dxorcist
Can't connect to London servers (DNS issue)
I have a three-day trial. Using Mac Eddie software. I've picked a London server and getting some DNS error:
AirVPN Support Report - Generated 3/12/2017 11:10 AM UTC
-- Environment --
Eddie version: 2.11.15
Eddie OS build: osx_x64
OS type: OSX
OS name: 10.11.6
OS description: Unix 15.6.0.0 - Darwin Bishnus-MBP 15.6.0 Darwin Kernel Version 15.6.0: Mon Aug 29 20:21:34 PDT 2016; root:xnu-3248.60.11~1/RELEASE_X86_64 x86_64
Mono /.Net Framework: v4.0.30319
OpenVPN driver: Expected
OpenVPN: 2.4.0 - OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 (/Users/Bishnu/Downloads/Eddie.app/Contents/MacOS/openvpn)
SSH: OpenSSH_6.9p1, LibreSSL 2.1.8 (/usr/bin/ssh)
SSL: stunnel 5.40 (/Users/Bishnu/Downloads/Eddie.app/Contents/MacOS/stunnel)
Profile path: /Users/Bishnu/.airvpn/AirVPN.xml
Data path: /Users/Bishnu/.airvpn
Application path: /Users/Bishnu/Downloads/Eddie.app/Contents/MacOS
Executable path: /Users/Bishnu/Downloads/Eddie.app/Contents/MacOS/Eddie
Command line arguments (2): psn_0_15925039="True" gui.osx.style="dark"
-- Important options not at defaults --
login: dxorcist
password: (omissis)
remember: True
servers.whitelist: 20dc8ad0bdcd308532e267288a96f544097973189da6b23cf9343aed601d6b09
servers.blacklist: 6f2bdea45a28f462ac3a12b4ad7b6136b9d9a1251fce8453ba3c50c326277a50
areas.whitelist: gb
openvpn.sndbuf: 262144
openvpn.rcvbuf: 262144
-- Logs --
. 2017.03.12 11:04:12 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:04:12 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:04:12 - Connection terminated.
. 2017.03.12 11:04:12 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:04:12 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:04:12 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:04:12 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:04:12 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:04:12 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:04:12 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:04:12 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:04:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.12 11:04:12 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:04:12 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:04:12 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:04:12 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:04:16 - Checking authorization ...
! 2017.03.12 11:04:16 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:04:16 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:04:16 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:04:16 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:04:16 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:04:16 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:04:16 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:04:16 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:04:16 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:04:16 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:04:16 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=f7f976ff a4a03ae3
. 2017.03.12 11:04:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:04:16 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:04:16 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:04:16 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:04:16 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:04:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:04:16 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:04:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:04:16 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:04:16 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:04:17 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:04:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:04:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:04:17 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:04:17 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:04:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:04:17 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:04:17 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:04:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:04:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:04:18 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:04:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:04:18 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:04:18 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:04:18 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:04:18 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:04:18 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:04:18 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:04:18 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:04:18 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:04:18 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:04:18 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:04:18 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:04:18 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:04:18 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:04:18 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:04:18 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:04:18 - Starting Management Interface
. 2017.03.12 11:04:18 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:04:18 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:18 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:18 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:19 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:19 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:19 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:19 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:19 - Flushing DNS
I 2017.03.12 11:04:19 - Checking route
I 2017.03.12 11:04:20 - Checking DNS
E 2017.03.12 11:04:24 - Checking DNS don't match
. 2017.03.12 11:04:24 - Checking DNS (2° try)
E 2017.03.12 11:04:29 - Checking DNS don't match
. 2017.03.12 11:04:29 - Checking DNS (3° try)
E 2017.03.12 11:04:35 - Checking DNS don't match
E 2017.03.12 11:04:35 - DNS checking failed.
. 2017.03.12 11:04:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.03.12 11:04:36 - Disconnecting
. 2017.03.12 11:04:36 - Management - Send 'signal SIGTERM'
. 2017.03.12 11:04:36 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.12 11:04:36 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.12 11:04:36 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.12 11:04:41 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:04:41 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:04:41 - Connection terminated.
