Not connected, Your IP: 216.73.216.41
Hello everyon.
AirVPN says "even the most brutal techniques of monitoring, censorship, throttling and traffic shaping will fail against AirVPN" on the frontpage.
But my question is, what settings must I use to be as anonymous as possible?
Can hardware achieve such? Can the settings in client achieve this?
Im currently using SSL Tunnel thats the most secure for my opinion, but i am new...
what can I use for even more anonimity? TOR Proxy?
thanks for your help.
Please check the guide in my signature first. AirVPN is secure by default, but it can't do everything for you, so there's links in my new user guide to various things .
Consider using Tor browser after running Eddie with network lock activated. Use Tor Browser without javascript with the security level as maximum. Only allow javascript with Noscript when you really trust that website.
Hello everyon.
Hello everyon.
is this then
VPN->TOR->WEBSITE
or
TOR->VPN->WEBSITE
Well, it depends the level of security you want and why, I am satisfied with VPN-Tor Browser-website. If someone wants to follow me then they will end with the VPN without logs, and the VPN itself won't know where I am or what I am doing, and my ISP won't know I am connecting to Tor, only to the VPN. This is easier than the other option, but it's your choice.
Hello everyon.
is this then
VPN->TOR->WEBSITE
or
TOR->VPN->WEBSITE
