2.11.15 Eddie not working in Debian Stable
today I upgraded to Eddie 2.11.15 on two laptops. Both can't connect to vpn any more! I tried by adding the Debian repository and by installing the .deb ... same issue.
Here is the log:
I 2017.01.31 19:21:57 - Eddie client version: 2.11.15 / linux_x64, System: Linux, Name: Debian GNU/Linux 8 \n \l, Mono/.Net Framework: v4.0.30319
. 2017.01.31 19:21:57 - Reading options from /root/.airvpn/AirVPN.xml
. 2017.01.31 19:21:58 - Data path: /root/.airvpn
. 2017.01.31 19:21:58 - Application path: /usr/lib/AirVPN
. 2017.01.31 19:21:58 - Executable path: /usr/lib/AirVPN/AirVPN.exe
. 2017.01.31 19:21:58 - Command line arguments (1): path="/root/.airvpn"
. 2017.01.31 19:21:58 - Operating System: Unix 3.16.0.4 - Linux X201 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
I 2017.01.31 19:21:58 - OpenVPN Driver - Found, /dev/net/tun
I 2017.01.31 19:21:58 - OpenVPN - Version: 2.3.4 - OpenSSL 1.0.1t  3 May 2016, LZO 2.08 (/usr/sbin/openvpn)
I 2017.01.31 19:21:58 - SSH - Version: OpenSSH_6.7p1 Debian-5+deb8u3, OpenSSL 1.0.1t  3 May 2016 (/usr/bin/ssh)
I 2017.01.31 19:21:58 - SSL - Version: stunnel 5.06 (/usr/bin/stunnel4)
! 2017.01.31 19:21:58 - Ready
. 2017.01.31 19:21:58 - Updating systems & servers data ...
I 2017.01.31 19:22:01 - Session starting.
. 2017.01.31 19:22:01 - Unable to understand if IPv6 is active.
I 2017.01.31 19:22:02 - Checking authorization ...
. 2017.01.31 19:22:02 - Systems & servers data update completed
! 2017.01.31 19:22:02 - Connecting to Aquilae (Germany, Frankfurt)
. 2017.01.31 19:22:02 - OpenVPN > OpenVPN 2.3.4 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Nov 12 2015
. 2017.01.31 19:22:02 - OpenVPN > library versions: OpenSSL 1.0.1t  3 May 2016, LZO 2.08
. 2017.01.31 19:22:02 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.31 19:22:02 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.01.31 19:22:02 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:02 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:02 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]
. 2017.01.31 19:22:02 - OpenVPN > UDPv4 link local: [undef]
. 2017.01.31 19:22:02 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.70:443
. 2017.01.31 19:22:02 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.70:443, sid=e8c1fb0f 945f5134
. 2017.01.31 19:22:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.31 19:22:02 - OpenVPN > Validating certificate key usage
. 2017.01.31 19:22:02 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.31 19:22:02 - OpenVPN > VERIFY KU OK
. 2017.01.31 19:22:02 - OpenVPN > Validating certificate extended key usage
. 2017.01.31 19:22:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.31 19:22:02 - OpenVPN > VERIFY EKU OK
. 2017.01.31 19:22:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.01.31 19:22:03 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.31 19:22:03 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:03 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.31 19:22:03 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:03 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2017.01.31 19:22:03 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.70:443
. 2017.01.31 19:22:05 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.01.31 19:22:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.12.181 255.255.0.0'
. 2017.01.31 19:22:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.31 19:22:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.01.31 19:22:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.31 19:22:06 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.31 19:22:06 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.31 19:22:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.31 19:22:06 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 IFACE=wlan0 HWADDR=00:27:10:78:e2:30
. 2017.01.31 19:22:06 - OpenVPN > TUN/TAP device tun0 opened
. 2017.01.31 19:22:06 - OpenVPN > TUN/TAP TX queue length set to 100
. 2017.01.31 19:22:06 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.01.31 19:22:06 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2017.01.31 19:22:06 - OpenVPN > /sbin/ip addr add dev tun0 10.4.12.181/16 broadcast 10.4.255.255
. 2017.01.31 19:22:11 - OpenVPN > /sbin/ip route add 46.165.208.70/32 via 192.168.178.1
. 2017.01.31 19:22:11 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1
. 2017.01.31 19:22:11 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1
. 2017.01.31 19:22:11 - Starting Management Interface
. 2017.01.31 19:22:11 - OpenVPN > Initialization Sequence Completed
. 2017.01.31 19:22:11 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup
. 2017.01.31 19:22:11 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2017.01.31 19:22:11 - Checking route
E 2017.01.31 19:22:12 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
. 2017.01.31 19:22:12 - Checking route (2° try)
E 2017.01.31 19:22:13 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
. 2017.01.31 19:22:13 - Checking route (3° try)
E 2017.01.31 19:22:15 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
E 2017.01.31 19:22:15 - Routing checking failed.