. 2017.03.12 11:04:41 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:04:41 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:04:41 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:04:41 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:04:41 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:04:41 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:04:41 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:04:41 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:04:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.12 11:04:41 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:04:41 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:04:41 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:04:41 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:04:44 - Checking authorization ...
! 2017.03.12 11:04:45 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:04:45 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:04:45 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:04:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:04:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:04:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:04:45 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:04:45 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:04:45 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:04:45 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:04:45 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=48953396 79ded6ed
. 2017.03.12 11:04:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:04:45 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:04:45 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:04:45 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:04:45 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:04:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:04:45 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:04:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:04:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:04:45 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:04:45 - OpenVPN > Key [AF_INET]217.151.98.162:443 [0] not initialized (yet), dropping packet.
. 2017.03.12 11:04:46 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:04:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:04:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:04:46 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:04:46 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:04:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:04:46 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:04:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:04:47 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:04:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:04:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:04:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:04:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:04:47 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:04:47 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:04:47 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:04:47 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:04:47 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:04:47 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:04:47 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:04:47 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:04:47 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:04:47 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:04:47 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:04:47 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:04:47 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:04:47 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:04:47 - Starting Management Interface
. 2017.03.12 11:04:47 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:04:47 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:48 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:48 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:48 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:48 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:48 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:48 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:04:49 - Flushing DNS
I 2017.03.12 11:04:49 - Checking route
I 2017.03.12 11:04:49 - Checking DNS
E 2017.03.12 11:04:53 - Checking DNS don't match
. 2017.03.12 11:04:53 - Checking DNS (2° try)
E 2017.03.12 11:04:59 - Checking DNS don't match
. 2017.03.12 11:04:59 - Checking DNS (3° try)
E 2017.03.12 11:05:06 - Checking DNS don't match
E 2017.03.12 11:05:06 - DNS checking failed.
. 2017.03.12 11:05:06 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.03.12 11:05:06 - Disconnecting
. 2017.03.12 11:05:06 - Management - Send 'signal SIGTERM'
. 2017.03.12 11:05:06 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.12 11:05:06 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.12 11:05:06 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.12 11:05:11 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:05:11 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:05:11 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:05:11 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:05:11 - Connection terminated.
. 2017.03.12 11:05:11 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:05:11 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:05:11 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:05:11 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:05:11 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:05:11 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.12 11:05:11 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:05:11 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:05:11 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:05:11 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:05:11 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:05:15 - Checking authorization ...
! 2017.03.12 11:05:15 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:05:15 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:05:15 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:05:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:05:15 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:05:15 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:05:15 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:05:15 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:05:15 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:05:15 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:05:15 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=99d9a465 82e3cc5a
. 2017.03.12 11:05:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:05:15 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:05:15 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:05:15 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:05:15 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:05:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:05:15 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:05:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:05:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:05:15 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:05:15 - OpenVPN > Key [AF_INET]217.151.98.162:443 [0] not initialized (yet), dropping packet.
. 2017.03.12 11:05:16 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:05:16 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:05:16 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:05:16 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:05:16 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:05:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:05:17 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:05:17 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:05:17 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:05:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:05:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:05:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:05:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:05:17 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:05:17 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:05:17 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:05:17 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:05:17 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:05:17 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:05:17 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:05:17 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:05:17 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:05:17 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:05:17 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:05:17 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:05:17 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:05:17 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:05:17 - Starting Management Interface
. 2017.03.12 11:05:17 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:05:17 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:17 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:18 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:18 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:18 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:18 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:18 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:18 - Flushing DNS
I 2017.03.12 11:05:19 - Checking route
I 2017.03.12 11:05:19 - Checking DNS
E 2017.03.12 11:05:23 - Checking DNS don't match
. 2017.03.12 11:05:23 - Checking DNS (2° try)
E 2017.03.12 11:05:28 - Checking DNS don't match
. 2017.03.12 11:05:28 - Checking DNS (3° try)
E 2017.03.12 11:05:35 - Checking DNS don't match
E 2017.03.12 11:05:35 - DNS checking failed.
. 2017.03.12 11:05:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.03.12 11:05:35 - Disconnecting
. 2017.03.12 11:05:35 - Management - Send 'signal SIGTERM'
. 2017.03.12 11:05:35 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.12 11:05:35 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.12 11:05:35 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.12 11:05:40 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:05:40 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:05:40 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:05:40 - Connection terminated.
