_adil
UDP port not works
I want to use that mode:-
Free-UDP-53
There is no problem in connecting to airVPN server. I can successfully connect to airVPN server but after connecting there is no data activity, no browsing and no downloading.........
Free-UDP-53
During the day there are hundreds and hundreds of connections on free server - port 53 UDP. We are not aware of any problem about it.
Please check your configuration and feel free to open a ticket. Do not forget to attach your OpenVPN log.
AirVPN admins
still same problem. here is the log
Wed Jan 12 17:56:05 2011 OpenVPN 2.1.4 i686-pc-mingw32 [sSL] [LZO2] [PKCS11] built on Nov 8 2010
Wed Jan 12 17:56:05 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Jan 12 17:56:05 2011 LZO compression initialized
Wed Jan 12 17:56:05 2011 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
Wed Jan 12 17:56:05 2011 Socket Buffers: R=[8192->8192] S=[8192->8192]
Wed Jan 12 17:56:05 2011 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
Wed Jan 12 17:56:05 2011 Local Options hash (VER=V4): '22188c5b'
Wed Jan 12 17:56:05 2011 Expected Remote Options hash (VER=V4): 'a8f55717'
Wed Jan 12 17:56:05 2011 UDPv4 link local: [undef]
Wed Jan 12 17:56:05 2011 UDPv4 link remote: 94.23.211.188:53
Wed Jan 12 17:56:05 2011 TLS: Initial packet from 94.23.211.188:53, sid=1a2a2792 3c372562
Wed Jan 12 17:56:08 2011 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
Wed Jan 12 17:56:08 2011 VERIFY OK: nsCertType=SERVER
Wed Jan 12 17:56:08 2011 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
Wed Jan 12 17:56:21 2011 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Wed Jan 12 17:56:21 2011 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jan 12 17:56:21 2011 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Wed Jan 12 17:56:21 2011 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jan 12 17:56:21 2011 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Wed Jan 12 17:56:21 2011 [server] Peer Connection Initiated with 94.23.211.188:53
Wed Jan 12 17:56:23 2011 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Jan 12 17:56:23 2011 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.8.0.1,route 10.8.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.8.18.146 10.8.18.145'
Wed Jan 12 17:56:23 2011 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jan 12 17:56:23 2011 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jan 12 17:56:23 2011 OPTIONS IMPORT: route options modified
Wed Jan 12 17:56:23 2011 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Wed Jan 12 17:56:23 2011 ROUTE default_gateway=10.36.37.58
Wed Jan 12 17:56:23 2011 TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{0929F912-1FEE-477B-BEEC-F72547246085}.tap
Wed Jan 12 17:56:23 2011 TAP-Win32 Driver Version 9.7
Wed Jan 12 17:56:23 2011 TAP-Win32 MTU=1500
Wed Jan 12 17:56:23 2011 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.8.18.146/255.255.255.252 on interface {0929F912-1FEE-477B-BEEC-F72547246085} [DHCP-serv: 10.8.18.145, lease-time: 31536000]
Wed Jan 12 17:56:23 2011 Successful ARP Flush on interface [1179652] {0929F912-1FEE-477B-BEEC-F72547246085}
Wed Jan 12 17:56:28 2011 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
Wed Jan 12 17:56:28 2011 C:\WINDOWS\system32\route.exe ADD 94.23.211.188 MASK 255.255.255.255 10.36.37.58
Wed Jan 12 17:56:28 2011 ROUTE: route addition failed using CreateIpForwardEntry: The parameter is incorrect. [status=87 if_index=1179651]
Wed Jan 12 17:56:28 2011 Route addition via IPAPI failed [adaptive]
Wed Jan 12 17:56:28 2011 Route addition fallback to route.exe
Wed Jan 12 17:56:28 2011 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.18.145
Wed Jan 12 17:56:28 2011 Route addition via IPAPI succeeded [adaptive]
Wed Jan 12 17:56:28 2011 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.18.145
Wed Jan 12 17:56:28 2011 C:\WINDOWS\system32\route.exe ADD 10.8.0.1 MASK 255.255.255.255 10.8.18.145
Wed Jan 12 17:56:28 2011 Initialization Sequence Completed
_adil wrote:
heyyyyyy!!!!!!!!!
AirVPN admins