. 2017.01.31 19:22:15 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.01.31 19:22:15 - Disconnecting
. 2017.01.31 19:22:15 - Management - Send 'signal SIGTERM'
. 2017.01.31 19:22:15 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.31 19:22:15 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.31 19:22:15 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.01.31 19:22:15 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2017.01.31 19:22:20 - OpenVPN > /sbin/ip route del 46.165.208.70/32
. 2017.01.31 19:22:20 - OpenVPN > /sbin/ip route del 0.0.0.0/1
. 2017.01.31 19:22:20 - OpenVPN > /sbin/ip route del 128.0.0.0/1
. 2017.01.31 19:22:20 - OpenVPN > Closing TUN/TAP interface
. 2017.01.31 19:22:20 - OpenVPN > /sbin/ip addr del dev tun0 10.4.12.181/16
. 2017.01.31 19:22:20 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.31 19:22:20 - Connection terminated.
. 2017.01.31 19:22:20 - DNS of the system restored to original settings (Rename method)
I 2017.01.31 19:22:23 - Checking authorization ...
! 2017.01.31 19:22:23 - Connecting to Velorum (Germany, Frankfurt)
. 2017.01.31 19:22:23 - OpenVPN > OpenVPN 2.3.4 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Nov 12 2015
. 2017.01.31 19:22:23 - OpenVPN > library versions: OpenSSL 1.0.1t  3 May 2016, LZO 2.08
. 2017.01.31 19:22:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.31 19:22:23 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.01.31 19:22:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:23 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]
. 2017.01.31 19:22:23 - OpenVPN > UDPv4 link local: [undef]
. 2017.01.31 19:22:23 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.69:443
. 2017.01.31 19:22:23 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.69:443, sid=2f999999 156341d2
. 2017.01.31 19:22:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.31 19:22:23 - OpenVPN > Validating certificate key usage
. 2017.01.31 19:22:23 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.31 19:22:24 - OpenVPN > VERIFY KU OK
. 2017.01.31 19:22:24 - OpenVPN > Validating certificate extended key usage
. 2017.01.31 19:22:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.31 19:22:24 - OpenVPN > VERIFY EKU OK
. 2017.01.31 19:22:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.01.31 19:22:24 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.31 19:22:24 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:24 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.31 19:22:24 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:24 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2017.01.31 19:22:24 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.69:443
. 2017.01.31 19:22:26 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.01.31 19:22:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.12.49 255.255.0.0'
. 2017.01.31 19:22:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.31 19:22:26 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.01.31 19:22:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.31 19:22:26 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.31 19:22:26 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.31 19:22:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.31 19:22:26 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 IFACE=wlan0 HWADDR=00:27:10:78:e2:30
. 2017.01.31 19:22:26 - OpenVPN > TUN/TAP device tun0 opened
. 2017.01.31 19:22:26 - OpenVPN > TUN/TAP TX queue length set to 100
. 2017.01.31 19:22:26 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.01.31 19:22:26 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2017.01.31 19:22:26 - OpenVPN > /sbin/ip addr add dev tun0 10.4.12.49/16 broadcast 10.4.255.255
. 2017.01.31 19:22:32 - OpenVPN > /sbin/ip route add 46.165.208.69/32 via 192.168.178.1
. 2017.01.31 19:22:32 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1
. 2017.01.31 19:22:32 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1
. 2017.01.31 19:22:32 - Starting Management Interface
. 2017.01.31 19:22:32 - OpenVPN > Initialization Sequence Completed
. 2017.01.31 19:22:32 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup
. 2017.01.31 19:22:32 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2017.01.31 19:22:32 - Checking route
E 2017.01.31 19:22:32 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
. 2017.01.31 19:22:32 - Checking route (2° try)
E 2017.01.31 19:22:33 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
. 2017.01.31 19:22:33 - Checking route (3° try)
E 2017.01.31 19:22:35 - Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
E 2017.01.31 19:22:35 - Routing checking failed.
