mucski 1 Posted ... Been using the VPN for a while now, I am from France, first there was a French server, now since like a month or so it's gone. Furthermore it takes forever to connect, disabling the DNS feature helps with the speed but even then it's not fast enough. Tried different protocols (from what's available to me, which is TCP or SSL), multiple servers, some are better but still very very slow, like it custs my internet speed in half. Prior to some popular suggestions on this forums I have also tried older tap drivers, set the buffer to 256bits, and many more. Please help, I am using Windows 10. Quote Share this post Link to post
LZ1 678 Posted ... Hello! Have you tried the Beta client? Yes there's no French servers left currently. But you can still access a lot of French content. Which DNS feature did you disable? Make sure you're not leaking, on ipleak.net now. If it's a route checking issue, then try to disable DNS and Tunnel checking. You should also append some logs, merci. I find the message "Please help, I am using Windows 10" quite funny and fitting, haha . Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
