Stribog 0 Posted ... Good day. I've just started using the program. At first it worked ok, but the next day it can't connect to any server. It's called connection disconnection loop I guess. Use Windows 7. What can it be? Quote Share this post Link to post
go558a83nk 383 Posted ... you need to post some logs so people can get a clue. you might also check here https://airvpn.org/topic/18339-guide-to-getting-started-links-for-advanced-users/ Quote Share this post Link to post
Guest Posted ... I've been getting the same problem lately. AirVPN gets stuck in a connect/disconnect loop or even just gives up and crashes. Here is latest log. . 2017.04.17 17:23:01 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.17 17:23:01 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561. 2017.04.17 17:23:01 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2017.04.17 17:23:01 - OpenVPN > Opened utun device utun2. 2017.04.17 17:23:01 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.04.17 17:23:01 - OpenVPN > /sbin/ifconfig utun2 delete. 2017.04.17 17:23:01 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2017.04.17 17:23:01 - OpenVPN > /sbin/ifconfig utun2 10.4.1.155 10.4.1.155 netmask 255.255.0.0 mtu 1500 up. 2017.04.17 17:23:01 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.155 255.255.0.0. 2017.04.17 17:23:01 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.155: File exists. 2017.04.17 17:23:01 - OpenVPN > /sbin/route add -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:23:01 - OpenVPN > add net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:23:01 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:01 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:01 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:01 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:01 - Starting Management Interface. 2017.04.17 17:23:01 - OpenVPN > Initialization Sequence Completed. 2017.04.17 17:23:01 - Shell of 'sh','-c 'networksetup -listallnetworkservices | grep -v denotes'' done sync in 33 ms. 2017.04.17 17:23:01 - Shell of 'sh','-c 'networksetup -getdnsservers "DJI CONTROLLER"'' done sync in 31 ms. 2017.04.17 17:23:01 - Shell of 'sh','-c 'networksetup -getdnsservers "Ethernet"'' done sync in 30 msI 2017.04.17 17:23:01 - DNS of a network adapter forced (Ethernet). 2017.04.17 17:23:01 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "10.4.0.1"'' done sync in 33 ms. 2017.04.17 17:23:01 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt FireWire"'' done sync in 31 msI 2017.04.17 17:23:01 - DNS of a network adapter forced (Thunderbolt FireWire). 2017.04.17 17:23:01 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "10.4.0.1"'' done sync in 32 ms. 2017.04.17 17:23:01 - Shell of 'sh','-c 'networksetup -getdnsservers "Wi-Fi"'' done sync in 31 msI 2017.04.17 17:23:01 - DNS of a network adapter forced (Wi-Fi). 2017.04.17 17:23:01 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "10.4.0.1"'' done sync in 33 ms. 2017.04.17 17:23:02 - Shell of 'sh','-c 'networksetup -getdnsservers "Bluetooth PAN"'' done sync in 30 msI 2017.04.17 17:23:02 - DNS of a network adapter forced (Bluetooth PAN). 2017.04.17 17:23:02 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "10.4.0.1"'' done sync in 33 ms. 2017.04.17 17:23:02 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt Bridge"'' done sync in 27 msI 2017.04.17 17:23:02 - DNS of a network adapter forced (Thunderbolt Bridge). 2017.04.17 17:23:02 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "10.4.0.1"'' done sync in 28 msI 2017.04.17 17:23:02 - Flushing DNS. 2017.04.17 17:23:02 - Shell of 'sh','-c 'dscacheutil -flushcache'' done sync in 17 ms. 2017.04.17 17:23:02 - Shell of 'sh','-c 'killall -HUP mDNSResponder'' done sync in 18 ms. 2017.04.17 17:23:02 - Shell of 'sh','-c 'discoveryutil udnsflushcaches'' done sync in 12 msI 2017.04.17 17:23:02 - Checking routeE 2017.04.17 17:23:02 - Routing checking failed.. 2017.04.17 17:23:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3102! 2017.04.17 17:23:02 - Disconnecting. 2017.04.17 17:23:02 - Management - Send 'signal SIGTERM'. 2017.04.17 17:23:02 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.17 17:23:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.17 17:23:02 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.17 17:23:07 - OpenVPN > /sbin/route delete -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:23:07 - OpenVPN > delete net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:23:07 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:07 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:07 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:07 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:07 - OpenVPN > Closing TUN/TAP interface. 2017.04.17 17:23:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.17 17:23:07 - Connection terminated.I 2017.04.17 17:23:07 - DNS of a network adapter restored to original settings (Ethernet). 2017.04.17 17:23:07 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "empty"'' done sync in 34 msI 2017.04.17 17:23:07 - DNS of a network adapter restored to original settings (Thunderbolt FireWire). 2017.04.17 17:23:07 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "empty"'' done sync in 32 msI 2017.04.17 17:23:07 - DNS of a network adapter restored to original settings (Wi-Fi). 2017.04.17 17:23:07 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "empty"'' done sync in 34 msI 2017.04.17 17:23:07 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2017.04.17 17:23:08 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "empty"'' done sync in 32 msI 2017.04.17 17:23:08 - DNS of a network adapter restored to original settings (Thunderbolt Bridge). 2017.04.17 17:23:08 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "empty"'' done sync in 29 msI 2017.04.17 17:23:11 - Checking authorization ...! 2017.04.17 17:23:11 - Connecting to Caelum (Austria, Vienna). 2017.04.17 17:23:11 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2017.04.17 17:23:11 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.04.17 17:23:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3102. 2017.04.17 17:23:11 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.04.17 17:23:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:11 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2017.04.17 17:23:11 - OpenVPN > UDPv4 link local: [undef]. 2017.04.17 17:23:11 - OpenVPN > UDPv4 link remote: [AF_INET]217.64.127.194:443. 2017.04.17 17:23:11 - OpenVPN > TLS: Initial packet from [AF_INET]217.64.127.194:443, sid=12bb623c 0178b279. 2017.04.17 17:23:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.17 17:23:11 - OpenVPN > Validating certificate key usage. 2017.04.17 17:23:11 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.17 17:23:11 - OpenVPN > VERIFY KU OK. 2017.04.17 17:23:11 - OpenVPN > Validating certificate extended key usage. 2017.04.17 17:23:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.17 17:23:11 - OpenVPN > VERIFY EKU OK. 2017.04.17 17:23:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caelum, emailAddress=info@airvpn.org. 2017.04.17 17:23:11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:23:11 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:23:11 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.17 17:23:11 - OpenVPN > [Caelum] Peer Connection Initiated with [AF_INET]217.64.127.194:443. 2017.04.17 17:23:13 - OpenVPN > SENT CONTROL [Caelum]: 'PUSH_REQUEST' (status=1). 2017.04.17 17:23:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.155 255.255.0.0,peer-id 42'. 2017.04.17 17:23:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.17 17:23:13 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.04.17 17:23:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.17 17:23:13 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.17 17:23:13 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.17 17:23:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.17 17:23:13 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.17 17:23:13 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561. 2017.04.17 17:23:13 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2017.04.17 17:23:13 - OpenVPN > Opened utun device utun2. 2017.04.17 17:23:13 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.04.17 17:23:13 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2017.04.17 17:23:13 - OpenVPN > /sbin/ifconfig utun2 delete. 2017.04.17 17:23:13 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2017.04.17 17:23:13 - OpenVPN > route: writing to routing socket: File exists. 2017.04.17 17:23:13 - OpenVPN > /sbin/ifconfig utun2 10.4.1.155 10.4.1.155 netmask 255.255.0.0 mtu 1500 up. 2017.04.17 17:23:13 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.155 255.255.0.0. 2017.04.17 17:23:13 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.155: File exists. 2017.04.17 17:23:13 - OpenVPN > /sbin/route add -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:23:13 - OpenVPN > add net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:23:13 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:13 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:13 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:13 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:13 - Starting Management Interface. 