Not connected, Your IP: 216.73.216.117
Casper31
Relation between google and Captcha`s more explained by Steve Gibson
In the podcast of Security now nr.593  ,Steve mentioned the relation between captcha`s and google.
If you want to listen particularly to this subject,listen or watch from 1:43
https://twit.tv/shows/security-now/episodes/593
If you using Tor,you know captcha  can be very annoying ; for me shift-cntrl-l until they let me trough without captcha.I know the key combi doesn`t work on every site,but can be useful.
Have a good Day,
Casper
Dallas servers getting captcha from google searches now.  very annoying.
Perhaps with a little effort,you can without google... .For me startpage search engine give the same result.Etc etc.
casper
casper
startpage works again?  some time ago it seemed their information was becoming outdated.
Here is a better solution. DO NOT USE GOOGLE. Just that simple.
https://duckduckgo.com
https://www.ixquick.com/eng/
Those both work. Basically nothing from Google is worth supporting them.
Unfortunately google search is superior to all others.  I use self destructing cookies and other privacy add-ons so I feel that I'm not being taken for a ride when using them.  But, as long as they serve me 10 captchas I'll just use startpage.