. 2017.01.31 19:22:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.01.31 19:22:35 - Disconnecting
. 2017.01.31 19:22:35 - Management - Send 'signal SIGTERM'
. 2017.01.31 19:22:35 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.01.31 19:22:35 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.31 19:22:35 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.31 19:22:40 - OpenVPN > /sbin/ip route del 46.165.208.69/32
. 2017.01.31 19:22:40 - OpenVPN > /sbin/ip route del 0.0.0.0/1
. 2017.01.31 19:22:40 - OpenVPN > /sbin/ip route del 128.0.0.0/1
. 2017.01.31 19:22:40 - OpenVPN > Closing TUN/TAP interface
. 2017.01.31 19:22:40 - OpenVPN > /sbin/ip addr del dev tun0 10.4.12.49/16
. 2017.01.31 19:22:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.31 19:22:41 - Connection terminated.
. 2017.01.31 19:22:41 - DNS of the system restored to original settings (Rename method)
I 2017.01.31 19:22:44 - Checking authorization ...
! 2017.01.31 19:22:44 - Connecting to Achird (Switzerland, Zurich)
. 2017.01.31 19:22:44 - OpenVPN > OpenVPN 2.3.4 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Nov 12 2015
. 2017.01.31 19:22:44 - OpenVPN > library versions: OpenSSL 1.0.1t  3 May 2016, LZO 2.08
. 2017.01.31 19:22:44 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.31 19:22:44 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.01.31 19:22:44 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:44 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:44 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]
. 2017.01.31 19:22:44 - OpenVPN > UDPv4 link local: [undef]
. 2017.01.31 19:22:44 - OpenVPN > UDPv4 link remote: [AF_INET]185.156.175.34:443
. 2017.01.31 19:22:44 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.34:443, sid=c0f845e1 ad02e31b
. 2017.01.31 19:22:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.31 19:22:44 - OpenVPN > Validating certificate key usage
. 2017.01.31 19:22:44 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.31 19:22:44 - OpenVPN > VERIFY KU OK
. 2017.01.31 19:22:44 - OpenVPN > Validating certificate extended key usage
. 2017.01.31 19:22:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.31 19:22:44 - OpenVPN > VERIFY EKU OK
. 2017.01.31 19:22:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.01.31 19:22:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.31 19:22:45 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.31 19:22:45 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.31 19:22:45 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2017.01.31 19:22:45 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]185.156.175.34:443
. 2017.01.31 19:22:47 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.01.31 19:22:47 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.13.48 255.255.0.0'
. 2017.01.31 19:22:47 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.31 19:22:47 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.01.31 19:22:47 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.31 19:22:47 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.31 19:22:47 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.31 19:22:47 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.31 19:22:47 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 IFACE=wlan0 HWADDR=00:27:10:78:e2:30
. 2017.01.31 19:22:47 - OpenVPN > TUN/TAP device tun0 opened
. 2017.01.31 19:22:47 - OpenVPN > TUN/TAP TX queue length set to 100
. 2017.01.31 19:22:47 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.01.31 19:22:47 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2017.01.31 19:22:47 - OpenVPN > /sbin/ip addr add dev tun0 10.4.13.48/16 broadcast 10.4.255.255
An additional information:
When unchecking "Preferences --> Advanced --> Check if the tunnel works" it works ... but not if box is checked.