2017.04.17 17:23:13 - OpenVPN > Initialization Sequence Completed. 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -listallnetworkservices | grep -v denotes'' done sync in 31 ms. 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -getdnsservers "DJI CONTROLLER"'' done sync in 30 ms. 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -getdnsservers "Ethernet"'' done sync in 29 msI 2017.04.17 17:23:14 - DNS of a network adapter forced (Ethernet). 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "10.4.0.1"'' done sync in 31 ms. 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt FireWire"'' done sync in 29 msI 2017.04.17 17:23:14 - DNS of a network adapter forced (Thunderbolt FireWire). 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "10.4.0.1"'' done sync in 31 ms. 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -getdnsservers "Wi-Fi"'' done sync in 31 msI 2017.04.17 17:23:14 - DNS of a network adapter forced (Wi-Fi). 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "10.4.0.1"'' done sync in 33 ms. 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -getdnsservers "Bluetooth PAN"'' done sync in 30 msI 2017.04.17 17:23:14 - DNS of a network adapter forced (Bluetooth PAN). 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "10.4.0.1"'' done sync in 33 ms. 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt Bridge"'' done sync in 26 msI 2017.04.17 17:23:14 - DNS of a network adapter forced (Thunderbolt Bridge). 2017.04.17 17:23:14 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "10.4.0.1"'' done sync in 29 msI 2017.04.17 17:23:14 - Flushing DNS. 2017.04.17 17:23:14 - Shell of 'sh','-c 'dscacheutil -flushcache'' done sync in 18 ms. 2017.04.17 17:23:14 - Shell of 'sh','-c 'killall -HUP mDNSResponder'' done sync in 18 ms. 2017.04.17 17:23:14 - Shell of 'sh','-c 'discoveryutil udnsflushcaches'' done sync in 13 msI 2017.04.17 17:23:14 - Checking routeE 2017.04.17 17:23:14 - Routing checking failed.. 2017.04.17 17:23:14 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3102! 2017.04.17 17:23:14 - Disconnecting. 2017.04.17 17:23:14 - Management - Send 'signal SIGTERM'. 2017.04.17 17:23:14 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.17 17:23:14 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.17 17:23:14 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.17 17:23:19 - OpenVPN > /sbin/route delete -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:23:19 - OpenVPN > delete net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:23:19 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:19 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:19 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:19 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:19 - OpenVPN > Closing TUN/TAP interface. 2017.04.17 17:23:19 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.17 17:23:19 - Connection terminated.I 2017.04.17 17:23:19 - DNS of a network adapter restored to original settings (Ethernet). 2017.04.17 17:23:19 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "empty"'' done sync in 32 msI 2017.04.17 17:23:19 - DNS of a network adapter restored to original settings (Thunderbolt FireWire). 2017.04.17 17:23:19 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "empty"'' done sync in 33 msI 2017.04.17 17:23:19 - DNS of a network adapter restored to original settings (Wi-Fi). 2017.04.17 17:23:19 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "empty"'' done sync in 33 msI 2017.04.17 17:23:19 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2017.04.17 17:23:19 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "empty"'' done sync in 32 msI 2017.04.17 17:23:19 - DNS of a network adapter restored to original settings (Thunderbolt Bridge). 2017.04.17 17:23:19 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "empty"'' done sync in 28 msI 2017.04.17 17:23:22 - Checking authorization ...! 2017.04.17 17:23:22 - Connecting to Caelum (Austria, Vienna). 2017.04.17 17:23:22 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2017.04.17 17:23:22 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.04.17 17:23:22 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3102. 2017.04.17 17:23:22 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.04.17 17:23:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:22 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2017.04.17 17:23:22 - OpenVPN > UDPv4 link local: [undef]. 2017.04.17 17:23:22 - OpenVPN > UDPv4 link remote: [AF_INET]217.64.127.194:443. 2017.04.17 17:23:22 - OpenVPN > TLS: Initial packet from [AF_INET]217.64.127.194:443, sid=298f8ac2 f0f2d5c6. 2017.04.17 17:23:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.17 17:23:22 - OpenVPN > Validating certificate key usage. 2017.04.17 17:23:22 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.17 17:23:22 - OpenVPN > VERIFY KU OK. 2017.04.17 17:23:22 - OpenVPN > Validating certificate extended key usage. 2017.04.17 17:23:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.17 17:23:22 - OpenVPN > VERIFY EKU OK. 2017.04.17 17:23:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caelum, emailAddress=info@airvpn.org. 2017.04.17 17:23:23 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:23:23 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:23 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:23:23 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.17 17:23:23 - OpenVPN > [Caelum] Peer Connection Initiated with [AF_INET]217.64.127.194:443. 2017.04.17 17:23:25 - OpenVPN > SENT CONTROL [Caelum]: 'PUSH_REQUEST' (status=1). 2017.04.17 17:23:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.155 255.255.0.0,peer-id 42'. 2017.04.17 17:23:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.17 17:23:25 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2017.04.17 17:23:25 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.04.17 17:23:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.17 17:23:25 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.17 17:23:25 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.17 17:23:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.17 17:23:25 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.17 17:23:25 - OpenVPN > route: writing to routing socket: File exists. 2017.04.17 17:23:25 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561. 2017.04.17 17:23:25 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2017.04.17 17:23:25 - OpenVPN > Opened utun device utun2. 2017.04.17 17:23:25 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.04.17 17:23:25 - OpenVPN > /sbin/ifconfig utun2 delete. 2017.04.17 17:23:25 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2017.04.17 17:23:25 - OpenVPN > /sbin/ifconfig utun2 10.4.1.155 10.4.1.155 netmask 255.255.0.0 mtu 1500 up. 2017.04.17 17:23:25 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.155 255.255.0.0. 2017.04.17 17:23:25 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.155: File exists. 2017.04.17 17:23:25 - OpenVPN > /sbin/route add -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:23:25 - OpenVPN > add net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:23:25 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:25 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:25 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:25 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:25 - Starting Management Interface. 2017.04.17 17:23:25 - OpenVPN > Initialization Sequence Completed. 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -listallnetworkservices | grep -v denotes'' done sync in 31 ms. 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -getdnsservers "DJI CONTROLLER"'' done sync in 36 ms. 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -getdnsservers "Ethernet"'' done sync in 31 msI 2017.04.17 17:23:25 - DNS of a network adapter forced (Ethernet). 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "10.4.0.1"'' done sync in 31 ms. 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt FireWire"'' done sync in 29 msI 2017.04.17 17:23:25 - DNS of a network adapter forced (Thunderbolt FireWire). 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "10.4.0.1"'' done sync in 30 ms. 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -getdnsservers "Wi-Fi"'' done sync in 31 msI 2017.04.17 17:23:25 - DNS of a network adapter forced (Wi-Fi). 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "10.4.0.1"'' done sync in 34 ms. 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -getdnsservers "Bluetooth PAN"'' done sync in 30 msI 2017.04.17 17:23:25 - DNS of a network adapter forced (Bluetooth PAN). 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "10.4.0.1"'' done sync in 32 ms. 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt Bridge"'' done sync in 25 msI 2017.04.17 17:23:25 - DNS of a network adapter forced (Thunderbolt Bridge). 2017.04.17 17:23:25 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "10.4.0.1"'' done sync in 28 msI 2017.04.17 17:23:25 - Flushing DNS. 2017.04.17 17:23:25 - Shell of 'sh','-c 'dscacheutil -flushcache'' done sync in 16 ms. 2017.04.17 17:23:25 - Shell of 'sh','-c 'killall -HUP mDNSResponder'' done sync in 18 ms. 2017.04.17 17:23:25 - Shell of 'sh','-c 'discoveryutil udnsflushcaches'' done sync in 12 msI 2017.04.17 17:23:25 - Checking routeE 2017.04.17 17:23:25 - Routing checking failed.. 