b:9d:78:be
. 2017.04.24 13:13:33 - SSH > The server's host key is not cached in the registry. You
. 2017.04.24 13:13:33 - SSH > have no guarantee that the server is the computer you
. 2017.04.24 13:13:33 - SSH > think it is.
. 2017.04.24 13:13:33 - SSH > The server's rsa2 key fingerprint is:
. 2017.04.24 13:13:33 - SSH > If you trust this host, enter "y" to add the key to
. 2017.04.24 13:13:33 - SSH > PuTTY's cache and carry on connecting.
. 2017.04.24 13:13:33 - SSH > If you want to carry on connecting just once, without
. 2017.04.24 13:13:33 - SSH > adding the key to the cache, enter "n".
. 2017.04.24 13:13:33 - SSH > If you do not trust this host, press Return to abandon the
. 2017.04.24 13:13:33 - SSH > connection.
. 2017.04.24 13:13:33 - SSH > Store key in cache? (y/n) Initialised AES-256 SDCTR client->server encryption
. 2017.04.24 13:13:33 - SSH > Initialised HMAC-SHA-256 client->server MAC algorithm
. 2017.04.24 13:13:33 - SSH > Initialised AES-256 SDCTR server->client encryption
. 2017.04.24 13:13:33 - SSH > Initialised HMAC-SHA-256 server->client MAC algorithm
. 2017.04.24 13:13:33 - SSH > Reading private key file "C:\Users\Admin\AppData\Local\AirVPN\6570eb3d8385f5b8aa6f6d80f725ac7c51b4ff2d4383f492e62e25bde6112911.tmp.ppk"
. 2017.04.24 13:13:33 - SSH > Using username "sshtunnel".
. 2017.04.24 13:13:33 - SSH > Offered public key
. 2017.04.24 13:13:33 - SSH > Offer of public key accepted
. 2017.04.24 13:13:33 - SSH > Authenticating with public key ""
. 2017.04.24 13:13:33 - SSH > Sent public key signature
. 2017.04.24 13:13:33 - SSH > Access granted
. 2017.04.24 13:13:33 - SSH > Local port 18853 forwarding to 127.0.0.1:2018
. 2017.04.24 13:13:33 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.04.24 13:13:33 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.04.24 13:13:33 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.04.24 13:13:33 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.04.24 13:13:33 - SSH > Remote debug message: Pty allocation disabled.
. 2017.04.24 13:13:33 - SSH > Remote debug message: X11 forwarding disabled.
. 2017.04.24 13:13:34 - SSH > Remote debug message: Forced command.
. 2017.04.24 13:13:34 - SSH > Remote debug message: Pty allocation disabled.
. 2017.04.24 13:13:34 - SSH > Remote debug message: X11 forwarding disabled.
. 2017.04.24 13:13:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.24 13:13:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.24 13:13:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:18853
. 2017.04.24 13:13:34 - SSH > Opening connection to 127.0.0.1:2018 for forwarding from 127.0.0.1:53732
. 2017.04.24 13:13:34 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.04.24 13:13:34 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:18853 [nonblock]
. 2017.04.24 13:13:34 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:18853
. 2017.04.24 13:13:34 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2017.04.24 13:13:34 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:18853
. 2017.04.24 13:13:34 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:18853, sid=c5e882ed 69af7174
. 2017.04.24 13:13:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.04.24 13:13:34 - OpenVPN > Validating certificate key usage
. 2017.04.24 13:13:34 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.04.24 13:13:34 - OpenVPN > VERIFY KU OK
. 2017.04.24 13:13:34 - OpenVPN > Validating certificate extended key usage
. 2017.04.24 13:13:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.04.24 13:13:34 - OpenVPN > VERIFY EKU OK
. 2017.04.24 13:13:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.04.24 13:13:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.04.24 13:13:34 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:18853
. 2017.04.24 13:13:35 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.04.24 13:13:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.4.115 255.255.0.0'
. 2017.04.24 13:13:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.04.24 13:13:35 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.04.24 13:13:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.04.24 13:13:35 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.04.24 13:13:35 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.04.24 13:13:35 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.04.24 13:13:35 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.24 13:13:35 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.24 13:13:35 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.24 13:13:35 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.24 13:13:35 - OpenVPN > interactive service msg_channel=0
. 2017.04.24 13:13:35 - OpenVPN > ROUTE_GATEWAY 172.26.64.1/255.255.248.0 I=5 HWADDR=4c:cc:6a:7f:19:0c
. 2017.04.24 13:13:35 - OpenVPN > ROUTE: bypass_host_route[0]=172.17.0.110
. 2017.04.24 13:13:35 - OpenVPN > open_tun
. 2017.04.24 13:13:35 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{105C4A69-F1F6-4BD9-A62B-678959132E3F}.tap
. 2017.04.24 13:13:35 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.04.24 13:13:35 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.4.115/255.255.0.0 [sUCCEEDED]
. 2017.04.24 13:13:35 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.4.115/255.255.0.0 on interface {105C4A69-F1F6-4BD9-A62B-678959132E3F} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2017.04.24 13:13:35 - OpenVPN > Successful ARP Flush on interface [19] {105C4A69-F1F6-4BD9-A62B-678959132E3F}
. 2017.04.24 13:13:35 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.04.24 13:13:40 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2017.04.24 13:13:40 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 172.26.64.1
. 2017.04.24 13:13:40 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.04.24 13:13:40 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.04.24 13:13:40 - OpenVPN > C:\Windows\system32\route.exe ADD 172.17.0.110 MASK 255.255.255.255 172.26.64.1
. 2017.04.24 13:13:40 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2017.04.24 13:13:40 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.04.24 13:13:40 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2017.04.24 13:13:40 - OpenVPN > C:\Windows\system32\route.exe ADD 84.39.117.58 MASK 255.255.255.255 172.26.64.1
. 2017.04.24 13:13:40 - Starting Management Interface
. 2017.04.24 13:13:40 - OpenVPN > Initialization Sequence Completed
. 2017.04.24 13:13:40 - DNS leak protection with packet filtering enabled.
. 2017.04.24 13:13:40 - DNS of a network adapter forced (TAP-Windows Adapter V9, from manual (10.5.0.1) to 10.50.0.1)
. 2017.04.24 13:13:41 - Flushing DNS
I 2017.04.24 13:13:44 - Checking route
E 2017.04.24 13:13:45 - curl: (7) Failed to connect to naos.airservers.org port 89: Connection refused
I 2017.04.24 13:13:45 - Checking DNS
! 2017.04.24 13:13:57 - Connected.
. 2017.04.24 13:13:57 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.04.24 13:13:57 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.04.24 13:23:43 - Updating systems & servers data ...
. 2017.04.24 13:23:43 - Systems & servers data update completed