. 2017.03.12 11:05:40 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:05:40 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:05:40 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:05:40 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:05:40 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:05:40 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:05:40 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:05:40 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.12 11:05:40 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:05:40 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:05:40 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:05:40 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:05:44 - Checking authorization ...
! 2017.03.12 11:05:44 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:05:44 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:05:44 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:05:44 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:05:44 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:05:44 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:05:44 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:05:44 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:05:44 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:05:44 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:05:44 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=962af4ec 547ba525
. 2017.03.12 11:05:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:05:44 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:05:44 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:05:44 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:05:44 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:05:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:05:44 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:05:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:05:44 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:05:44 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:05:45 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:05:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:05:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:05:45 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:05:45 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:05:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:05:45 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:05:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:05:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:05:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:05:46 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:05:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:05:46 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:05:46 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:05:46 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:05:46 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:05:46 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:05:46 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:05:46 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:05:46 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:05:46 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:05:46 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:05:46 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:05:46 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:05:46 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:05:46 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:05:46 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:05:46 - Starting Management Interface
. 2017.03.12 11:05:46 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:05:46 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:46 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:47 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:47 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:47 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:47 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:47 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:05:47 - Flushing DNS
I 2017.03.12 11:05:48 - Checking route
I 2017.03.12 11:05:48 - Checking DNS
E 2017.03.12 11:05:52 - Checking DNS don't match
. 2017.03.12 11:05:52 - Checking DNS (2° try)
E 2017.03.12 11:05:57 - Checking DNS don't match
. 2017.03.12 11:05:57 - Checking DNS (3° try)
E 2017.03.12 11:06:04 - Checking DNS don't match
E 2017.03.12 11:06:04 - DNS checking failed.
. 2017.03.12 11:06:04 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.03.12 11:06:04 - Disconnecting
. 2017.03.12 11:06:04 - Management - Send 'signal SIGTERM'
. 2017.03.12 11:06:04 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.12 11:06:04 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.12 11:06:04 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.12 11:06:09 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:06:09 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:06:09 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:09 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:09 - Connection terminated.
. 2017.03.12 11:06:09 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:06:09 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:09 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:09 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:06:09 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:06:09 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.12 11:06:09 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:06:09 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:06:09 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:06:09 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:06:10 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:06:13 - Checking authorization ...
! 2017.03.12 11:06:13 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:06:13 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:06:13 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:06:13 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:06:13 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:13 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:13 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:06:13 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:06:13 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:06:13 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:06:13 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=0fb1aaf9 a23b6c13
. 2017.03.12 11:06:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:06:13 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:06:13 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:06:13 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:06:13 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:06:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:06:13 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:06:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:06:13 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:06:13 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:06:14 - OpenVPN > Key [AF_INET]217.151.98.162:443 [0] not initialized (yet), dropping packet.
. 2017.03.12 11:06:14 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:06:14 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:06:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:06:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:06:14 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:06:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:06:14 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:06:14 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:06:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:06:14 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:06:14 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:14 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:06:14 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:14 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:06:14 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:06:14 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:06:14 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:06:14 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:06:14 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:06:14 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:06:14 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:06:14 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:06:14 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:06:14 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:14 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:14 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:14 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:14 - Starting Management Interface
. 2017.03.12 11:06:14 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:06:15 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:15 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:15 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:15 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:15 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:15 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:16 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:16 - Flushing DNS
I 2017.03.12 11:06:16 - Checking route
I 2017.03.12 11:06:16 - Checking DNS
E 2017.03.12 11:06:16 - Checking DNS don't match
. 2017.03.12 11:06:16 - Checking DNS (2° try)
E 2017.03.12 11:06:18 - Checking DNS don't match
. 2017.03.12 11:06:18 - Checking DNS (3° try)
E 2017.03.12 11:06:20 - Checking DNS don't match
E 2017.03.12 11:06:20 - DNS checking failed.
. 2017.03.12 11:06:20 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.03.12 11:06:20 - Disconnecting
. 2017.03.12 11:06:20 - Management - Send 'signal SIGTERM'
. 2017.03.12 11:06:20 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.12 11:06:20 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.12 11:06:20 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.12 11:06:25 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:06:25 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:06:25 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:25 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:25 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:25 - Connection terminated.