2017.04.17 17:23:25 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3102! 2017.04.17 17:23:25 - Disconnecting. 2017.04.17 17:23:26 - Management - Send 'signal SIGTERM'. 2017.04.17 17:23:26 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.17 17:23:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.17 17:23:26 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.17 17:23:31 - OpenVPN > /sbin/route delete -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:23:31 - OpenVPN > delete net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:23:31 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:31 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:31 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:31 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:31 - OpenVPN > Closing TUN/TAP interface. 2017.04.17 17:23:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.17 17:23:31 - Connection terminated.I 2017.04.17 17:23:31 - DNS of a network adapter restored to original settings (Ethernet). 2017.04.17 17:23:31 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "empty"'' done sync in 33 msI 2017.04.17 17:23:31 - DNS of a network adapter restored to original settings (Thunderbolt FireWire). 2017.04.17 17:23:31 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "empty"'' done sync in 32 msI 2017.04.17 17:23:31 - DNS of a network adapter restored to original settings (Wi-Fi). 2017.04.17 17:23:31 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "empty"'' done sync in 35 msI 2017.04.17 17:23:31 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2017.04.17 17:23:31 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "empty"'' done sync in 33 msI 2017.04.17 17:23:31 - DNS of a network adapter restored to original settings (Thunderbolt Bridge). 2017.04.17 17:23:31 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "empty"'' done sync in 27 msI 2017.04.17 17:23:34 - Checking authorization ...! 2017.04.17 17:23:34 - Connecting to Caelum (Austria, Vienna). 2017.04.17 17:23:34 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2017.04.17 17:23:34 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.04.17 17:23:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3102. 2017.04.17 17:23:34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.04.17 17:23:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:34 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2017.04.17 17:23:34 - OpenVPN > UDPv4 link local: [undef]. 2017.04.17 17:23:34 - OpenVPN > UDPv4 link remote: [AF_INET]217.64.127.194:443. 2017.04.17 17:23:34 - OpenVPN > TLS: Initial packet from [AF_INET]217.64.127.194:443, sid=c0813a66 1c1da32f. 2017.04.17 17:23:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.17 17:23:34 - OpenVPN > Validating certificate key usage. 2017.04.17 17:23:34 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.17 17:23:34 - OpenVPN > VERIFY KU OK. 2017.04.17 17:23:34 - OpenVPN > Validating certificate extended key usage. 2017.04.17 17:23:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.17 17:23:34 - OpenVPN > VERIFY EKU OK. 2017.04.17 17:23:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caelum, emailAddress=info@airvpn.org. 2017.04.17 17:23:35 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:23:35 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:35 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:23:35 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:35 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.17 17:23:35 - OpenVPN > [Caelum] Peer Connection Initiated with [AF_INET]217.64.127.194:443. 2017.04.17 17:23:37 - OpenVPN > SENT CONTROL [Caelum]: 'PUSH_REQUEST' (status=1). 2017.04.17 17:23:37 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.155 255.255.0.0,peer-id 42'. 2017.04.17 17:23:37 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.17 17:23:37 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.04.17 17:23:37 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.17 17:23:37 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2017.04.17 17:23:37 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.17 17:23:37 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.17 17:23:37 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.17 17:23:37 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.17 17:23:37 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561. 2017.04.17 17:23:37 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2017.04.17 17:23:37 - OpenVPN > Opened utun device utun2. 2017.04.17 17:23:37 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.04.17 17:23:37 - OpenVPN > /sbin/ifconfig utun2 delete. 2017.04.17 17:23:37 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2017.04.17 17:23:37 - OpenVPN > /sbin/ifconfig utun2 10.4.1.155 10.4.1.155 netmask 255.255.0.0 mtu 1500 up. 2017.04.17 17:23:37 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.155 255.255.0.0. 2017.04.17 17:23:37 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.155: File exists. 2017.04.17 17:23:37 - OpenVPN > route: writing to routing socket: File exists. 2017.04.17 17:23:37 - OpenVPN > /sbin/route add -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:23:37 - OpenVPN > add net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:23:37 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:37 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:37 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:37 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:37 - Starting Management Interface. 2017.04.17 17:23:37 - OpenVPN > Initialization Sequence Completed. 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -listallnetworkservices | grep -v denotes'' done sync in 33 ms. 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -getdnsservers "DJI CONTROLLER"'' done sync in 31 ms. 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -getdnsservers "Ethernet"'' done sync in 31 msI 2017.04.17 17:23:37 - DNS of a network adapter forced (Ethernet). 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "10.4.0.1"'' done sync in 32 ms. 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt FireWire"'' done sync in 30 msI 2017.04.17 17:23:37 - DNS of a network adapter forced (Thunderbolt FireWire). 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "10.4.0.1"'' done sync in 32 ms. 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -getdnsservers "Wi-Fi"'' done sync in 32 msI 2017.04.17 17:23:37 - DNS of a network adapter forced (Wi-Fi). 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "10.4.0.1"'' done sync in 33 ms. 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -getdnsservers "Bluetooth PAN"'' done sync in 30 msI 2017.04.17 17:23:37 - DNS of a network adapter forced (Bluetooth PAN). 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "10.4.0.1"'' done sync in 32 ms. 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt Bridge"'' done sync in 26 msI 2017.04.17 17:23:37 - DNS of a network adapter forced (Thunderbolt Bridge). 2017.04.17 17:23:37 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "10.4.0.1"'' done sync in 28 msI 2017.04.17 17:23:37 - Flushing DNS. 2017.04.17 17:23:37 - Shell of 'sh','-c 'dscacheutil -flushcache'' done sync in 17 ms. 2017.04.17 17:23:37 - Shell of 'sh','-c 'killall -HUP mDNSResponder'' done sync in 17 ms. 2017.04.17 17:23:37 - Shell of 'sh','-c 'discoveryutil udnsflushcaches'' done sync in 12 msI 2017.04.17 17:23:37 - Checking routeE 2017.04.17 17:23:38 - Routing checking failed.. 2017.04.17 17:23:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3102! 2017.04.17 17:23:38 - Disconnecting. 2017.04.17 17:23:38 - Management - Send 'signal SIGTERM'. 2017.04.17 17:23:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.17 17:23:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.17 17:23:38 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.17 17:23:43 - OpenVPN > /sbin/route delete -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:23:43 - OpenVPN > delete net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:23:43 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:43 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:43 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:43 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:43 - OpenVPN > Closing TUN/TAP interface. 2017.04.17 17:23:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.17 17:23:43 - Connection terminated.I 2017.04.17 17:23:43 - DNS of a network adapter restored to original settings (Ethernet). 2017.04.17 17:23:43 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "empty"'' done sync in 33 msI 2017.04.17 17:23:43 - DNS of a network adapter restored to original settings (Thunderbolt FireWire). 2017.04.17 17:23:43 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "empty"'' done sync in 31 msI 2017.04.17 17:23:43 - DNS of a network adapter restored to original settings (Wi-Fi). 2017.04.17 17:23:44 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "empty"'' done sync in 34 msI 2017.04.17 17:23:44 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2017.04.17 17:23:44 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "empty"'' done sync in 33 msI 2017.04.17 17:23:44 - DNS of a network adapter restored to original settings (Thunderbolt Bridge). 