Not connected, Your IP: 216.73.216.190
medica
US FDA blocked https://www.fda.gov/
From your "medica" name maybe you are bigger on bio than techo, but probably have tried again and it worked ok.
No problem from Air exit node in Singapore, but my Firefox WorldIP addon says that webpage server is on Akamai Content Delivery Network so that is probably the origin of that message.
Could be some sort of race condition between DNS lookup  and CDN server IP address as a guess, but not common. Maybe some odd maintenance / load share / fault failover condition. Server type is "Microsoft-IIS 7.0" so maybe a hint Akamai should use Apache on Linux.