. 2017.03.12 11:06:25 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:06:25 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:25 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:06:25 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.12 11:06:25 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:06:25 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:06:25 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:06:25 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:06:25 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:06:25 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:06:29 - Checking authorization ...
! 2017.03.12 11:06:29 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:06:29 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:06:29 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:06:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:06:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:06:29 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:06:29 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:06:29 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:06:29 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=87c02b7c 55fd4f31
. 2017.03.12 11:06:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:06:29 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:06:29 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:06:29 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:06:29 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:06:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:06:29 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:06:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:06:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:06:29 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:06:29 - OpenVPN > Key [AF_INET]217.151.98.162:443 [0] not initialized (yet), dropping packet.
. 2017.03.12 11:06:30 - Above log line repeated 1 times more
. 2017.03.12 11:06:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:06:30 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:06:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:06:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:06:30 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:06:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:06:30 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:06:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:06:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:06:30 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:06:30 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:30 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:06:30 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:30 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:06:30 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:06:30 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:06:30 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:06:30 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:06:30 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:06:30 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:06:30 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:06:30 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:06:30 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:06:30 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:30 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:30 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:30 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:30 - Starting Management Interface
. 2017.03.12 11:06:30 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:06:30 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:31 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:31 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:31 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:31 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:31 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:31 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:32 - Flushing DNS
I 2017.03.12 11:06:32 - Checking route
I 2017.03.12 11:06:32 - Checking DNS
E 2017.03.12 11:06:32 - Checking DNS don't match
. 2017.03.12 11:06:32 - Checking DNS (2° try)
E 2017.03.12 11:06:33 - Checking DNS don't match
. 2017.03.12 11:06:33 - Checking DNS (3° try)
E 2017.03.12 11:06:36 - Checking DNS don't match
E 2017.03.12 11:06:36 - DNS checking failed.
. 2017.03.12 11:06:36 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.03.12 11:06:36 - Disconnecting
. 2017.03.12 11:06:36 - Management - Send 'signal SIGTERM'
. 2017.03.12 11:06:36 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.12 11:06:36 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.12 11:06:36 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.12 11:06:41 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:06:41 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:06:41 - Connection terminated.
. 2017.03.12 11:06:41 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:06:41 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:41 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:41 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:41 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:06:41 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:41 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:06:41 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:06:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.12 11:06:41 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:06:41 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:06:41 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:06:41 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:06:44 - Checking authorization ...
! 2017.03.12 11:06:45 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:06:45 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:06:45 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:06:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:06:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:45 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:06:45 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:06:45 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:06:45 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:06:45 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=919e83b1 efe6eabb
. 2017.03.12 11:06:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:06:45 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:06:45 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:06:45 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:06:45 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:06:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:06:45 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:06:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:06:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:06:45 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:06:45 - OpenVPN > Key [AF_INET]217.151.98.162:443 [0] not initialized (yet), dropping packet.
. 2017.03.12 11:06:46 - Above log line repeated 1 times more
. 2017.03.12 11:06:46 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:06:46 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:06:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:06:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:06:46 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:06:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:06:46 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:06:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:06:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:06:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:06:46 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:06:46 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:06:46 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:06:46 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:06:46 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:06:46 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:06:46 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:06:46 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:06:46 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:06:46 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:06:47 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:06:47 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:06:47 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:47 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:47 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:06:47 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:06:47 - Starting Management Interface
. 2017.03.12 11:06:47 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:06:47 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:47 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:47 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:47 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:48 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:48 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:48 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:06:48 - Flushing DNS
I 2017.03.12 11:06:48 - Checking route
I 2017.03.12 11:06:48 - Checking DNS
E 2017.03.12 11:06:49 - Checking DNS don't match
. 2017.03.12 11:06:49 - Checking DNS (2° try)
! 2017.03.12 11:06:49 - Disconnecting
. 2017.03.12 11:06:49 - Management - Send 'signal SIGTERM'
. 2017.03.12 11:06:49 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.12 11:06:54 - Connection terminated.
. 2017.03.12 11:06:54 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:06:54 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:06:54 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:06:54 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:06:54 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:06:54 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:06:54 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:06:54 - Cancel requested.