2017.04.17 17:23:44 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "empty"'' done sync in 29 msI 2017.04.17 17:23:47 - Checking authorization ...! 2017.04.17 17:23:47 - Connecting to Caelum (Austria, Vienna). 2017.04.17 17:23:47 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2017.04.17 17:23:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.04.17 17:23:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3102. 2017.04.17 17:23:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.04.17 17:23:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:47 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2017.04.17 17:23:47 - OpenVPN > UDPv4 link local: [undef]. 2017.04.17 17:23:47 - OpenVPN > UDPv4 link remote: [AF_INET]217.64.127.194:443. 2017.04.17 17:23:47 - OpenVPN > TLS: Initial packet from [AF_INET]217.64.127.194:443, sid=a41cac14 5c7c490e. 2017.04.17 17:23:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.17 17:23:47 - OpenVPN > Validating certificate key usage. 2017.04.17 17:23:47 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.17 17:23:47 - OpenVPN > VERIFY KU OK. 2017.04.17 17:23:47 - OpenVPN > Validating certificate extended key usage. 2017.04.17 17:23:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.17 17:23:47 - OpenVPN > VERIFY EKU OK. 2017.04.17 17:23:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caelum, emailAddress=info@airvpn.org. 2017.04.17 17:23:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:23:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:23:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.17 17:23:47 - OpenVPN > [Caelum] Peer Connection Initiated with [AF_INET]217.64.127.194:443. 2017.04.17 17:23:50 - OpenVPN > SENT CONTROL [Caelum]: 'PUSH_REQUEST' (status=1). 2017.04.17 17:23:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.155 255.255.0.0,peer-id 44'. 2017.04.17 17:23:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.17 17:23:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.04.17 17:23:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.17 17:23:50 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.17 17:23:50 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.17 17:23:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.17 17:23:50 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.17 17:23:50 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561. 2017.04.17 17:23:50 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2017.04.17 17:23:50 - OpenVPN > Opened utun device utun2. 2017.04.17 17:23:50 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2017.04.17 17:23:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.04.17 17:23:50 - OpenVPN > route: writing to routing socket: File exists. 2017.04.17 17:23:50 - OpenVPN > /sbin/ifconfig utun2 delete. 2017.04.17 17:23:50 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2017.04.17 17:23:50 - OpenVPN > /sbin/ifconfig utun2 10.4.1.155 10.4.1.155 netmask 255.255.0.0 mtu 1500 up. 2017.04.17 17:23:50 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.155 255.255.0.0. 2017.04.17 17:23:50 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.155: File exists. 2017.04.17 17:23:50 - OpenVPN > /sbin/route add -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:23:50 - OpenVPN > add net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:23:50 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:50 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:50 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:50 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:50 - Starting Management Interface. 2017.04.17 17:23:50 - OpenVPN > Initialization Sequence Completed. 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -listallnetworkservices | grep -v denotes'' done sync in 34 ms. 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -getdnsservers "DJI CONTROLLER"'' done sync in 33 ms. 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -getdnsservers "Ethernet"'' done sync in 31 msI 2017.04.17 17:23:50 - DNS of a network adapter forced (Ethernet). 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "10.4.0.1"'' done sync in 33 ms. 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt FireWire"'' done sync in 31 msI 2017.04.17 17:23:50 - DNS of a network adapter forced (Thunderbolt FireWire). 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "10.4.0.1"'' done sync in 32 ms. 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -getdnsservers "Wi-Fi"'' done sync in 32 msI 2017.04.17 17:23:50 - DNS of a network adapter forced (Wi-Fi). 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "10.4.0.1"'' done sync in 33 ms. 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -getdnsservers "Bluetooth PAN"'' done sync in 30 msI 2017.04.17 17:23:50 - DNS of a network adapter forced (Bluetooth PAN). 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "10.4.0.1"'' done sync in 32 ms. 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt Bridge"'' done sync in 25 msI 2017.04.17 17:23:50 - DNS of a network adapter forced (Thunderbolt Bridge). 2017.04.17 17:23:50 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "10.4.0.1"'' done sync in 27 msI 2017.04.17 17:23:50 - Flushing DNS. 2017.04.17 17:23:50 - Shell of 'sh','-c 'dscacheutil -flushcache'' done sync in 17 ms. 2017.04.17 17:23:50 - Shell of 'sh','-c 'killall -HUP mDNSResponder'' done sync in 17 ms. 2017.04.17 17:23:50 - Shell of 'sh','-c 'discoveryutil udnsflushcaches'' done sync in 11 msI 2017.04.17 17:23:50 - Checking routeE 2017.04.17 17:23:51 - Routing checking failed.. 2017.04.17 17:23:51 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3102! 2017.04.17 17:23:51 - Disconnecting. 2017.04.17 17:23:51 - Management - Send 'signal SIGTERM'. 2017.04.17 17:23:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.17 17:23:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.17 17:23:51 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.17 17:23:56 - OpenVPN > /sbin/route delete -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:23:56 - OpenVPN > delete net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:23:56 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:56 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:56 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:23:56 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:23:56 - OpenVPN > Closing TUN/TAP interface. 2017.04.17 17:23:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.17 17:23:56 - Connection terminated.I 2017.04.17 17:23:56 - DNS of a network adapter restored to original settings (Ethernet). 2017.04.17 17:23:56 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "empty"'' done sync in 33 msI 2017.04.17 17:23:56 - DNS of a network adapter restored to original settings (Thunderbolt FireWire). 2017.04.17 17:23:56 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "empty"'' done sync in 33 msI 2017.04.17 17:23:56 - DNS of a network adapter restored to original settings (Wi-Fi). 2017.04.17 17:23:56 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "empty"'' done sync in 35 msI 2017.04.17 17:23:56 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2017.04.17 17:23:56 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "empty"'' done sync in 33 msI 2017.04.17 17:23:56 - DNS of a network adapter restored to original settings (Thunderbolt Bridge). 2017.04.17 17:23:56 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "empty"'' done sync in 29 msI 2017.04.17 17:23:59 - Checking authorization ...! 2017.04.17 17:23:59 - Connecting to Caelum (Austria, Vienna). 2017.04.17 17:23:59 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2017.04.17 17:23:59 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.04.17 17:23:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3102. 2017.04.17 17:23:59 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.04.17 17:23:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:59 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2017.04.17 17:23:59 - OpenVPN > UDPv4 link local: [undef]. 2017.04.17 17:23:59 - OpenVPN > UDPv4 link remote: [AF_INET]217.64.127.194:443. 2017.04.17 17:23:59 - OpenVPN > TLS: Initial packet from [AF_INET]217.64.127.194:443, sid=78f28220 e6d09c0f. 2017.04.17 17:23:59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.17 17:23:59 - OpenVPN > Validating certificate key usage. 2017.04.17 17:23:59 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.17 17:23:59 - OpenVPN > VERIFY KU OK. 2017.04.17 17:23:59 - OpenVPN > Validating certificate extended key usage. 2017.04.17 17:23:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.17 17:23:59 - OpenVPN > VERIFY EKU OK. 2017.04.17 17:23:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caelum, emailAddress=info@airvpn.org. 2017.04.17 17:23:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:23:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:23:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:23:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.17 17:23:59 - OpenVPN > [Caelum] Peer Connection Initiated with [AF_INET]217.64.127.194:443. 2017.04.17 17:24:02 - OpenVPN > SENT CONTROL [Caelum]: 'PUSH_REQUEST' (status=1). 