guppy
WebRTC leak - how to test?
A friend sendt me this link; https://privacytoolsio.github.io/privacytools.io/
Which pretty much says that only firefox can keep you safe from vpn leeks and other privacy inrusions, I'm not convinced so I set out to test my daily browser ( chrome ) - but I cannot seem to test webrtc leaks;
https://privacytoolsio.github.io/privacytools.io/webrtc.html
shows no IPs at all ( vpn or no )
and with airVPNs tool : https://ipleak.net/ I can't figure out where it indicates that webrtc is leaking
The IP changes depending on weather I'm on VPN or Not as you would expect - where does it show that I am leaking, I mean chrome is suppose to - so ?
Chrome: Version 57.0.2987.133 (64-bit)
I run AirVPN on my router with split routing ( switching between an DHCP and manual IPv4 on my computers depending on weather I want VPN or not )
What am I missing?
To disable Webrtc surely and definitively in Firefox:
In the browser bar enter
about:config
ask to find
media.peerconnection.enabled
Set the value to false
And Check again in ipleak
Thanks for that information.
However the question was; "how can I actually test weather or not I have this problem currently?"
I sort of suspect that because I use source based split routing to force *all* traffic from a specific subnet through the tunnel that I doesn't matter that webrtc is enabled, how ever I would like to test that theory.
Actually nevermind - I tested the two urls in firefox and it shows my internal address for webRTC.
Guess chrome has fixed it somehow as it does it even on a brand new install
I first thought that it migth be privacy badger, but for some reason it doesn't block webRTC by default;
Among Google Chrome extensions "Webrtc control" is working very well .
About webrtc leak tests you will find a lot of pages on internet