. 2017.03.12 11:06:54 - IPv6 restored on network adapter (SAMSUNG_Android 2)
. 2017.03.12 11:06:54 - IPv6 restored on network adapter (SAMSUNG_Android)
. 2017.03.12 11:06:54 - IPv6 restored on network adapter (SAMSUNG Modem)
. 2017.03.12 11:06:55 - IPv6 restored on network adapter (Thunderbolt Ethernet)
. 2017.03.12 11:06:55 - IPv6 restored on network adapter (Wi-Fi)
. 2017.03.12 11:06:55 - IPv6 restored on network adapter (iPhone USB)
. 2017.03.12 11:06:55 - IPv6 restored on network adapter (Bluetooth PAN)
. 2017.03.12 11:06:55 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2017.03.12 11:06:55 - IPv6 restored on network adapter (PureVPN)
! 2017.03.12 11:06:55 - Session terminated.
E 2017.03.12 11:07:01 - The request timed out
. 2017.03.12 11:07:01 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.03.12 11:07:01 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.12 11:07:01 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.12 11:07:01 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:07:01 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:07:01 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:07:01 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:07:01 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:07:01 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:07:01 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:07:01 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.03.12 11:09:10 - Logged out.
I 2017.03.12 11:09:12 - Checking login ...
! 2017.03.12 11:09:12 - Logged in.
I 2017.03.12 11:09:24 - Session starting.
. 2017.03.12 11:09:24 - IPv6 disabled on network adapter (SAMSUNG_Android 2)
. 2017.03.12 11:09:24 - IPv6 disabled on network adapter (SAMSUNG_Android)
. 2017.03.12 11:09:24 - IPv6 disabled on network adapter (SAMSUNG Modem)
. 2017.03.12 11:09:24 - IPv6 disabled on network adapter (Thunderbolt Ethernet)
. 2017.03.12 11:09:24 - IPv6 disabled on network adapter (Wi-Fi)
. 2017.03.12 11:09:24 - IPv6 disabled on network adapter (iPhone USB)
. 2017.03.12 11:09:24 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2017.03.12 11:09:24 - IPv6 disabled on network adapter (Thunderbolt Bridge)
. 2017.03.12 11:09:25 - IPv6 disabled on network adapter (PureVPN)
I 2017.03.12 11:09:25 - Checking authorization ...
! 2017.03.12 11:09:25 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:09:25 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:09:25 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:09:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:09:25 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:25 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:09:25 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:09:25 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:09:25 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:09:25 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=cf7512b4 fd7eef22
. 2017.03.12 11:09:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:09:25 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:09:25 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:09:25 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:09:25 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:09:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:09:25 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:09:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:09:25 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:09:25 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:09:26 - OpenVPN > Key [AF_INET]217.151.98.162:443 [0] not initialized (yet), dropping packet.
. 2017.03.12 11:09:26 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:09:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:09:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:09:26 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:09:26 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:09:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:09:26 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:09:26 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:09:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:09:26 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:09:26 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:26 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:09:26 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:26 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:09:26 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:09:26 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:09:26 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:09:26 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:09:26 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:09:26 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:09:26 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:09:26 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:09:26 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:09:26 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:09:26 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:09:26 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:09:26 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:09:26 - Starting Management Interface
. 2017.03.12 11:09:27 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:09:27 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:27 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:27 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:27 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:27 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:27 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:27 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:27 - Flushing DNS
I 2017.03.12 11:09:27 - Checking route
I 2017.03.12 11:09:28 - Checking DNS
E 2017.03.12 11:09:28 - Checking DNS don't match
. 2017.03.12 11:09:28 - Checking DNS (2° try)
E 2017.03.12 11:09:29 - Checking DNS don't match
. 2017.03.12 11:09:29 - Checking DNS (3° try)
E 2017.03.12 11:09:31 - Checking DNS don't match
E 2017.03.12 11:09:31 - DNS checking failed.
. 2017.03.12 11:09:31 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.03.12 11:09:31 - Disconnecting
. 2017.03.12 11:09:31 - Management - Send 'signal SIGTERM'
. 2017.03.12 11:09:31 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.12 11:09:31 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.12 11:09:31 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.12 11:09:36 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:09:36 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:09:36 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:09:36 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:09:36 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:09:36 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:09:36 - Connection terminated.