2017.04.17 17:24:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.155 255.255.0.0,peer-id 44'. 2017.04.17 17:24:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.17 17:24:02 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2017.04.17 17:24:02 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.04.17 17:24:02 - OpenVPN > route: writing to routing socket: File exists. 2017.04.17 17:24:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.17 17:24:02 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.17 17:24:02 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.17 17:24:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.17 17:24:02 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.17 17:24:02 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561. 2017.04.17 17:24:02 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2017.04.17 17:24:02 - OpenVPN > Opened utun device utun2. 2017.04.17 17:24:02 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.04.17 17:24:02 - OpenVPN > /sbin/ifconfig utun2 delete. 2017.04.17 17:24:02 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2017.04.17 17:24:02 - OpenVPN > /sbin/ifconfig utun2 10.4.1.155 10.4.1.155 netmask 255.255.0.0 mtu 1500 up. 2017.04.17 17:24:02 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.155 255.255.0.0. 2017.04.17 17:24:02 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.155: File exists. 2017.04.17 17:24:02 - OpenVPN > /sbin/route add -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:24:02 - OpenVPN > add net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:24:02 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:02 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:02 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:02 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:02 - Starting Management Interface. 2017.04.17 17:24:02 - OpenVPN > Initialization Sequence Completed. 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -listallnetworkservices | grep -v denotes'' done sync in 33 ms. 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -getdnsservers "DJI CONTROLLER"'' done sync in 29 ms. 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -getdnsservers "Ethernet"'' done sync in 30 msI 2017.04.17 17:24:02 - DNS of a network adapter forced (Ethernet). 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "10.4.0.1"'' done sync in 32 ms. 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt FireWire"'' done sync in 33 msI 2017.04.17 17:24:02 - DNS of a network adapter forced (Thunderbolt FireWire). 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "10.4.0.1"'' done sync in 31 ms. 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -getdnsservers "Wi-Fi"'' done sync in 31 msI 2017.04.17 17:24:02 - DNS of a network adapter forced (Wi-Fi). 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "10.4.0.1"'' done sync in 34 ms. 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -getdnsservers "Bluetooth PAN"'' done sync in 30 msI 2017.04.17 17:24:02 - DNS of a network adapter forced (Bluetooth PAN). 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "10.4.0.1"'' done sync in 33 ms. 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt Bridge"'' done sync in 25 msI 2017.04.17 17:24:02 - DNS of a network adapter forced (Thunderbolt Bridge). 2017.04.17 17:24:02 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "10.4.0.1"'' done sync in 29 msI 2017.04.17 17:24:02 - Flushing DNS. 2017.04.17 17:24:02 - Shell of 'sh','-c 'dscacheutil -flushcache'' done sync in 18 ms. 2017.04.17 17:24:02 - Shell of 'sh','-c 'killall -HUP mDNSResponder'' done sync in 20 ms. 2017.04.17 17:24:02 - Shell of 'sh','-c 'discoveryutil udnsflushcaches'' done sync in 13 msI 2017.04.17 17:24:03 - Checking routeE 2017.04.17 17:24:03 - Routing checking failed.. 2017.04.17 17:24:03 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3102! 2017.04.17 17:24:03 - Disconnecting. 2017.04.17 17:24:03 - Management - Send 'signal SIGTERM'. 2017.04.17 17:24:03 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.17 17:24:03 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.17 17:24:03 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.17 17:24:08 - OpenVPN > /sbin/route delete -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:24:08 - OpenVPN > delete net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:24:08 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:08 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:08 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:08 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:08 - OpenVPN > Closing TUN/TAP interface. 2017.04.17 17:24:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.17 17:24:08 - Connection terminated.I 2017.04.17 17:24:08 - DNS of a network adapter restored to original settings (Ethernet). 2017.04.17 17:24:08 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "empty"'' done sync in 31 msI 2017.04.17 17:24:08 - DNS of a network adapter restored to original settings (Thunderbolt FireWire). 2017.04.17 17:24:08 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "empty"'' done sync in 33 msI 2017.04.17 17:24:08 - DNS of a network adapter restored to original settings (Wi-Fi). 2017.04.17 17:24:08 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "empty"'' done sync in 32 msI 2017.04.17 17:24:08 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2017.04.17 17:24:08 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "empty"'' done sync in 32 msI 2017.04.17 17:24:08 - DNS of a network adapter restored to original settings (Thunderbolt Bridge). 2017.04.17 17:24:08 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "empty"'' done sync in 28 msI 2017.04.17 17:24:11 - Checking authorization ...! 2017.04.17 17:24:11 - Connecting to Caelum (Austria, Vienna). 2017.04.17 17:24:11 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2017.04.17 17:24:11 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.04.17 17:24:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3102. 2017.04.17 17:24:11 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.04.17 17:24:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:11 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2017.04.17 17:24:11 - OpenVPN > UDPv4 link local: [undef]. 2017.04.17 17:24:11 - OpenVPN > UDPv4 link remote: [AF_INET]217.64.127.194:443. 2017.04.17 17:24:11 - OpenVPN > TLS: Initial packet from [AF_INET]217.64.127.194:443, sid=6a402cd0 5d22ad54. 2017.04.17 17:24:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.17 17:24:11 - OpenVPN > Validating certificate key usage. 2017.04.17 17:24:11 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.17 17:24:11 - OpenVPN > VERIFY KU OK. 2017.04.17 17:24:11 - OpenVPN > Validating certificate extended key usage. 2017.04.17 17:24:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.17 17:24:11 - OpenVPN > VERIFY EKU OK. 2017.04.17 17:24:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caelum, emailAddress=info@airvpn.org. 2017.04.17 17:24:12 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:24:12 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:12 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:24:12 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:12 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.17 17:24:12 - OpenVPN > [Caelum] Peer Connection Initiated with [AF_INET]217.64.127.194:443. 2017.04.17 17:24:14 - OpenVPN > SENT CONTROL [Caelum]: 'PUSH_REQUEST' (status=1). 2017.04.17 17:24:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.155 255.255.0.0,peer-id 44'. 2017.04.17 17:24:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.17 17:24:14 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2017.04.17 17:24:14 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.04.17 17:24:14 - OpenVPN > route: writing to routing socket: File exists. 2017.04.17 17:24:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.17 17:24:14 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.17 17:24:14 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.17 17:24:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.17 17:24:14 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.17 17:24:14 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561. 2017.04.17 17:24:14 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2017.04.17 17:24:14 - OpenVPN > Opened utun device utun2. 2017.04.17 17:24:14 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.04.17 17:24:14 - OpenVPN > /sbin/ifconfig utun2 delete. 2017.04.17 17:24:14 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2017.04.17 17:24:14 - OpenVPN > /sbin/ifconfig utun2 10.4.1.155 10.4.1.155 netmask 255.255.0.0 mtu 1500 up. 2017.04.17 17:24:14 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.155 255.255.0.0. 2017.04.17 17:24:14 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.155: File exists. 2017.04.17 17:24:14 - OpenVPN > /sbin/route add -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:24:14 - OpenVPN > add net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:24:14 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:14 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:14 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:14 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:14 - Starting Management Interface. 