ozon3xp
pfsense with airvpn client and running a VPN Server with OpenVPN and Stunnel
Greetings,
I've followed this tutorial to setup my pfsense firewall:
https://airvpn.org/topic/17444-how-to-set-up-pfsense-23-for-airvpn/
and followed this tutorial to setup my pi:
http://www.farrellf.com/projects/software/2016-05-04_Running_a_VPN_Server_with_OpenVPN_and_Stunnel/
My lack of firewall knowledge is preventing me from figuring out the proper port forwarding to make this work. Thanks in advance.
vpn windows:
Fri Mar 03 13:21:44 2017 SIGUSR1[soft,connection-reset] received, process restarting
Fri Mar 03 13:21:44 2017 Restart pause, 5 second(s)
Fri Mar 03 13:21:49 2017 TCP/UDP: Preserving recently used remote address: [AF_INET6]::1:1337
Fri Mar 03 13:21:49 2017 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri Mar 03 13:21:49 2017 Attempting to establish TCP connection with [AF_INET6]::1:1337 [nonblock]
Fri Mar 03 13:23:49 2017 TCP: connect to [AF_INET6]::1:1337 failed: Connection timed out (WSAETIMEDOUT)
Fri Mar 03 13:23:49 2017 SIGUSR1[connection failed(soft),init_instance] received, process restarting
Fri Mar 03 13:23:49 2017 Restart pause, 5 second(s)
Fri Mar 03 13:23:54 2017 TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:1337
Fri Mar 03 13:23:54 2017 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri Mar 03 13:23:54 2017 Attempting to establish TCP connection with [AF_INET]127.0.0.1:1337 [nonblock]
Fri Mar 03 13:23:54 2017 TCP connection established with [AF_INET]127.0.0.1:1337
Fri Mar 03 13:23:54 2017 TCP_CLIENT link local: (not bound)
Fri Mar 03 13:23:54 2017 TCP_CLIENT link remote: [AF_INET]127.0.0.1:1337
Fri Mar 03 13:24:04 2017 Connection reset, restarting [-1]
Fri Mar 03 13:24:04 2017 SIGUSR1[soft,connection-reset] received, process restarting
Fri Mar 03 13:24:04 2017 Restart pause, 5 second(s)
Fri Mar 03 13:24:09 2017 TCP/UDP: Preserving recently used remote address: [AF_INET6]::1:1337
Fri Mar 03 13:24:09 2017 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri Mar 03 13:24:09 2017 Attempting to establish TCP connection with [AF_INET6]::1:1337 [nonblock]
Fri Mar 03 13:26:09 2017 TCP: connect to [AF_INET6]::1:1337 failed: Connection timed out (WSAETIMEDOUT)
Fri Mar 03 13:26:09 2017 SIGUSR1[connection failed(soft),init_instance] received, process restarting
Fri Mar 03 13:26:09 2017 Restart pause, 5 second(s)
Fri Mar 03 13:26:14 2017 TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:1337
Fri Mar 03 13:26:14 2017 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri Mar 03 13:26:14 2017 Attempting to establish TCP connection with [AF_INET]127.0.0.1:1337 [nonblock]
Fri Mar 03 13:26:14 2017 TCP connection established with [AF_INET]127.0.0.1:1337
Fri Mar 03 13:26:14 2017 TCP_CLIENT link local: (not bound)
Fri Mar 03 13:26:14 2017 TCP_CLIENT link remote: [AF_INET]127.0.0.1:1337
stunnel log:
2017.03.03 13:19:13 LOG5[14]: Service [openvpn] accepted connection from 127.0.0.1:35182
2017.03.03 13:19:23 LOG3[14]: s_connect: s_poll_wait 199.241.146.179:15136: TIMEOUTconnect exceeded
2017.03.03 13:19:23 LOG3[14]: No more addresses to connect
2017.03.03 13:19:23 LOG5[14]: Connection reset: 0 byte(s) sent to TLS, 0 byte(s) sent to socket
2017.03.03 13:21:34 LOG5[15]: Service [openvpn] accepted connection from 127.0.0.1:35192
2017.03.03 13:21:44 LOG3[15]: s_connect: s_poll_wait 199.241.146.179:15136: TIMEOUTconnect exceeded
2017.03.03 13:21:44 LOG3[15]: No more addresses to connect
2017.03.03 13:21:44 LOG5[15]: Connection reset: 0 byte(s) sent to TLS, 0 byte(s) sent to socket
2017.03.03 13:23:54 LOG5[16]: Service [openvpn] accepted connection from 127.0.0.1:35220
2017.03.03 13:24:04 LOG3[16]: s_connect: s_poll_wait 199.241.146.179:15136: TIMEOUTconnect exceeded
2017.03.03 13:24:04 LOG3[16]: No more addresses to connect
2017.03.03 13:24:04 LOG5[16]: Connection reset: 0 byte(s) sent to TLS, 0 byte(s) sent to socket
2017.03.03 13:26:14 LOG5[17]: Service [openvpn] accepted connection from 127.0.0.1:35238
2017.03.03 13:26:24 LOG3[17]: s_connect: s_poll_wait 199.241.146.179:15136: TIMEOUTconnect exceeded
2017.03.03 13:26:24 LOG3[17]: No more addresses to connect
2017.03.03 13:26:24 LOG5[17]: Connection reset: 0 byte(s) sent to TLS, 0 byte(s) sent to socket