. 2017.03.12 11:09:36 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:09:36 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:09:36 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.12 11:09:36 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:09:36 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:09:36 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:09:36 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:09:36 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:09:36 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:09:39 - Checking authorization ...
! 2017.03.12 11:09:39 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:09:40 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:09:40 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:09:40 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:09:40 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:40 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:40 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:09:40 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:09:40 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:09:40 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:09:40 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=9a38e6ce 199c48ed
. 2017.03.12 11:09:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:09:40 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:09:40 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:09:40 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:09:40 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:09:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:09:40 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:09:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:09:40 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:09:40 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:09:41 - OpenVPN > Key [AF_INET]217.151.98.162:443 [0] not initialized (yet), dropping packet.
. 2017.03.12 11:09:41 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:09:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:09:41 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:09:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:09:41 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:09:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:09:41 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:09:41 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:09:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:09:41 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:09:41 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:41 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:09:41 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:41 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:09:41 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:09:41 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:09:41 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:09:41 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:09:41 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:09:41 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:09:41 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:09:41 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:09:41 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:09:41 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:09:41 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:09:41 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:09:41 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:09:41 - Starting Management Interface
. 2017.03.12 11:09:41 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:09:42 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:42 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:42 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:42 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:42 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:42 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:42 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:43 - Flushing DNS
I 2017.03.12 11:09:43 - Checking route
I 2017.03.12 11:09:43 - Checking DNS
E 2017.03.12 11:09:43 - Checking DNS don't match
. 2017.03.12 11:09:43 - Checking DNS (2° try)
E 2017.03.12 11:09:44 - Checking DNS don't match
. 2017.03.12 11:09:44 - Checking DNS (3° try)
E 2017.03.12 11:09:47 - Checking DNS don't match
E 2017.03.12 11:09:47 - DNS checking failed.
. 2017.03.12 11:09:47 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.03.12 11:09:47 - Disconnecting
. 2017.03.12 11:09:47 - Management - Send 'signal SIGTERM'
. 2017.03.12 11:09:47 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.12 11:09:47 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.12 11:09:47 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.12 11:09:52 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:09:52 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:09:52 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:09:52 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:09:52 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:09:52 - Connection terminated.
. 2017.03.12 11:09:52 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:09:52 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:09:52 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:09:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.12 11:09:52 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:09:52 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:09:52 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:09:53 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:09:53 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:09:53 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:09:56 - Checking authorization ...
! 2017.03.12 11:09:56 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:09:56 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:09:56 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:09:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:09:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:56 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:09:56 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:09:56 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:09:56 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:09:56 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=9c12582d 1a2c797c
. 2017.03.12 11:09:56 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:09:56 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:09:56 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:09:56 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:09:56 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:09:56 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:09:56 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:09:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:09:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:09:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:09:57 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:09:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:09:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:09:57 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:09:57 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:09:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:09:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:09:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:09:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:09:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:09:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:09:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:09:58 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:09:58 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:09:58 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:09:58 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:09:58 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:09:58 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:09:58 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:09:58 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:09:58 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:09:58 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:09:58 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:09:58 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:09:58 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:09:58 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:09:58 - Starting Management Interface
. 2017.03.12 11:09:58 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:09:58 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:58 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:58 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:59 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:59 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:59 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:59 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:09:59 - Flushing DNS
I 2017.03.12 11:09:59 - Checking route
I 2017.03.12 11:10:00 - Checking DNS
E 2017.03.12 11:10:00 - Checking DNS don't match
. 2017.03.12 11:10:00 - Checking DNS (2° try)
E 2017.03.12 11:10:01 - Checking DNS don't match
. 2017.03.12 11:10:01 - Checking DNS (3° try)
E 2017.03.12 11:10:03 - Checking DNS don't match
E 2017.03.12 11:10:03 - DNS checking failed.
. 2017.03.12 11:10:03 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.03.12 11:10:03 - Disconnecting
. 2017.03.12 11:10:03 - Management - Send 'signal SIGTERM'
. 2017.03.12 11:10:03 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.12 11:10:03 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.12 11:10:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.12 11:10:08 - OpenVPN > /sbin/route delete -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:10:08 - OpenVPN > delete net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:10:08 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:10:08 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:10:08 - Connection terminated.