2017.04.17 17:24:14 - OpenVPN > Initialization Sequence Completed. 2017.04.17 17:24:14 - Shell of 'sh','-c 'networksetup -listallnetworkservices | grep -v denotes'' done sync in 33 ms. 2017.04.17 17:24:14 - Shell of 'sh','-c 'networksetup -getdnsservers "DJI CONTROLLER"'' done sync in 31 ms. 2017.04.17 17:24:14 - Shell of 'sh','-c 'networksetup -getdnsservers "Ethernet"'' done sync in 30 msI 2017.04.17 17:24:14 - DNS of a network adapter forced (Ethernet). 2017.04.17 17:24:14 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "10.4.0.1"'' done sync in 31 ms. 2017.04.17 17:24:14 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt FireWire"'' done sync in 29 msI 2017.04.17 17:24:14 - DNS of a network adapter forced (Thunderbolt FireWire). 2017.04.17 17:24:14 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "10.4.0.1"'' done sync in 31 ms. 2017.04.17 17:24:14 - Shell of 'sh','-c 'networksetup -getdnsservers "Wi-Fi"'' done sync in 32 msI 2017.04.17 17:24:14 - DNS of a network adapter forced (Wi-Fi). 2017.04.17 17:24:14 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "10.4.0.1"'' done sync in 33 ms. 2017.04.17 17:24:14 - Shell of 'sh','-c 'networksetup -getdnsservers "Bluetooth PAN"'' done sync in 29 msI 2017.04.17 17:24:14 - DNS of a network adapter forced (Bluetooth PAN). 2017.04.17 17:24:14 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "10.4.0.1"'' done sync in 31 ms. 2017.04.17 17:24:15 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt Bridge"'' done sync in 26 msI 2017.04.17 17:24:15 - DNS of a network adapter forced (Thunderbolt Bridge). 2017.04.17 17:24:15 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "10.4.0.1"'' done sync in 28 msI 2017.04.17 17:24:15 - Flushing DNS. 2017.04.17 17:24:15 - Shell of 'sh','-c 'dscacheutil -flushcache'' done sync in 17 ms. 2017.04.17 17:24:15 - Shell of 'sh','-c 'killall -HUP mDNSResponder'' done sync in 18 ms. 2017.04.17 17:24:15 - Shell of 'sh','-c 'discoveryutil udnsflushcaches'' done sync in 13 msI 2017.04.17 17:24:15 - Checking routeE 2017.04.17 17:24:15 - Routing checking failed.. 2017.04.17 17:24:15 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3102! 2017.04.17 17:24:15 - Disconnecting. 2017.04.17 17:24:15 - Management - Send 'signal SIGTERM'. 2017.04.17 17:24:15 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.17 17:24:15 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.17 17:24:15 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.17 17:24:20 - OpenVPN > /sbin/route delete -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:24:20 - OpenVPN > delete net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:24:20 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:20 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:20 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:20 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:20 - OpenVPN > Closing TUN/TAP interface. 2017.04.17 17:24:20 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.17 17:24:20 - Connection terminated.I 2017.04.17 17:24:20 - DNS of a network adapter restored to original settings (Ethernet). 2017.04.17 17:24:20 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "empty"'' done sync in 33 msI 2017.04.17 17:24:20 - DNS of a network adapter restored to original settings (Thunderbolt FireWire). 2017.04.17 17:24:20 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "empty"'' done sync in 33 msI 2017.04.17 17:24:20 - DNS of a network adapter restored to original settings (Wi-Fi). 2017.04.17 17:24:20 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "empty"'' done sync in 34 msI 2017.04.17 17:24:20 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2017.04.17 17:24:20 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "empty"'' done sync in 33 msI 2017.04.17 17:24:20 - DNS of a network adapter restored to original settings (Thunderbolt Bridge). 2017.04.17 17:24:20 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "empty"'' done sync in 27 msI 2017.04.17 17:24:23 - Checking authorization ...! 2017.04.17 17:24:23 - Connecting to Caelum (Austria, Vienna). 2017.04.17 17:24:23 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2017.04.17 17:24:23 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.04.17 17:24:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3102. 2017.04.17 17:24:23 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.04.17 17:24:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:23 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2017.04.17 17:24:23 - OpenVPN > UDPv4 link local: [undef]. 2017.04.17 17:24:23 - OpenVPN > UDPv4 link remote: [AF_INET]217.64.127.194:443. 2017.04.17 17:24:23 - OpenVPN > TLS: Initial packet from [AF_INET]217.64.127.194:443, sid=7ba2c8b2 e57a6cc6. 2017.04.17 17:24:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.17 17:24:23 - OpenVPN > Validating certificate key usage. 2017.04.17 17:24:23 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.17 17:24:23 - OpenVPN > VERIFY KU OK. 2017.04.17 17:24:23 - OpenVPN > Validating certificate extended key usage. 2017.04.17 17:24:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.17 17:24:23 - OpenVPN > VERIFY EKU OK. 2017.04.17 17:24:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caelum, emailAddress=info@airvpn.org. 2017.04.17 17:24:24 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:24:24 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:24 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:24:24 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:24 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.17 17:24:24 - OpenVPN > [Caelum] Peer Connection Initiated with [AF_INET]217.64.127.194:443. 2017.04.17 17:24:26 - OpenVPN > SENT CONTROL [Caelum]: 'PUSH_REQUEST' (status=1). 2017.04.17 17:24:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.155 255.255.0.0,peer-id 44'. 2017.04.17 17:24:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.17 17:24:26 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.04.17 17:24:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.17 17:24:26 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.17 17:24:26 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.17 17:24:26 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2017.04.17 17:24:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.17 17:24:26 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.17 17:24:26 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561. 2017.04.17 17:24:26 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2017.04.17 17:24:26 - OpenVPN > Opened utun device utun2. 2017.04.17 17:24:26 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.04.17 17:24:26 - OpenVPN > /sbin/ifconfig utun2 delete. 2017.04.17 17:24:26 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2017.04.17 17:24:26 - OpenVPN > route: writing to routing socket: File exists. 2017.04.17 17:24:26 - OpenVPN > /sbin/ifconfig utun2 10.4.1.155 10.4.1.155 netmask 255.255.0.0 mtu 1500 up. 2017.04.17 17:24:26 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.155 255.255.0.0. 2017.04.17 17:24:26 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.155: File exists. 2017.04.17 17:24:26 - OpenVPN > /sbin/route add -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:24:26 - OpenVPN > add net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:24:26 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:26 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:26 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:26 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:26 - Starting Management Interface. 2017.04.17 17:24:26 - OpenVPN > Initialization Sequence Completed. 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -listallnetworkservices | grep -v denotes'' done sync in 32 ms. 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -getdnsservers "DJI CONTROLLER"'' done sync in 29 ms. 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -getdnsservers "Ethernet"'' done sync in 30 msI 2017.04.17 17:24:26 - DNS of a network adapter forced (Ethernet). 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "10.4.0.1"'' done sync in 32 ms. 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt FireWire"'' done sync in 29 msI 2017.04.17 17:24:26 - DNS of a network adapter forced (Thunderbolt FireWire). 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "10.4.0.1"'' done sync in 31 ms. 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -getdnsservers "Wi-Fi"'' done sync in 31 msI 2017.04.17 17:24:26 - DNS of a network adapter forced (Wi-Fi). 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "10.4.0.1"'' done sync in 32 ms. 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -getdnsservers "Bluetooth PAN"'' done sync in 29 msI 2017.04.17 17:24:26 - DNS of a network adapter forced (Bluetooth PAN). 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "10.4.0.1"'' done sync in 30 ms. 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt Bridge"'' done sync in 24 msI 2017.04.17 17:24:26 - DNS of a network adapter forced (Thunderbolt Bridge). 