whenhellfreezes 0 Posted ... Came here with same problem to see if I was the only one. With a little bit of google magic I was able to find this. https://bugs.launchpad.net/ubuntu/+source/openvpn/+bug/908824 So if you are an admin on your machine you can intiate the VPN from the command line with something along the lines of sudo openvpn air.ovpn but given what the bug report seems to say you might be unable to connect without admin rights in some form or another Edit: also i could be totally wrong about this stuff. however it worked for me Quote Share this post Link to post
stuntfest 0 Posted ... Tried the terminal command, but this all I get: Options error: In [CMD-LINE]:1: Error opening configuration file: air.ovpn Use --help for more information. Quote Share this post Link to post
Staff 10386 Posted ... Tried the terminal command, but this all I get: Options error: In [CMD-LINE]:1: Error opening configuration file: air.ovpnUse --help for more information.Hello!Please make sure that OpenVPN can find the air.ovpn file. Please check path and permissions.Kind regards Quote Share this post Link to post
stuntfest 0 Posted ... paths and permissions are all proper, but still 'times out' Quote Share this post Link to post
stuntfest 0 Posted ... I was able to fix the problem by reinstalling using TCP instead of UDP Quote Share this post Link to post