. 2017.03.12 11:10:08 - DNS of a network adapter restored to original settings (SAMSUNG_Android 2, to Automatic)
. 2017.03.12 11:10:08 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:10:08 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:10:08 - OpenVPN > Closing TUN/TAP interface
. 2017.03.12 11:10:08 - DNS of a network adapter restored to original settings (SAMSUNG_Android, to Automatic)
. 2017.03.12 11:10:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.12 11:10:08 - DNS of a network adapter restored to original settings (SAMSUNG Modem, to Automatic)
. 2017.03.12 11:10:08 - DNS of a network adapter restored to original settings (Thunderbolt Ethernet, to Automatic)
. 2017.03.12 11:10:08 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.03.12 11:10:08 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.03.12 11:10:08 - DNS of a network adapter restored to original settings (PureVPN, to Automatic)
I 2017.03.12 11:10:11 - Checking authorization ...
! 2017.03.12 11:10:11 - Connecting to Alshain (United Kingdom, London)
. 2017.03.12 11:10:12 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan 29 2017
. 2017.03.12 11:10:12 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.12 11:10:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.12 11:10:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:10:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:10:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]217.151.98.162:443
. 2017.03.12 11:10:12 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.03.12 11:10:12 - OpenVPN > UDP link local: (not bound)
. 2017.03.12 11:10:12 - OpenVPN > UDP link remote: [AF_INET]217.151.98.162:443
. 2017.03.12 11:10:12 - OpenVPN > TLS: Initial packet from [AF_INET]217.151.98.162:443, sid=bb15b93d f1fbc3a0
. 2017.03.12 11:10:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.12 11:10:12 - OpenVPN > Validating certificate key usage
. 2017.03.12 11:10:12 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.12 11:10:12 - OpenVPN > VERIFY KU OK
. 2017.03.12 11:10:12 - OpenVPN > Validating certificate extended key usage
. 2017.03.12 11:10:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.12 11:10:12 - OpenVPN > VERIFY EKU OK
. 2017.03.12 11:10:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.12 11:10:12 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.12 11:10:12 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]217.151.98.162:443
. 2017.03.12 11:10:13 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.12 11:10:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.238 255.255.0.0'
. 2017.03.12 11:10:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.12 11:10:13 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.03.12 11:10:13 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.12 11:10:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.12 11:10:13 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.12 11:10:13 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.12 11:10:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.12 11:10:13 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:10:13 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:10:13 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.12 11:10:13 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.12 11:10:13 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=en0 HWADDR=78:31:c1:c9:2f:f0
. 2017.03.12 11:10:13 - OpenVPN > Opened utun device utun0
. 2017.03.12 11:10:13 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.12 11:10:13 - OpenVPN > /sbin/ifconfig utun0 delete
. 2017.03.12 11:10:13 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.03.12 11:10:14 - OpenVPN > /sbin/ifconfig utun0 10.4.21.238 10.4.21.238 netmask 255.255.0.0 mtu 1500 up
. 2017.03.12 11:10:14 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.21.238 255.255.0.0
. 2017.03.12 11:10:14 - OpenVPN > add net 10.4.0.0: gateway 10.4.21.238
. 2017.03.12 11:10:14 - OpenVPN > /sbin/route add -net 217.151.98.162 192.168.1.1 255.255.255.255