2017.04.17 17:24:26 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "10.4.0.1"'' done sync in 27 msI 2017.04.17 17:24:26 - Flushing DNS. 2017.04.17 17:24:26 - Shell of 'sh','-c 'dscacheutil -flushcache'' done sync in 16 ms. 2017.04.17 17:24:26 - Shell of 'sh','-c 'killall -HUP mDNSResponder'' done sync in 17 ms. 2017.04.17 17:24:26 - Shell of 'sh','-c 'discoveryutil udnsflushcaches'' done sync in 11 msI 2017.04.17 17:24:26 - Checking routeE 2017.04.17 17:24:26 - Routing checking failed.. 2017.04.17 17:24:26 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3102! 2017.04.17 17:24:26 - Disconnecting. 2017.04.17 17:24:26 - Management - Send 'signal SIGTERM'. 2017.04.17 17:24:26 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.17 17:24:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.17 17:24:26 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.17 17:24:31 - OpenVPN > /sbin/route delete -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:24:31 - OpenVPN > delete net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:24:31 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:31 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:31 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:31 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:31 - Connection terminated.. 2017.04.17 17:24:31 - OpenVPN > Closing TUN/TAP interfaceI 2017.04.17 17:24:31 - DNS of a network adapter restored to original settings (Ethernet). 2017.04.17 17:24:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.17 17:24:31 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "empty"'' done sync in 33 msI 2017.04.17 17:24:31 - DNS of a network adapter restored to original settings (Thunderbolt FireWire). 2017.04.17 17:24:31 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "empty"'' done sync in 34 msI 2017.04.17 17:24:31 - DNS of a network adapter restored to original settings (Wi-Fi). 2017.04.17 17:24:31 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "empty"'' done sync in 34 msI 2017.04.17 17:24:31 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2017.04.17 17:24:31 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "empty"'' done sync in 33 msI 2017.04.17 17:24:31 - DNS of a network adapter restored to original settings (Thunderbolt Bridge). 2017.04.17 17:24:31 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "empty"'' done sync in 29 msI 2017.04.17 17:24:34 - Checking authorization ...! 2017.04.17 17:24:34 - Connecting to Caelum (Austria, Vienna). 2017.04.17 17:24:34 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2017.04.17 17:24:34 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.04.17 17:24:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3102. 2017.04.17 17:24:34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.04.17 17:24:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:34 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2017.04.17 17:24:34 - OpenVPN > UDPv4 link local: [undef]. 2017.04.17 17:24:34 - OpenVPN > UDPv4 link remote: [AF_INET]217.64.127.194:443. 2017.04.17 17:24:34 - OpenVPN > TLS: Initial packet from [AF_INET]217.64.127.194:443, sid=2123652e 8b9ccb59. 2017.04.17 17:24:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.17 17:24:34 - OpenVPN > Validating certificate key usage. 2017.04.17 17:24:34 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.17 17:24:34 - OpenVPN > VERIFY KU OK. 2017.04.17 17:24:34 - OpenVPN > Validating certificate extended key usage. 2017.04.17 17:24:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.17 17:24:34 - OpenVPN > VERIFY EKU OK. 2017.04.17 17:24:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caelum, emailAddress=info@airvpn.org. 2017.04.17 17:24:34 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:24:34 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:34 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:24:34 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.17 17:24:34 - OpenVPN > [Caelum] Peer Connection Initiated with [AF_INET]217.64.127.194:443. 2017.04.17 17:24:37 - OpenVPN > SENT CONTROL [Caelum]: 'PUSH_REQUEST' (status=1). 2017.04.17 17:24:37 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.155 255.255.0.0,peer-id 44'. 2017.04.17 17:24:37 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.17 17:24:37 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2017.04.17 17:24:37 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.04.17 17:24:37 - OpenVPN > route: writing to routing socket: File exists. 2017.04.17 17:24:37 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.17 17:24:37 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.17 17:24:37 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.17 17:24:37 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.17 17:24:37 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.17 17:24:37 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561. 2017.04.17 17:24:37 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2017.04.17 17:24:37 - OpenVPN > Opened utun device utun2. 2017.04.17 17:24:37 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.04.17 17:24:37 - OpenVPN > /sbin/ifconfig utun2 delete. 2017.04.17 17:24:37 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2017.04.17 17:24:37 - OpenVPN > /sbin/ifconfig utun2 10.4.1.155 10.4.1.155 netmask 255.255.0.0 mtu 1500 up. 2017.04.17 17:24:37 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.155 255.255.0.0. 2017.04.17 17:24:37 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.155: File exists. 2017.04.17 17:24:37 - OpenVPN > /sbin/route add -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:24:37 - OpenVPN > add net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:24:37 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:37 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:37 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:37 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:37 - Starting Management Interface. 2017.04.17 17:24:37 - OpenVPN > Initialization Sequence Completed. 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -listallnetworkservices | grep -v denotes'' done sync in 43 ms. 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -getdnsservers "DJI CONTROLLER"'' done sync in 40 ms. 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -getdnsservers "Ethernet"'' done sync in 39 msI 2017.04.17 17:24:37 - DNS of a network adapter forced (Ethernet). 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "10.4.0.1"'' done sync in 42 ms. 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt FireWire"'' done sync in 40 msI 2017.04.17 17:24:37 - DNS of a network adapter forced (Thunderbolt FireWire). 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "10.4.0.1"'' done sync in 42 ms. 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -getdnsservers "Wi-Fi"'' done sync in 40 msI 2017.04.17 17:24:37 - DNS of a network adapter forced (Wi-Fi). 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "10.4.0.1"'' done sync in 41 ms. 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -getdnsservers "Bluetooth PAN"'' done sync in 39 msI 2017.04.17 17:24:37 - DNS of a network adapter forced (Bluetooth PAN). 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "10.4.0.1"'' done sync in 41 ms. 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt Bridge"'' done sync in 34 msI 2017.04.17 17:24:37 - DNS of a network adapter forced (Thunderbolt Bridge). 2017.04.17 17:24:37 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "10.4.0.1"'' done sync in 37 msI 2017.04.17 17:24:37 - Flushing DNS. 2017.04.17 17:24:37 - Shell of 'sh','-c 'dscacheutil -flushcache'' done sync in 25 ms. 2017.04.17 17:24:37 - Shell of 'sh','-c 'killall -HUP mDNSResponder'' done sync in 26 ms. 2017.04.17 17:24:37 - Shell of 'sh','-c 'discoveryutil udnsflushcaches'' done sync in 21 msI 2017.04.17 17:24:37 - Checking routeE 2017.04.17 17:24:38 - Routing checking failed.. 2017.04.17 17:24:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3102! 2017.04.17 17:24:38 - Disconnecting. 2017.04.17 17:24:38 - Management - Send 'signal SIGTERM'. 2017.04.17 17:24:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.17 17:24:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.17 17:24:38 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.17 17:24:42 - OpenVPN > TLS: new session incoming connection from [AF_INET]217.64.127.194:443. 2017.04.17 17:24:44 - OpenVPN > /sbin/route delete -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:24:44 - OpenVPN > delete net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:24:44 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:44 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:44 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:44 - Connection terminated.I 2017.04.17 17:24:44 - DNS of a network adapter restored to original settings (Ethernet). 2017.04.17 17:24:44 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:44 - OpenVPN > Closing TUN/TAP interface. 2017.04.17 17:24:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.17 17:24:44 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "empty"'' done sync in 51 msI 2017.04.17 17:24:44 - DNS of a network adapter restored to original settings (Thunderbolt FireWire). 2017.04.17 17:24:44 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "empty"'' done sync in 49 msI 2017.04.17 17:24:44 - DNS of a network adapter restored to original settings (Wi-Fi). 