Xabache
AirVPN client disconnects 1 minute after connecting
AirVPN client connects. Your website displays a green check. Googling My IP shows I am on a different Ip and a network I use shows I am located in a different country. I start my torrent client. It makes connections and begins transfering data. At this point 3x your client disconnects, tries to reconnect, or i try to reconnect using other servers. all attempts to reconnect fail. i close the client my internet doesnt reconect until i reboot after which I am free to repeat this exact scenario to the same end. 1 minute after connecting.  It tries to restart.
Win 7 x64 home premium, zonealarm free, double router
. 2016.12.21 03:41:37 - Starting Management Interface
. 2016.12.21 03:41:37 - OpenVPN > Initialization Sequence Completed
I 2016.12.21 03:41:37 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.12.21 03:41:37 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.12.21 03:41:37 - Flushing DNS
I 2016.12.21 03:41:37 - Checking route
I 2016.12.21 03:41:38 - Checking DNS
! 2016.12.21 03:41:38 - Connected.
. 2016.12.21 03:41:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.12.21 03:41:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.12.21 03:42:52 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.12.21 03:42:52 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.12.21 03:42:52 - OpenVPN > Restart pause, 2 second(s)
! 2016.12.21 03:42:52 - Disconnecting
. 2016.12.21 03:42:52 - Management - Send 'signal SIGTERM'
. 2016.12.21 03:42:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.12.21 03:42:52 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.12.21 03:42:52 - OpenVPN > Assertion failed at misc.c:779
. 2016.12.21 03:42:52 - OpenVPN > Exiting due to fatal error
. 2016.12.21 03:42:52 - Connection terminated.
I 2016.12.21 03:42:52 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.12.21 03:42:52 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.12.21 03:42:55 - Checking authorization ...
W 2016.12.21 03:44:19 - Authorization check failed, continue anyway ({1])
! 2016.12.21 03:44:19 - Connecting to Mimosa (Canada, Vancouver)
. 2016.12.21 03:44:19 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2016.12.21 03:44:19 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.21 03:44:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.21 03:44:19 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.21 03:44:19 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.21 03:44:19 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.21 03:44:19 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.12.21 03:44:19 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.21 03:44:19 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.251.247:443
. 2016.12.21 03:44:52 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.12.21 03:44:52 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.21 03:44:57 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2016.12.21 03:44:57 - Disconnecting
. 2016.12.21 03:44:57 - Connection terminated.
I 2016.12.21 03:45:00 - Checking authorization ...
W 2016.12.21 03:46:24 - Authorization check failed, continue anyway ({1])
! 2016.12.21 03:46:24 - Connecting to Mimosa (Canada, Vancouver)
. 2016.12.21 03:46:24 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2016.12.21 03:46:24 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.21 03:46:24 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.21 03:46:25 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.21 03:46:25 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.21 03:46:25 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.21 03:46:25 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.12.21 03:46:25 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.21 03:46:25 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.251.247:443
. 2016.12.21 03:46:57 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.12.21 03:46:57 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.21 03:47:02 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2016.12.21 03:47:02 - Disconnecting
. 2016.12.21 03:47:02 - Connection terminated.
I 2016.12.21 03:47:05 - IPv6 restored.
! 2016.12.21 03:47:05 - Session terminated.
I 2016.12.21 03:47:49 - Session starting.
I 2016.12.21 03:47:49 - IPv6 disabled.
I 2016.12.21 03:47:49 - Checking authorization ...
W 2016.12.21 03:49:13 - Authorization check failed, continue anyway ({1])
! 2016.12.21 03:49:13 - Connecting to Alkes (United States, Los Angeles)
. 2016.12.21 03:49:35 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2016.12.21 03:49:35 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.21 03:49:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.21 03:49:35 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.21 03:49:35 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.21 03:49:35 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.21 03:49:35 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.12.21 03:49:35 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.21 03:49:35 - OpenVPN > UDPv4 link remote: [AF_INET]199.241.146.178:443
. 2016.12.21 03:49:45 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.12.21 03:49:45 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.21 03:49:50 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2016.12.21 03:49:50 - Disconnecting
. 2016.12.21 03:49:50 - Connection terminated.
I 2016.12.21 03:49:54 - Checking authorization ...
W 2016.12.21 03:51:18 - Authorization check failed, continue anyway ({1])
What client are you using?  Can't tell from the logs.  You said "AirVPN Client" in your message, but which one (you log doesn't look like a typical eddie log dump)?  Try moving to the experimental build, 2.11.  Go to the download area, click other versions, click experimental and try that version of eddie.
zonealarm free
You could of course try disabling this one.. I'm sure you let it block vital packets.
Are you close to the 3 devices limit? As you're getting authorization errors.
