Yingyz
SSL Tunnel to bypass Smoothwall
I'm trying to use an SSL tunnel to bypass Smoothwall but unfortunately it doesn't appear to work. I've tried SSH tunneling as well but that doesn't help.
The logs are below.
! 2017.03.08 12:58:02 - Connecting to Mirach (Netherlands, Alblasserdam)
. 2017.03.08 12:58:03 - SSL > 2017.03.08 12:58:02 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2017.03.08 12:58:03 - SSL > 2017.03.08 12:58:02 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2017.03.08 12:58:03 - SSL > 2017.03.08 12:58:02 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2017.03.08 12:58:03 - SSL > 2017.03.08 12:58:02 LOG5[ui]: Reading configuration from file C:\Users\Ying\AppData\Local\AirVPN\91f5d007fe5e64fc8eca340f830f5538765982a6d8461d0550467f8416119510.tmp.ssl
. 2017.03.08 12:58:03 - SSL > 2017.03.08 12:58:02 LOG5[ui]: UTF-8 byte order mark not detected
. 2017.03.08 12:58:03 - SSL > 2017.03.08 12:58:03 LOG6[ui]: Initializing service [openvpn]
. 2017.03.08 12:58:03 - SSL > 2017.03.08 12:58:03 LOG5[ui]: Configuration successful
. 2017.03.08 12:58:03 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.03.08 12:58:03 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.03.08 12:58:03 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.03.08 12:58:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.08 12:58:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.08 12:58:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.08 12:58:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:61932
. 2017.03.08 12:58:03 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.03.08 12:58:03 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:61932 [nonblock]
. 2017.03.08 12:58:03 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:61932
. 2017.03.08 12:58:03 - SSL > 2017.03.08 12:58:03 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:52608
. 2017.03.08 12:58:03 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2017.03.08 12:58:03 - SSL > 2017.03.08 12:58:03 LOG6[0]: s_connect: connecting 213.152.162.70:28439
. 2017.03.08 12:58:03 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:61932
. 2017.03.08 12:58:04 - SSL > 2017.03.08 12:58:04 LOG3[0]: s_connect: connect 213.152.162.70:28439: Connection refused (WSAECONNREFUSED) (10061)
. 2017.03.08 12:58:04 - OpenVPN > Connection reset, restarting [-1]
. 2017.03.08 12:58:04 - SSL > 2017.03.08 12:58:04 LOG3[0]: No more addresses to connect
. 2017.03.08 12:58:04 - SSL > 2017.03.08 12:58:04 LOG5[0]: Connection reset: 0 byte(s) sent to TLS, 0 byte(s) sent to socket
. 2017.03.08 12:58:04 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2017.03.08 12:58:04 - OpenVPN > Restart pause, 5 second(s)
! 2017.03.08 12:58:04 - Disconnecting
. 2017.03.08 12:58:04 - Connection terminated.
! 2017.03.08 13:16:08 - Connecting to Muscida (Netherlands, Alblasserdam)
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG5[ui]: Reading configuration from file C:\Users\Ying\AppData\Local\AirVPN\6972b761746905d3bc437f8929dd6da4a66bebbbd54f55c20ae72376cfdd550d.tmp.ssl
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG5[ui]: UTF-8 byte order mark not detected
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG6[ui]: Initializing service [openvpn]
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG5[ui]: Configuration successful
. 2017.03.08 13:16:08 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.03.08 13:16:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.03.08 13:16:08 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.03.08 13:16:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.08 13:16:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.08 13:16:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.08 13:16:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:45897
. 2017.03.08 13:16:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.03.08 13:16:08 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:45897 [nonblock]
. 2017.03.08 13:16:08 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:45897
. 2017.03.08 13:16:08 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:52869
. 2017.03.08 13:16:08 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:45897
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG6[0]: s_connect: connecting 213.152.162.155:443
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG5[0]: s_connect: connected 213.152.162.155:443
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG5[0]: Service [openvpn] connected remote server from 172.16.2.52:52870
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG6[0]: SNI: sending servername: 213.152.162.155
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG6[0]: Peer certificate required
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG4[0]: CERT: Pre-verification error: self signed certificate in certificate chain
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG4[0]: Rejected by CERT at depth=2: CN=Smoothwall-default-root-certificate-authority
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG3[0]: SSL_connect: 14090086: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
. 2017.03.08 13:16:08 - SSL > 2017.03.08 13:16:08 LOG5[0]: Connection reset: 0 byte(s) sent to TLS, 0 byte(s) sent to socket
. 2017.03.08 13:16:08 - OpenVPN > Connection reset, restarting [-1]
. 2017.03.08 13:16:08 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2017.03.08 13:16:08 - OpenVPN > Restart pause, 5 second(s)
! 2017.03.08 13:16:08 - Disconnecting
Thats what I got when I tried using 443
Could you tell me how I could change that line?
I'm using the Eddie GUI and I don't know if that gives an option to change config files.
I have had success bypassing a restrictive firewall connecting to Dheneb using SSL on port 28439. Unfortunately, it's the only  one working. Everything else gives me a "connection reset by peer".