2017.04.17 17:24:44 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "empty"'' done sync in 50 msI 2017.04.17 17:24:44 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2017.04.17 17:24:44 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "empty"'' done sync in 49 msI 2017.04.17 17:24:44 - DNS of a network adapter restored to original settings (Thunderbolt Bridge). 2017.04.17 17:24:44 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "empty"'' done sync in 44 msI 2017.04.17 17:24:47 - Checking authorization ...! 2017.04.17 17:24:47 - Connecting to Caelum (Austria, Vienna). 2017.04.17 17:24:47 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2017.04.17 17:24:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.04.17 17:24:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3102. 2017.04.17 17:24:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.04.17 17:24:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:47 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]. 2017.04.17 17:24:47 - OpenVPN > UDPv4 link local: [undef]. 2017.04.17 17:24:47 - OpenVPN > UDPv4 link remote: [AF_INET]217.64.127.194:443. 2017.04.17 17:24:47 - OpenVPN > TLS: Initial packet from [AF_INET]217.64.127.194:443, sid=25b1cc87 2387b6c2. 2017.04.17 17:24:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.17 17:24:47 - OpenVPN > Validating certificate key usage. 2017.04.17 17:24:47 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.17 17:24:47 - OpenVPN > VERIFY KU OK. 2017.04.17 17:24:47 - OpenVPN > Validating certificate extended key usage. 2017.04.17 17:24:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.17 17:24:47 - OpenVPN > VERIFY EKU OK. 2017.04.17 17:24:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Caelum, emailAddress=info@airvpn.org. 2017.04.17 17:24:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:24:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.04.17 17:24:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.17 17:24:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.17 17:24:48 - OpenVPN > [Caelum] Peer Connection Initiated with [AF_INET]217.64.127.194:443. 2017.04.17 17:24:50 - OpenVPN > SENT CONTROL [Caelum]: 'PUSH_REQUEST' (status=1). 2017.04.17 17:24:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.155 255.255.0.0,peer-id 47'. 2017.04.17 17:24:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.17 17:24:50 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address. 2017.04.17 17:24:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.04.17 17:24:50 - OpenVPN > route: writing to routing socket: File exists. 2017.04.17 17:24:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.17 17:24:50 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.17 17:24:50 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.17 17:24:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.17 17:24:50 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.17 17:24:50 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561. 2017.04.17 17:24:50 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy. 2017.04.17 17:24:50 - OpenVPN > Opened utun device utun2. 2017.04.17 17:24:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.04.17 17:24:50 - OpenVPN > /sbin/ifconfig utun2 delete. 2017.04.17 17:24:50 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure. 2017.04.17 17:24:50 - OpenVPN > /sbin/ifconfig utun2 10.4.1.155 10.4.1.155 netmask 255.255.0.0 mtu 1500 up. 2017.04.17 17:24:50 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.155 255.255.0.0. 2017.04.17 17:24:50 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.155: File exists. 2017.04.17 17:24:50 - OpenVPN > /sbin/route add -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:24:50 - OpenVPN > add net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:24:50 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:50 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:50 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:50 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:50 - Starting Management Interface. 2017.04.17 17:24:50 - OpenVPN > Initialization Sequence Completed. 2017.04.17 17:24:50 - Shell of 'sh','-c 'networksetup -listallnetworkservices | grep -v denotes'' done sync in 39 ms. 2017.04.17 17:24:50 - Shell of 'sh','-c 'networksetup -getdnsservers "DJI CONTROLLER"'' done sync in 38 ms. 2017.04.17 17:24:50 - Shell of 'sh','-c 'networksetup -getdnsservers "Ethernet"'' done sync in 37 msI 2017.04.17 17:24:50 - DNS of a network adapter forced (Ethernet). 2017.04.17 17:24:50 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "10.4.0.1"'' done sync in 39 ms. 2017.04.17 17:24:50 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt FireWire"'' done sync in 38 msI 2017.04.17 17:24:50 - DNS of a network adapter forced (Thunderbolt FireWire). 2017.04.17 17:24:51 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "10.4.0.1"'' done sync in 38 ms. 2017.04.17 17:24:51 - Shell of 'sh','-c 'networksetup -getdnsservers "Wi-Fi"'' done sync in 39 msI 2017.04.17 17:24:51 - DNS of a network adapter forced (Wi-Fi). 2017.04.17 17:24:51 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "10.4.0.1"'' done sync in 40 ms. 2017.04.17 17:24:51 - Shell of 'sh','-c 'networksetup -getdnsservers "Bluetooth PAN"'' done sync in 37 msI 2017.04.17 17:24:51 - DNS of a network adapter forced (Bluetooth PAN). 2017.04.17 17:24:51 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "10.4.0.1"'' done sync in 39 ms. 2017.04.17 17:24:51 - Shell of 'sh','-c 'networksetup -getdnsservers "Thunderbolt Bridge"'' done sync in 32 msI 2017.04.17 17:24:51 - DNS of a network adapter forced (Thunderbolt Bridge). 2017.04.17 17:24:51 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "10.4.0.1"'' done sync in 34 msI 2017.04.17 17:24:51 - Flushing DNS. 2017.04.17 17:24:51 - Shell of 'sh','-c 'dscacheutil -flushcache'' done sync in 24 ms. 2017.04.17 17:24:51 - Shell of 'sh','-c 'killall -HUP mDNSResponder'' done sync in 24 ms. 2017.04.17 17:24:51 - Shell of 'sh','-c 'discoveryutil udnsflushcaches'' done sync in 19 msI 2017.04.17 17:24:51 - Checking routeE 2017.04.17 17:24:51 - Routing checking failed.. 2017.04.17 17:24:51 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3102! 2017.04.17 17:24:51 - Disconnecting. 2017.04.17 17:24:51 - Management - Send 'signal SIGTERM'. 2017.04.17 17:24:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.17 17:24:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.17 17:24:51 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.17 17:24:56 - OpenVPN > /sbin/route delete -net 217.64.127.194 192.168.1.254 255.255.255.255. 2017.04.17 17:24:56 - OpenVPN > delete net 217.64.127.194: gateway 192.168.1.254. 2017.04.17 17:24:56 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:56 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:56 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0. 2017.04.17 17:24:56 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1. 2017.04.17 17:24:56 - OpenVPN > Closing TUN/TAP interface. 2017.04.17 17:24:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.17 17:24:56 - Connection terminated.I 2017.04.17 17:24:56 - DNS of a network adapter restored to original settings (Ethernet). 2017.04.17 17:24:56 - Shell of 'sh','-c 'networksetup -setdnsservers "Ethernet" "empty"'' done sync in 36 msI 2017.04.17 17:24:56 - DNS of a network adapter restored to original settings (Thunderbolt FireWire). 2017.04.17 17:24:56 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt FireWire" "empty"'' done sync in 36 msI 2017.04.17 17:24:56 - DNS of a network adapter restored to original settings (Wi-Fi). 2017.04.17 17:24:56 - Shell of 'sh','-c 'networksetup -setdnsservers "Wi-Fi" "empty"'' done sync in 36 msI 2017.04.17 17:24:56 - DNS of a network adapter restored to original settings (Bluetooth PAN). 2017.04.17 17:24:56 - Shell of 'sh','-c 'networksetup -setdnsservers "Bluetooth PAN" "empty"'' done sync in 35 msI 2017.04.17 17:24:56 - DNS of a network adapter restored to original settings (Thunderbolt Bridge). 2017.04.17 17:24:56 - Shell of 'sh','-c 'networksetup -setdnsservers "Thunderbolt Bridge" "empty"'' done sync in 32 msI 2017.04.17 17:24:57 - Cancel requested.. 2017.04.17 17:24:57 - Shell of 'sh','-c 'networksetup -setv6automatic "DJI CONTROLLER"'' done sync in 34 msI 2017.04.17 17:24:57 - IPv6 restored on network adapter (DJI CONTROLLER). 2017.04.17 17:24:57 - Shell of 'sh','-c 'networksetup -setv6automatic "Ethernet"'' done sync in 32 msI 2017.04.17 17:24:57 - IPv6 restored on network adapter (Ethernet). 2017.04.17 17:24:57 - Shell of 'sh','-c 'networksetup -setv6automatic "Thunderbolt FireWire"'' done sync in 31 msI 2017.04.17 17:24:57 - IPv6 restored on network adapter (Thunderbolt FireWire). 2017.04.17 17:24:57 - Shell of 'sh','-c 'networksetup -setv6automatic "Wi-Fi"'' done sync in 32 msI 2017.04.17 17:24:57 - IPv6 restored on network adapter (Wi-Fi). 2017.04.17 17:24:57 - Shell of 'sh','-c 'networksetup -setv6automatic "Bluetooth PAN"'' done sync in 33 msI 2017.04.17 17:24:57 - IPv6 restored on network adapter (Bluetooth PAN). 2017.04.17 17:24:57 - Shell of 'sh','-c 'networksetup -setv6automatic "Thunderbolt Bridge"'' done sync in 28 msI 2017.04.17 17:24:57 - IPv6 restored on network adapter (Thunderbolt Bridge)! 2017.04.17 17:24:57 - Session terminated. Quote Share this post Link to post