. 2017.03.12 11:10:14 - OpenVPN > add net 217.151.98.162: gateway 192.168.1.1
. 2017.03.12 11:10:14 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:10:14 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:10:14 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.03.12 11:10:14 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.03.12 11:10:14 - Starting Management Interface
. 2017.03.12 11:10:14 - OpenVPN > Initialization Sequence Completed
. 2017.03.12 11:10:14 - DNS of a network adapter forced (SAMSUNG_Android 2, from Automatic to 10.4.0.1)
. 2017.03.12 11:10:14 - DNS of a network adapter forced (SAMSUNG_Android, from Automatic to 10.4.0.1)
. 2017.03.12 11:10:14 - DNS of a network adapter forced (SAMSUNG Modem, from Automatic to 10.4.0.1)
. 2017.03.12 11:10:14 - DNS of a network adapter forced (Thunderbolt Ethernet, from Automatic to 10.4.0.1)
. 2017.03.12 11:10:14 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.03.12 11:10:15 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.03.12 11:10:15 - DNS of a network adapter forced (PureVPN, from Automatic to 10.4.0.1)
. 2017.03.12 11:10:15 - Flushing DNS
I 2017.03.12 11:10:15 - Checking route
I 2017.03.12 11:10:15 - Checking DNS
E 2017.03.12 11:10:15 - Checking DNS don't match
. 2017.03.12 11:10:15 - Checking DNS (2° try)
-- System --
Operating System: Unix 15.6.0.0 - Darwin Bishnus-MBP 15.6.0 Darwin Kernel Version 15.6.0: Mon Aug 29 20:21:34 PDT 2016; root:xnu-3248.60.11~1/RELEASE_X86_64 x86_64
Network Interface: lo0 (lo0, ID:lo0) - Loopback - Up
Network Interface: gif0 (gif0, ID:gif0) - Unknown - Unknown
Network Interface: stf0 (stf0, ID:stf0) - Unknown - Unknown
Network Interface: en0 (en0, ID:en0) - Ethernet - Up
Network Interface: en1 (en1, ID:en1) - Ethernet - Up
Network Interface: en2 (en2, ID:en2) - Ethernet - Up
Network Interface: p2p0 (p2p0, ID:p2p0) - Ethernet - Up
Network Interface: awdl0 (awdl0, ID:awdl0) - Ethernet - Up
Network Interface: bridge0 (bridge0, ID:bridge0) - Ethernet - Up
Network Interface: utun0 (utun0, ID:utun0) - Unknown - Up
Routing:
Default gateways:
127.0.0.1, lo0
192.168.1.1, en0
10.4.0.1, utun0
10.4.21.238, utun0
-- OS X
-- ifconfig
lo0: flags=8049 mtu 16384
options=3
inet6 ::1 prefixlen 128
inet 127.0.0.1 netmask 0xff000000
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=1
gif0: flags=8010 mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863 mtu 1500
ether 78:31:c1:c9:2f:f0
inet6 fe80::7a31:c1ff:fec9:2ff0%en0 prefixlen 64 scopeid 0x4
inet 192.168.1.172 netmask 0xffffff00 broadcast 192.168.1.255
nd6 options=1
media: autoselect
status: active
en1: flags=963 mtu 1500
options=60
ether 72:00:02:4d:77:80
media: autoselect
status: inactive
en2: flags=963 mtu 1500
options=60
ether 72:00:02:4d:77:81
media: autoselect
status: inactive
p2p0: flags=8843 mtu 2304
ether 0a:31:c1:c9:2f:f0
media: autoselect
status: inactive
awdl0: flags=8943 mtu 1484
ether 1a:a6:dc:33:17:e6
inet6 fe80::18a6:dcff:fe33:17e6%awdl0 prefixlen 64 scopeid 0x8
nd6 options=1
media: autoselect
status: active
bridge0: flags=8863 mtu 1500
options=63
ether 7a:31:c1:9c:02:00
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x2
member: en1 flags=3
ifmaxaddr 0 port 5 priority 0 path cost 0
member: en2 flags=3
ifmaxaddr 0 port 6 priority 0 path cost 0
nd6 options=1
media:
status: inactive
utun0: flags=8051 mtu 1500
inet 10.4.21.238 --> 10.4.21.238 netmask 0xffff0000
,pointopoint,running,multicast>,discover>,discover>,txcsum,tso4,tso6>,broadcast,smart,running,simplex,multicast>,broadcast,running,promisc,simplex,multicast>,broadcast,running,simplex,multicast>,tso6>,broadcast,smart,running,promisc,simplex>,tso6>,broadcast,smart,running,promisc,simplex>,broadcast,smart,running,simplex,multicast>,multicast>,txcsum>,loopback,running,multicast>
Can you let me know what I am doing wrong, or what I need to so to fix.
Thanks.
Welcome to AirVPN!
I'm just curious, is this with Network Lock turned on? In the Eddie settings, you can try to turn off DNS checking temporarily to see if that helps.
